what material? | FerrariChat
what material?
Discussion in 'Creative Arts' started by essdime, Dec 21, 2007.
  1. essdime
    essdime Karting
    Apr 26, 2006
    180
    Edmonton
    Ian K M.
    i have come across alot of modern interior design with what it looks like to be wood panel on the walls. Its very modern looking, and looks very sharp! Does anyone have any idea what material / construction it is made of? Im considering it for a new project in a room.
    Ian
  2. MarkPDX
    MarkPDX F1 World Champ
    Apr 21, 2003
    15,111
    Gulf Coast
    Could it be panels made of wood? Sometimes wooden panel looks like that.
  3. essdime
    essdime Karting
    Apr 26, 2006
    180
    Edmonton
    Ian K M.
    any USEFUL ideas?
  4. teak360
    teak360 F1 World Champ
    Nov 3, 2003
    10,065
    Boulder, CO
    Scott
    Actually Mark's answer was pretty good given the question. Anyway, can you be a little more descriptive re: what it is you are looking for?
  5. essdime
    essdime Karting
    Apr 26, 2006
    180
    Edmonton
    Ian K M.
    #5 essdime, Dec 24, 2007
  6. djui5
    djui5 F1 Veteran
    Aug 9, 2006
    5,418
    Phoenix, Arizona
    The middle one is real wood, strips of it glued together and finished on the outside. Same with the last one. Not sure how they construct something like that though. I'm sure they use whatever kind of exotic wood the home owner wants.
  7. essdime
    essdime Karting
    Apr 26, 2006
    180
    Edmonton
    Ian K M.
    thanks for your help, i was pretty much thinking the same thing, but just looking for some feedback on how to go about this. Thanks
  8. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    Are we talking about the pic with the wood covered surface to the right of all the switches on the wall?
    Either way, an application like that is most likely a wood veneer or cabinet grade veneered plywood type application.
    I don't do much with modern style homes/buildings, but IMO, while veneers are actually "real" wood, I don't consider veneer to be actual "real" wood if you know what I mean.
    A sheet of veneer is a layer of wood ( a couple of mils thick) shaved off a log (similar to how paper towel comes off a roll)... it can then be applied to bacially a plywood sub-straight to produce cabinet grade plywood, or used in it's original sheet form and glued to curved, irregular, or overly large surfaces.
    Lets say you were going to build a conference table... something like 6'x20'. You'd used a veneer. You'd make the table sub-straight out of a cheap and stable material like MDO, MDF, multi layer cross oriented plywoods, etc. Then use the veneer over the top since sheets of veneer are easier to produce and work with than dimesional lumber of the same dimesion. In essence it's real wood....
    Veneers have been used for many if not hundreds of years in the furniture industry, boat building and the like and on very high end items...however, IMO (on a philosophical level) a veneer is not "wood"...it's a "wood veneer". I own several nice peices of furniture that are veneered in everything from birdseye maple, oak, cherry and mahogany.
    For modern design applications of exotic woods...(ei expensive), it's a practical use of a limited resource.
  9. essdime
    essdime Karting
    Apr 26, 2006
    180
    Edmonton
    Ian K M.
    #9 essdime, Dec 25, 2007
    wow, thanks for the reply, i appreciate it. I was thinking of getting some sheets of 1/4 inch ply wood, sanding it smooth and staing it, then cut the sheets into sections to create the look in going for.
    for example the island in this kitchen
  10. Sea Bass
    Sea Bass Formula 3
    Jun 4, 2006
    1,041
    I'm no engineer or woodworker but I don't think plywood will look good. I think you would need maple, oak, redwood, teak, or some other real wood. Plywood isn't going to look good stained, no matter which way you slice it.
  11. BMW.SauberF1Team
    BMW.SauberF1Team F1 World Champ
    Dec 4, 2004
    14,437
    FL
    I've always liked this style. If I had a garage on a lower level connected to a bonus room or something, I would replace the load-bearing 2x4s and drywall with a couple steel beams and then put glass walls around it. Try to incorporate a sleek looking car into a modern design. Maybe polish the concrete floor as well. :)
  12. essdime
    essdime Karting
    Apr 26, 2006
    180
    Edmonton
    Ian K M.
    yea i actually agree upon the plywood comment, maple would look pretty good. Hopefully I can find somewhere local that has maple sheets.
