What oil are you using? | FerrariChat
Discussion in '348/355' started by eric lipper, Jan 27, 2008.
  1. eric lipper
    eric lipper Karting
    Nov 2, 2003
    172
    I am new to the 355 having been a 328 owner for a long time. My 355 looks like it is a quart low but it could be that it was never completely full after the last oil change because it was changed about 100 miles ago. I had it changed at the Ferrari dealer and they used Shell Helix 5W 40. I was going to go there and buy a quart but the question occurred to me as to what everyone else is using. I would prefer to go to Autozone for oil but at least until it is time for the next change I will probably stick to Helix. Lastly, do you check with the engine running or stopped. It showed a quart low when off, I did not check it running. All information is appreciated.
  2. Vegas-Guy
    Vegas-Guy Formula 3
    Nov 25, 2007
    1,828
    Austin, TX
    Reg
    If I remember correctly you check it immediately after shutting the car off. Someone correct me if I'm wrong.
  3. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,958
    MD and NE
    Robbie
    +1----check the oil hot, not cold...
  4. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    That only works if you check the oil very quickly after the engine is turned off (the longer that you wait, the lower the level will show). It's most accurate to check the oil level with the motor warm and running. Use appropriate safety precautions.
    Shell Helix is an awful oil. Worse is AGIP.
    I use Redline's 5w40 in the engine, and Redline's 75w90NS (presently, Superlight Shockproof previously) in my tranny/diff.
  5. 285ferrari
    Sponsor
    Sep 11, 2004
    20,958
    MD and NE
    Robbie
  6. eric lipper
    eric lipper Karting
    Nov 2, 2003
    172
    thanks for the info, I am going to check it running tomorrow night before I add any more -- I just freaked out when I checked it cold because I thought that I had driven it without any oil. I feel sure that I am somewhere between full and a quart low. I am just don't want to overfill it.
  7. rketex7
    rketex7 Formula Junior
    Jan 8, 2004
    511
    Midwest
    K.C.Y.
    I have used Redline since I could pick them up easily and it has been in my car for the last more than 2 yrs. And I believe they do have higher boiling point than the Shell. I have used it on my previous turbo charged cars as well. Never a problem.... :)
  8. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Overfilling the oil is an easy way to blow a headgasket, clog up your MAF, soil an air filter or two, and sometimes even burst an oil filter.
    I'd suggest draining or vacuuming-out as much as you just added cold, prior to restarting your motor.
  9. eric lipper
    eric lipper Karting
    Nov 2, 2003
    172
    good news is that I have not added any --- I was just checking it since I got it back from Ferrari about 100 miles ago. It may be full, I am just new to these cars and I don't exactly know what I am doing. The ol 328 was just like any other car since it had a traditional oil pan. Now I need a college degree and an internet connection to check the oil -- progress.
  10. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    Blow a head gasket? Burst an oil filter? By overfilling the oil?
    Eric, you done good to ask. The person or place that sold the car to you should have explained the procedure.
  11. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
  12. Miltonian
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    I think not. Overfilling the oil would have no effect at all on oil pressure, and could not possibly cause the filter to burst. No way. And as for blowing the head gasket, I'd have to have that one explained to me. I don't think so.
  13. sspooner
    sspooner Karting
    Jan 14, 2007
    165
    Sunnyvale, CA
    Simon
    I just switched from Mobil 1 0/40 to AMSOil 5/40
    I've always like Mobil 1, but recently, I dunno, I hear too much about additives.
    I friend of mine talked me into trying AMSOil. I remember it from my crotch rocket days as being the best for bikes.
    The reviews I read said it stacked up better than lots of other oils, but hey, I'm just an enthusiastic amateur.
  14. potxoli
    potxoli Formula 3
    Mar 22, 2007
    1,716
    Washington DC
    Eric B.
    +1. Do you know what weight they put in? I think I'm down a quart...
  15. rennspeed
    rennspeed Formula Junior
    528
    Rennspeed
    What does everyone think of Castrol Syntec?
  16. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Motul is good stuff... thats what my friend who got me into f-cars uses.... :) ...........I think I have Mobil1 in there this time.... carried over from my p-car days....... :eek:
  17. speedy_sam
    speedy_sam F1 Veteran
    Jul 13, 2004
    5,559
    TX
    Sameer
    I have Redline engine oil (5W40) and gearbox oil (75W90NS) in my 348 currently. I think I will try something else on the engine oil in the upcoming fluid change - possibly Royal Purple or Mobil 1 0W40. The Redline oil is great - I just want to try something different. I will stick to Redline for the gearbox oil though.
  18. f355spider
    f355spider F1 World Champ
    18,044
    Their 0w-30 is one of the best (you will only find it at Autozone). It has very good used oil analysis on the oil forums. It is actually almost a 40 weight if you read the specs more closely. I am thinking of switching to it from Mobil 1. Mobil 1 0w-40 has a bad trait of dropping to a 0w-30 within 1500 miles of use. Confirmed in several oil analysis done on www.bobistheoilguy.com oil forums. Their 5w-40 looks good as well, but I don't know anything about it.
    Here are the various Castrol viscosities:
    http://www.castrol.com/castrol/genericarticle.do?categoryId=82915470&contentId=6006933
  19. f355spider
    18,044
    +2, check it hot, and immediately upon shut down. Do not check it while running, esp with Shell, as it will be foamy and harder to read.
  20. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    +3 .....right after shut down, using an asbestos glove.... ;)
  21. f355spider
    18,044
    Damn straight....I use two shop towels, one to insulate the oil cap, the other to wipe the stick with. Try not to drop any oil on the exhaust manifold (it will smoke) and not on the convertible top or paint... ;)
  22. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    TRIVIA:
    If oil crackles and pops (like your favorite cereal as a kid) when a drop hits your exhaust manifold...it means that you've got condensation (or worse levels of water) in your oil.
  23. Llenroc
    Llenroc F1 Veteran
    5,495
    Colorado
    Vern
    Are you sure about that??? I'm pretty sure you can blow head gaskets and oil filters if you overfill the oil. Bwaaaahaaaa!!!!!!
    Sorry ND I couldn't resist,.. LOL... you have got to quit readin' those internet sites they're leadin' you down the wrong path.
  24. Llenroc
    Llenroc F1 Veteran
    5,495
    Colorado
    Vern
    Please allow me to ask a simple question. Why would you not read the Owners Manual on such an expensive car? Even if the PO didn't leave it with the car, they are readily available and very important to read.
  25. 05011994
    05011994 Formula 3
    May 1, 2004
    1,865
    Golden, Colorado
    Redline all the way, my mechanic used to recommend Mobil 1, but made the switch to Redline last year, I trust Mr. Helms.
