What lift do you use at home? | FerrariChat
Discussion in 'Technical Q&A' started by massimofinance, Jul 21, 2011.
  1. massimofinance
    Nov 24, 2004
    39
    I want to put my 330 GTC up on one of those four post lifts for the winter so I can park under it. Does anyone have one of these? Seems to be a lot of brands out there, prices starting just of of $2k, but a lot of warnings about the Chinese made ones. Any opinions?
  2. LightGuy
    LightGuy Four Time F1 World Champ
    45,585
    Texas
    David
    #2 LightGuy, Jul 21, 2011
    Bought a Rotary because it was US made.
    Upon assembly found Made in China stickers.
    Figures, the price was too good.
    I really do like it because in my garage everything had to be adjusted to a gnat's whisker.
    This Rotary has adjustments screws for infinite adjustability.
    There are only a few US made ones left.
    I would have liked to buy a US product.
  3. DGS
    DGS Seven Time F1 World Champ
    71,851
    MidTN
    DGS
    Mine's a low-rise, from Eagle Equipment, as they were local (for the sake of delivery).
    They no longer market that model, which was virtually a direct copy of the Bend-Pak.
    Whichever one made it, there are no "made in China" stickers on it. ;)
  4. LmnsBlu355
    LmnsBlu355 Formula Junior
    Dec 28, 2009
    284
    NY
    Jordan S.
    Direct lift pro-park 8 plus. Its a great lift and very adjustable to level the platforms even if your floor is sloped. Very reasonable price and high quality. Check out Gregg Smith Equipment.
  5. davebdave
    davebdave Formula 3
    Mar 18, 2007
    2,381
    Northern VA
    Dave W
    +1
    Great lift...the net is full of stories/photos of Chinese 4-post lifts dropping cars but it is most likely operator error...you must adjust the lift so that all 4 safety catches engage at exactly the same time and verify that they are all released as you lower it. If one corner remains engaged on the way down - watch out.
    Dave
  6. duskybird
    duskybird F1 World Champ
    12,611
    29 Electoral Votes
    Bill B.
    I have two 4 post perfect park 7000's and a Greg Smith 2 post 9000. I really like my decisions on both.
  7. JohnnyS
    JohnnyS F1 World Champ
    Oct 19, 2006
    15,280
    Illinois
    Pro Park 7 (7000 lb) 4 post lift. Easy to set up and works like charm. Very pleased with it.
  8. moorfan
    moorfan Formula Junior
    May 11, 2009
    809
    Central Virginia
    Pete
    Another vote for a Direct Lift pro-park 8p. I also have two 3500lb jacks from direct lift on the 4 poster to raise the vehicle off the lift.
    Very good quality lift. Apparently there is an American Lift Institute that certifies lifts to be able to lift 1.5 times their rated capacity, and the Direct lift, as well as the ones from Rotary and Bend Pak are on the list. Make sure IMHO to go with a "certified" lift.
    Direct Lift is owned by Rotary, and the lift is assembled in China with American Steel (allegedly).
  9. DANCER308
    DANCER308 Formula Junior
    Oct 24, 2009
    935
    KY
    Dan
    #9 DANCER308, Jul 22, 2011
  10. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    I have a Snap-On scissor lift, 9K lbs. capacity. The problem with it is that it has a solid platform that is under the mid-section of the car, so if I need access to that area (which seems to happen often), I have to lower the car onto jack stands to get the platform out of the way. If I had the room, I would get a 4 post lift, like a Backyard Buddy that a friend has. But I don't, so I make do with the scissor lift, which is great for most of what I do in my home garage.
  11. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    Bendpak single post for storage and Bendpak 2-post for working on the cars.
    Jes
  12. norcal2
    norcal2 F1 Veteran
    Danmar and Bendpak..made by the same company...
