What model year was kjet with lambda installed on the 308 QV? | FerrariChat
Discussion in '308/328' started by SeattleM5, Jul 14, 2016.
  1. SeattleM5
    SeattleM5 Formula 3
    1,261
    Kirkland, Washington
    Ettore Palazzo
    Folks, a while back I acquired a Jetronic ECU from an 84' 308 QV that was being parted. I picked it up assuming that all of the 3x8's with lambda control used the same ECU and thought it might be a good idea to have it as a spare for my 328. Turns out the QV ECU is different from the 328 (QV Jetronic ECU Ferrari part# 121516/Bosch 0280800063, 328/3.2 Jetronic ECU Ferrari part# 127479/Bosch 0280800068). I have the QV Jetronic ECU for sale in the classified section (http://www.ferrarichat.com/forum/ferrari-parts-collectibles/514729-308-mondial-qv-jetronic-ecu.html) and yesterday someone asked if the ECU will work on an 83 QV. My understanding is that Kjet with lambda which requires this ECU was first fitted to US version 84 QVs. Can any QV owners confirm. Thanks in advance.
  2. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,814
    Cerritos, CA.
    QV uses the Digiplex up to 1985 then switch over to Jetronics in 1986
  3. SeattleM5
    SeattleM5 Formula 3
    1,261
    Ettore Palazzo
    Mike, I think we're talking about two different things (ignition ECU vs. fuel injection ECU). I'm sure someone smarter than me will correct me if I'm wrong, but I believe the 308QV ignition was indeed governed by dual Marelli Digiplex ECUs for each bank while the 328/3.2 line used a single Marelli Microplex ECU.
    The Bosch Fuel injection ECU which I'm referring to was introduced with the addition of kjet with lambda (addition of kjet with an oxygen sensor). I'm trying to figure out if kjet w/ lambda started with the US version QVs in 83 or 84.
  4. miketuason
    Feb 24, 2006
    15,814
    Cerritos, CA.
    Yes you're right, I misunderstood sorry!
  5. Steve Magnusson
    26,899
    Correct - 1984 and 1985 US 308QV are K-Jet with Lambda. 1983 US 308QV are K-jet without Lambda (so no Jetronic ECU).
  6. SeattleM5
    SeattleM5 Formula 3
    1,261
    Ettore Palazzo
    Thanks Steve!
    Sent from my SM-G900V using Tapatalk
