What kind of oil are you using? | Page 3 | FerrariChat
Discussion in '308/328' started by Jonny Law, Nov 9, 2010.
  1. JohnnyS
    JohnnyS F1 World Champ
    Oct 19, 2006
    15,285
    Illinois
    Yeah, I was going to leave it in for the winter when it isn't being driven and then change it in the spring to Castrol GTX 10W40 or something similar.
  2. Dino Milano
    Dino Milano Rookie
    Oct 30, 2008
    49
    Italy,Belgium
    Dino M.
    208 GT4 and 308 Q.V: Agip sint 2000 10W40
    360 Modena: Agip Extra HTS 5W40
  3. MechanicMan
    MechanicMan Rookie
    Jun 1, 2011
    34
    Northern Virginia
    I'm generally in this camp. I plan to use 10w40 dino oil in my newly acquired 308 QV. Not really too concerned about the brand, although I usually get Castrol as it's readily available.
  4. Bones2U
    Bones2U Formula Junior
    Jul 13, 2008
    814
    Ontario
    I only use Valvoline VR1 Racing 20W50. These old engines don't like the new synthetic stuff and I don't find there is a need for it. This is the best conventional motor oil around, although it is still just as pricey as the synthetic stuff.
  5. stefnews
    stefnews Karting
    Nov 23, 2010
    81
    EU-Hungary, Budapest
    I have filled my 308GTS '79 with :
    Engine : Castrol GTX
    Trans : REDLINE 75W90 NS !! Unbelievable wonder, fluid gold, for the gearbox and difflock, the difflock close much more erlier. This oil is not cheap, but the absolutely No1. Shifting is 3x quickly no different, when is cold or warm, absolutely the best.
  6. Jonny Law
    Jonny Law F1 Rookie
    3,210
    Over yonder.
    IT Guy
    20-50 or maybe shell rotella 15-40 was what has been recommended to me. The Brad Penn 20w50 is what I have been putting in lately because it has the extra ZDDP added in. Until I can rebuild the engine and get the proper size pistons to cylinders in, I am (like most) stuck pouring in a bottle of oil every couple of times I fill up.
  7. Jeff Kennedy
    Jeff Kennedy F1 Veteran
    Oct 16, 2007
    6,887
    Edwardsville, IL
    Jeff Kennedy
    Redline for the engine, trans and water wetter.
    Jeff
  8. stefnews
    stefnews Karting
    Nov 23, 2010
    81
    Thats Right
  9. stefnews
    stefnews Karting
    Nov 23, 2010
    81
    Thats Right
  10. stefnews
    stefnews Karting
    Nov 23, 2010
    81
    Thats Right
  11. lonnie77
    lonnie77 Karting
    Feb 17, 2011
    140
    Kennedale, Texas
    Lonnie Harrison
    As usual I do things different. I have been using Quaker State in all my cars Without any problems. I tried castrol in my pick-up for two years and sludge built up and clogged the oil pump which caused two inserts to spin.
    All oil meet's the min requirement while some claim to exceed the requirement. There is synthetic, paraffin base and sulfur base oil. Paraffin being wax will create sludge while sulfur will clean the engine but may break down under heat.
    To open a can of worms let's talk about filters. Haa..a. All filters meet the min requirement but the minimum does not trap everything and the maximum will restrict the flow and clog easily. So do you want good oil flow with some dirt or low oil flow with no dirt?
    If you change your filter more often can you go further between oil changes?
  12. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,833
    Cerritos, CA.
    I want good oil flow with no dirt!
  13. Jonny Law
    Jonny Law F1 Rookie
    3,210
    Over yonder.
    IT Guy
    Does anyone know if Consumer Reports still does their testing of these things? It would be nice to see their test results on filters and oil.
  14. lonnie77
    lonnie77 Karting
    Feb 17, 2011
    140
    Kennedale, Texas
    Lonnie Harrison
    So it begins.
    Which filter will do that?
  15. ramosel
    ramosel Formula 3
    Sep 11, 2004
    1,237
    Meadow Vista, CA
    R Moseley
    Jonny Law,
    If you really want to know more about "WHAT OIL" than you'll ever need to know, start here:
    http://ferrarichat.com/forum/faq.php?faq=haas_articles#faq_motor_oil_basics
    Then search for all the ancillary articles from Dr. Haas on this site (Search the Technical Q&A section for Oil and user AEHaas). There is quite literally a few days worth of reading. Some very good information and some tedium for those who need that level of information. After a few hours you'll either know EXACTLY what oil you need to use or be so confused you'll never want to see your dipstick again.
    Rick
  16. rvance
    rvance Karting
    Aug 30, 2010
    60
    Northern California
    Rick
    The factory manual lists 10-50 but I can't find it. Any hints on where to purchase it? Also is Agip even available in the US? I decided to go with 10-40 but I see some people are using 20-50 in the summer. That may keep the heat down but I think it protects a little less. I moved my oil cooler to the left vent and have additional air flow through the wheel well so I don't have to worry about that as much - great mod!
  17. MechanicMan
    MechanicMan Rookie
    Jun 1, 2011
    34
    Northern Virginia
    Yes, you can buy agip in the USA directly from agip. Friendly people and good prices. They now make 10-40 instead of 10-50.
  18. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,912
    Mike 996
    Interestingly, when modern performance engine shops build US musclecar V8 motors, 5W30 is a very common recommendation. The lighter oil has much less frictional drag, carries heat better, and gets where it needs to go quicker.
    Of course, we are talking about engines that are essentially blueprinted, not production engines with clearances varying all over the place.
    Just curious, anybody know what oil is specified for a current (new) Ferrari?
  19. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,354
    I believe the Enzo runs on 10W60 (but that Dr Haas runs his on 0W30)
  20. Mcarbognin
    Mcarbognin Rookie
    Mar 13, 2011
    9
    Calgary
    Marcello Carbognin
    I use Mobil 1 0W-40 in my 308 gtb
  21. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,912
    Mike 996
    "the Enzo runs on 10W60"
    Wow - I wouldn't think oil with that wide a viscosity range could maintain that range for more than maybe 1000 miles, if that. Seems like at the normal oil change interval it would probably be around 30 wt! :)
  22. tempest411
    tempest411 Formula Junior
    Dec 3, 2010
    564
    Those are both oil types I have never seen here in the U.S. Why, I wonder...
  23. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,318
    Germany
    Steven
    shell racing 10W60
  24. DWPC
    DWPC Formula Junior
    Mar 10, 2011
    733
    Sedona AZ
    Dennis
    Now I'm curious about how close to "blueprint" 308 engines were when they left the factory. Any data around?
  25. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,912
    Mike 996
    Well, the fact that Ferrari considered it "within specs" to burn a quart of oil in several hundred miles indicates that they were not built to particularly exacting standards - certainly not to blueprinting standards. Since some cars burned that much oil and others went 2k+ miles before being a quart low, it pretty much shows that the engine assembly tolerances/practices were actually on the rather sloppy side.
    It seems to me that they had exactly the same chance of a good (or bad) engine as any auto manufacturer - if you lucked out you got a motor where all the specs "came together;" if you didn't, you burned a quart of oil in less than 1k miles with the associated other issues (less power, carbon buildup on the valves/pistons, excessive blowby) and as far as Enzo was concerned, it was "in spec." ;)
