What kind of maintenance is involved on Diablo Vs. a 512 TR? | FerrariChat
Discussion in 'LamborghiniChat.com' started by silvergts1998, Jan 19, 2006.
  1. silvergts1998
    silvergts1998 Formula 3
    Apr 10, 2005
    2,426
    ky
    Adam
    Does the Diablo have chain driven cams vs the Ferrari's belt driven?
    Just curious which would be less to maintain and easier.
  2. Tomf-1
    Tomf-1 F1 Rookie
    Jan 17, 2004
    4,528
    Leawood KS/ South FL
    Thomas
    i've had both....w/o clutch, the diablo is cheaper to service than the 512tr (chain vs. belt). w/ clutch replacement, the diablo will run into some serious money (engine out). relative to drivability and enjoyment, my diablo takes preference over the 512tr.
  3. silvergts1998
    Apr 10, 2005
    2,426
    ky
    Adam
    Thanks Tom,
    What is the average cost to change the clutch out? Would you say the engine is a stronger engine than the 512TR?
  4. Tomf-1
    Tomf-1 F1 Rookie
    Jan 17, 2004
    4,528
    Thomas
    it depends on who you ask. on my 92 diablo, it's a bit north of 13k done at george evans. relative to engine strength, i have NO CLUE....i never keep them long enough to test their durability.
  5. WDR328
    WDR328 Formula 3
    Dec 11, 2003
    1,476
    The Bugscuffle Inn
    D. Rose
    I have a 512M and a 99SV. The apparent difference is the chain vs the belt cam drive. The difference in service IMHO is the 512 requires the engine to be removed to do the belt service,BUT the clutch can be changed with relative ease. The Diablo requires virtually "NO" cam service but requires the engine to be removed to change the clutch. So I suspect it is a draw. FRANKLY: with all things considered (including engineering and ease of problem rectification) I would select the Ferrari! Just my opinion I own both and find the F-car more enjoyable and comfortable. I realise that this is an anthithecal post to most of the Lambo people, But it is my opinion
  6. Cicero
    Cicero Formula 3
    Jul 27, 2004
    1,645
    when did you get an SV? color? sell the 355 and 328?
  7. silvergts1998
    Apr 10, 2005
    2,426
    ky
    Adam
    Wow! $13K for a clutch change? A friend of mine has a Momo edition yellow Diablo...he mentioned somewhere in the $5K range. I think the belts scare me more than the chain driven ones...because the belt breaks with the F-car...then it's a ton more money to fix. Is there a thread on Diablo's somewhere where a DIY did his own Clutch change? I can't imagine it being that hard.
  8. WDR328
    WDR328 Formula 3
    Dec 11, 2003
    1,476
    The Bugscuffle Inn
    D. Rose
    I suspect none of this stuff is that hard if you have done it before. IE: yank an engine out of some car and replace the clutch and put it back in. I have done several of these. However, pulling a motor out of a Lambo and stabbing it back in is a BIT of a chore and you had better make sure that everything you did is JAM up, because if it is not you are are going to do it again. The broken belt deal on the Ferrari---is a bit of Kabouke theatre. I suspect if you let them go long enough they will break. But if you let the timing belt break on an American engine it might also damage the valves, seats and pistons. Good maintenance will alleviate most of these problems
  9. Rapidsugarfoot
    Rapidsugarfoot Karting
    Nov 11, 2005
    73
    Naples,FL
    Cameron
    I dont remember what the thread was exactly but it was very popular and it purtained info on parts that you can get from NAPA for easier replacement (cost wise)....
    I mean you don't really need to pay 160$ for a hose. Noone really should, although I imagine their are people who would rather see their car fixed for 30K then send a kid to college.
    On the topic of Ferrari VS Bull.......The ferrari IMO has more service problems and mechanical quarks...... A close friend has a 355 and has these two gaskets in the Tranny that snap and then need to be replaced ALL the time. It costs about 7K everytime from a ring snaps and the ring only costs 3.50 a piece. He has 55K on his clock and his mechanic says it is the cleanest (mechanicaly) he gets to work on. SOOOOO I guess that it just really is what car you get, since they are all handmade. (maybe not all ferraris are handmade) but Lambos are!!!!! There are a few guys on here that say their cars are better and stronger built than any other of the exotics they have owned. If you want reliable check out Lotus and maybe even some Aston Martins.......they get great reviews all the time!
    PS.....The Bulls are still sexier!
  10. Looney
    Looney F1 Rookie
    Jul 1, 2004
    2,767
    Gold Coast
    BB
    Hahaha, Lotus' have to be one of the most unreliable cars out. The Elise has improved things substantially, and mine has been relatively trouble free, but stuff still falls of and it has some querks.