  13. ramosel
    ramosel Formula 3
    Sep 11, 2004
    1,237
    Meadow Vista, CA
    R Moseley
    Jes, (or anyone with a two post)
    I currently have a 4 post with jack bridges and have come to love it for all the things you can do with it. I'm buying a new house (OK, I'm buying a garage with living space attached). The new house has a bendpak 2 post I'm buying because the owner has put radiant heat in the floor and I can't drill for anything else....
    so, how well does the 2 post fit under the Ferrari. I've heard of others who have had to make ramps to drive the car onto to get the arms underneath... Did you make any special saddles for the arms to grab the frame?
    Rick
  14. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    I haven't had the 360 on the 2-post lift, runs like clockwork - knock on wood. But for my Alfa race car which is super low I used my home made wooden ramps. Though, I don't think that would be necessary with the 360 - my guess is the arms will fit underneather no problem. It may also depend on which 2-post model you have...
    Jes
  15. Gerry328
    Gerry328 Formula 3
    2,435
    Home
    Gerry
    #15 Gerry328, Jul 22, 2011
    I have a Bend Pak 6,000 Lb. Single Post Parking Lift. While more expensive than a 4 post, love not having to deal with posts is the center of my garage.
  16. 2000YELLOW360
    2000YELLOW360 F1 World Champ
    Jun 5, 2001
    19,800
    Art
    I've got a 2 post in the hanger. The Mondial fit, but the 430 didn't. The solution:
    Pull out the arms, cut them down, remachine the arms to take a better fit, and now it works just time.
    Found this 2 post, 7000# lift, that works on 110, for 500 dollars. Great deal.
    Art
  17. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,191
    Kingsport, TN
    Lawrence A. Coppari
    Eagle 4 post.....bought it around 1994, I think. No problems. It has large casters so it can be moved around.
  18. rwk360
    rwk360 Formula Junior
    Aug 26, 2005
    394
    Pebble Beach, CA
    R W Kenton
    Really? Chinese? I have Rotary 2- and 4-post lifts, installed by the regional dealer 3 yrs ago. I find no evidence of Made in China stickers, etc. I bought Rotary at that time because they were (supposedly) US-made, with a good dealer network. They added on another year of the factory warranty since I had them do the install.
  19. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,556
    San Carlos, CA
    Mitchell Le
    Sections of the new San Francisco Bay Bridge are being manufactured in ... China. Shall we refuse to use the bridge when it is finished? That would be a funny reaction, would it not?
  20. Michael Everson
    Michael Everson Karting
    Nov 5, 2005
    224
    Norton, MA USA Earth
    Michael Everson
    I currently have 3 lifts at my house. All 4 post. All made in China and all work flawlessly. All 3 are different brands but are identical in every way except color. I think they are all imported by Eagle Equipment and resold under different brand names
  21. gilligan308
    gilligan308 Karting
    Dec 8, 2008
    141
    S.W.Florida
    Brian
    I bought an "AMERICAN" lift from American equipment. It is two pole #9000 asymetric lift that really was easy to install and I park in it every day and can store my other car up top and was only $1100.00. Oh and by the way it was made in China and didn't know it until I unwrapped it and it had all metric bolts and funny colored cardboard. But it works wonderful.
  22. toggie
    toggie F1 World Champ
    Nov 30, 2003
    19,036
    Virginia
    Toggie (Ron)
    I have the 4-post Rotary Revolution lift.
    Installed by the regional dealer about 5 years ago.
    Been perfect. I keep my 65 Corvette convertible parked on top.
  23. full_garage
    full_garage Formula 3
    Feb 15, 2010
    2,241
    Sarasota Florida
    Jay
  24. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    #25 Spasso, Jul 27, 2011
    I have an Autolifters 4-post. (Now defuct company.) Also made in the USA.
    Very safe design, good features, heavy construction. Oversized ram, bearings in the pulleys instead of bushings, 220 volt motor.
    No problem getting replacement parts because they are all "industry standards" used on most of the other lifts out there.
    Mine is the "standard" size, which, If I had to do it over again, I would have gotten the "SUV" size. My TR barely fits on this one and I could use another 8 to 12" of height on occasion.