  13. wax
    wax Five Time F1 World Champ
    Jul 20, 2003
    52,415
    SFPD
    Dirty Harry
    Faux finishing
    http://www.diynetwork.com/diy/lv_faux_finishing/0,2040,DIY_14109,00.html
    "wood grain"
    http://www.diynetwork.com/diy/la_walls_floors/article/0,2041,DIY_13992_2269131,00.html
    "paneling"
    http://www.diynetwork.com/diy/lv_faux_finishing/article/0,2041,DIY_14109_2278235,00.html
    Minimalism
    http://www.ehow.com/how_14674_decorate-living-room.html
    http://www.ehow.com/how_14683_decorate-master-bedroom.html
    Bauhaus-style furniture - Prices are fair
    http://www.spacify.com/bedroom_in_stock-460-175.html
    On the cheap? Copy the ^copycats^ - Like sex, glue - not just screwing - is the tie that binds.
    For the price of retail furniture, you can build something with materials you select, and keep the tools.
    If you decide to do something like this on the side, and write off items as business or a home/office expense, there's that angle, as well.
    If a restaurant is getting rid of stuff kinda like the island sans the fancy finish - see if it's not banged up and if side can be recovered.
    The French term in painting for "trick the eye" is "Trompe-l'œil" - that's what you're after if not paying exorbitant amounts for the originals.
    and/or, go to Ikea - hell, even Big Lots has things which might fill the bill.
    Go to your bookstore and pick up a copy of Metropolitan Home magazine. Always something interesting and relatively cheap in Modern Design.
  14. AntonyR
    AntonyR F1 Veteran
    Apr 12, 2004
    5,426
    Los Angeles
    Antony
    Polycarb
    Stainless steal
    Brushed aluminum
    Concrete
    most raw materials
    Antony
  15. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    Obviously not local,
    http://www.woodcraft.com/search/search.aspx?SH=A%3dveneer%7eB%3dveneer%7eD%3d24%7eK%3d4%7eL%3d1%7eM%3d4%7e&SI=73ee6179-1c3b-476a-afb1-27c06b323621&LAP=0&Action=3&Page=1
    www.rockler.com has small sheets of veneers, nothing as big as 4'x8'
    Look in your area for cabinet shops and places that sell high pressure laminattes, they will almost always have or have access to large sheets of veneers or even a good selection of cabinet grade plywood in different thicknesses.
    I used to buy 24"X8' sheets of laminate right off the rack at Menards and home deopt. Haven't had a need for those in a long time, so I don't know if they still stock stff like that. They were also limited to Oak, Cherry and Mahogany IIRC.
  16. jelpspeed
    jelpspeed Formula Junior
    Nov 29, 2007
    546
    Guadalajara, Mexico
    Ever Lopez
    the materials suggested by AnthonyR would give you a great look in your project. I also use carbon fiber for some customers, and together with brushed aluminum gives an outstanding and modern look.
  17. tritone
    tritone F1 Veteran
    7,199
    On the Rock
    James
    if 'veneer' is OK, also consider 3M Di Noc, wrapped and glued. Same stuff used on station wagons in the '50's and later. A bit more 'hi-tech', and more choices now, but enables very light weight and good 'flatness' on the right substrate (mdf or...). Cheaper than 'real veneer' (which is v. thin wood).
  18. JCW Driver
    JCW Driver Formula Junior
    Oct 24, 2006
    393
    Portland, Oregon
    Bronson G.
    Parklex or Prodema are an option for wood veneer panel systems...
    Both manufacture interior and exterior grade spec products. I've used them on a couple projects (130 unit condo and 45 unti condo) and it's a nice product.
    Typically comes in 4x8 sheets (measured in mm), and is a resin impregnated wood veneer panel.
    www.parklex.com
    www.prodema.com