    If you look at something like an Esprit, i would suggest that the mechanics get to drive them more than the owners.
    Cant comment on Aston's though
  11. FL 355
    FL 355 Formula 3
    Nov 3, 2002
    1,665
    Ft Laud
    Frank Lipinski
    I'm the one that started the NAPA thread and it can be found on two web sites.
    When I bought the Diablo I did a full major service just for the fun of it :) Discovered everything will cross reference to a part from NAPA. My major service DIY was a few hundred dollars. I also replaced the coils, dist cap and rotor (all from NAPA). The 5.7 is very easy to work on. I was surprised on how well the motor was designed for service. Drain plugs, fillers, filters are all within reach and easy to get to. Designed with the mechanic in mind.
    The FCar belts are the killer. Factory said 30K or 5 years, but recently revised it to 3 years.
    The clutch is the weak point on the Diablo. The problem is the factory clutch is not designed for hard driving with that much power. I know people with 50K on the clock and clutch is fine, but these are pampered drivers. There are several aftermarket products that will remedy the problem. C/F, Carbon or triple plate. In terms of price - you can get a clutch rated at 750hp for $3k. Installation is 19 labor hours at the dealer. My mechanic is $75/hr.
  12. FL 355
    FL 355 Formula 3
    Nov 3, 2002
    1,665
    Ft Laud
    Frank Lipinski
  13. Rapidsugarfoot
    Nov 11, 2005
    73
    Naples,FL
    Cameron
    I just recently had a friend who bought the Elise and absolutely loves the lil'guy. He hasn't had any problems with it and drives the living **** out of it. I have witnessed the violence myself, sad true, but the thing actually kinda likes it. I have heard of complaints about the Electrical systems though. (I dont know for sure)
    Aston Martin is a little less tolerable to punishement, but they do drive well and have little problems from what I hear under the daily abuse. I also have a friend with a DB9 and he hammers on it, I am not sure how much maintenance is on it, but he has done only a minimal amount. I would compare it to a Z06 (not in performance, astons are just nicer there) but in things breaking and having problems.
    But whatever the car is, make sure its inspected by someone YOU trust!!
  14. Tomf-1
    Tomf-1 F1 Rookie
    Jan 17, 2004
    4,528
    Thomas
    frankie,
    i am shipping my car to you next time i need major service and/or new clutch :)
  15. silvergts1998
    Apr 10, 2005
    2,426
    ky
    Adam
    That has to be one of the best lambo sites I like!!! I like the engine removal pictorial. Doesn't look that bad.
  16. bentasm1
    bentasm1 Formula Junior
    Jun 7, 2004
    656
    My Orange 6.0 recently had a clutch change thanks to Busta Rhymes rappin style of driving prior to me owning the car. It cost $6500 for the clutch change. If you pay $13,000 for clutch work, it better be on TWO Lamborghinis.
    -Ben
  17. Get the Diablo, if it gernades on you I will help pull the engine etc.
  18. David_S
    David_S F1 World Champ
    11,260
    Mountains of WNC...
    David S.
    Cripes! Are you saying the F car has problems on a subatomic level? Bummer! :)
  19. Rapidsugarfoot
    Nov 11, 2005
    73
    Naples,FL
    Cameron
    haha, hadn't had any coffee at time of post.......but now that you mention it there is something a little creepy about the similarity of Ferraris McDonald colors. I find that whenever I eat McDonalds I have to **** and whenever I see a Ferrari I have to ****......maybe your right,
  20. rsvmille676
    rsvmille676 Formula Junior
    Nov 24, 2004
    765
    G-town
    Scott Major
    *cough* cough* HACK!!
    Umm, yeah they're not.
    Yeah I want the windshield wipers to go on when I adjust the temp. Oh... not enough light up front, I better turn on the radio so my head lights go up.
    Why do the brits drink warm beer.... yep.. lucas refridgerators.
  21. silvergts1998
    Apr 10, 2005
    2,426
    ky
    Adam
    What do you guys think about a 1994 Diablo VT?
  22. Europeanroadandracing
    Europeanroadandracing South Carolina
    Dec 19, 2003
    2,228
    Isle of Palms, SC
    Karl Troy
    The only weakpoint on a Lambo clutch is the driver. Clutches will last a long time unless people try stupid stunts like burnouts with a VT or so. I have owned two Diablos. VT and SVR and none ever needed a clutch while I had them. I did not baby them by any means.
    Karl
    www.europeanroadandracing.com
  23. Air_Cooled_Nut
    Air_Cooled_Nut Formula Junior
    Nov 25, 2004
    952
    Portland, Oregon
    Toby Erkson
    Awesome job!!!!!
