What oil are you using? | Page 2 | FerrariChat
Discussion in '348/355' started by eric lipper, Jan 27, 2008.
  1. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,984
    MD and NE
    Robbie
    Not 100% sure--Just give them a ring..I'm sure they use the same for either car..
  2. potxoli
    potxoli Formula 3
    Mar 22, 2007
    1,716
    Washington DC
    Eric B.
    I did. it is 8100 5w40 x-cess from Motul. I need to swing by to pick up a quart one of these days...
  3. speedy_sam
    speedy_sam F1 Veteran
    Jul 13, 2004
    5,559
    TX
    Sameer
    Ok after reading about Mobil related issues, I think I will stick to the Redline. :)
  4. 355
    355 F1 Rookie
    3,643
    Toronto
    Frank
    I think there are many good oils out there but I am using Motule 15w-50 as I have heard and read many good things about it. If they use it in lemans cars and high reving motorcycles then it must be good. IMHO
  5. speedy_sam
    Jul 13, 2004
    5,559
    TX
    Sameer
    I think 15W be too thick for cold weather that you get in Toronto
  6. 355
    355 F1 Rookie
    3,643
    Toronto
    Frank
    Nobody drives their Ferraris here between Nov and April and most are kept in heated garages. So 15w is not a problem unless you start your car in close to freezing weather. The summers are very hot here and any 355 once up to operating temps needs all the protection it can get. They are amongst the hottest running Ferraris made. It funny though, a few years ago I was in Pittsburg for my sons soccer game in June and some of the americans there thought that it took us days to get there and that it was still snowing in Toronto. Its a 5 hour drive :)
  7. TC (Houston)
    TC (Houston) Formula Junior
    Feb 5, 2002
    781
    Houston
    Do you guys have any reading on the dipstick when the car is cold?
    Also, Eric, I saw a black spider parked outside Smith & Wollensky last week with some sort of Carolina license plate frame. Was that yours? :)
  8. f355spider
    f355spider F1 World Champ
    18,061
  9. f355spider
    18,061
    Another well regarded oil is Shell Rotella T synthetic 5w-40. Is is designed for diesel applications, but also for gasoline engines as well. When there was a shortage of Shell Ultra Helix 5w-40 back in 2000 or 2001, FNA authorized the use of Shell Rotella T synthetic 5w-40 as substitute standard for all Ferraris.
    Four quart jugs are availabel at Wal-Mart for $16 each ($4 per quart)
    http://www.shell.com/home/Framework?siteId=rotella-en&FC2=/rotella-en/html/iwgen/products/zzz_lhn.html&FC3=/rotella-en/html/iwgen/products/product_rotellasynth.html
  10. eric lipper
    eric lipper Karting
    Nov 2, 2003
    172
    Yo TC (Houston) that was me. Went for a drink at S&W and drove around. The car now has TX plates. Small world. I live right by S&W and am usually running aroung that area.
  11. TC (Houston)
    Feb 5, 2002
    781
    Houston
    Awesome, I saw the car and thought I recognized it! Your car looked gorgeous, I had almost forgotten what a really clean 355 looked like, it inspired me to get mine out of the garage and wash it on Sunday.
  12. 355
    355 F1 Rookie
    3,643
    Toronto
    Frank
    Thats good if 5W-40 is good for a 355. If it is then check out the TDI forums. There is a group of VW TDI drivers that have been putting different milliage on their VW TDIs and sending their oil out to be tested after 6k, 10k 16k and some have gone further just to see which oils are best for their diesel VWs. There is quite a bit of reading there and I stumbled on it when googleing the best oil for my wifes TDI Jetta. There are many on there that swear by Mobile delvac 1 (delvac one) 5w-40 synthetic. Some guys who are into it big time are very technical about the tests on their oils and they say that if you use Delvac 1 5w-40 that you are throwing away good oil if you change it before 10,000 miles. So if you are using 5w-40 in your 355 then try this stuff.
  13. jetfixr
    jetfixr Formula 3
    Jun 14, 2007
    1,016
    northeast
    Gone
    I found through recent research that a person can obtain used oil much cheaper. This greatly reduces the cost of Ferrari ownership.....
    I reccomend pouring the used oil through a paint strainer prior to service.
    When the knocking begins you can get used 75-90W gear lube!!!!
  14. eric lipper
    eric lipper Karting
    Nov 2, 2003
    172
    I bought the Shell Helix because it had the little Ferrari symbol on the bottle and it gave me an excuse to got to FOH and mess around. Jetfixr, good idea on the oil straining idea, I'll have to give that one to my A&P for the next oil change in the Mentor since that must be an aeronautical secret that I didn't know. You know, maybe if I wiped the bottom of the plane off it may give me enough oil to top off the 355 given that I am at 1700 TTE on the Conti.
  15. jetfixr
    jetfixr Formula 3
    Jun 14, 2007
    1,016
    northeast
    Gone
    Good point! :) That was pretty good!
  16. eric lipper
    eric lipper Karting
    Nov 2, 2003
    172
    I enjoyed the detail that you are doing on your engine out. I will be curious how the chrome holds up on the bell housing as that was a great mod.
  17. butch355
    butch355 Karting
    Jan 27, 2005
    114
    Denver
    Brent
    I use the walmart 5w/40 shell. Same as the dealer stuff at 8$ a quart. Lets me change the oil twice a year at $16 per gallon. Redline is great but paying that much for oil when I drive my car about 1000 miles a year seems excessive. I do use the redline in the tranny, best stuff on the market, just make sure to add limited slip additive to be safe.
  18. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    Damn near fell off the chair this morning after reading this! I laughed loud enough the dogs came barking.
    I finished a very expensive full rebuild a few years back and had the owner watch as I poured in XXX brand 10w30 dino oil for start up and break in. His jaw near hit the floor and asked "can't you find something better than that!?" When told that I would be dropping that oil and the filter in 500 miles (he did not realize the new synthetic oils are too slippery for rings to seat) to put in good synthetic oil he asked "now is that really nessesary?". Nope, one could leave that swill in there for 10,000 miles and the car would still be running.
    With the cost difference being what, $40-50/yr between the best and the lesser quality oils, buy the best that money can buy what ever brand you think that is. Currently I think that is Redline and when something even better comes along I will look at changing again.
    Dave
  19. jetfixr
    jetfixr Formula 3
    Jun 14, 2007
    1,016
    northeast
    Gone
    Sorry Dave,
    I didn't mean to make you fall off the chair, or cause the dogs to bark....
    Truth be known I change my oil every 500 miles including oil analisys for trend patterns, Yes, that is no lie...I do that with my Lotus and both Fcars....I put the best in that money can buy, right now I'm trying Amsoil. Another case of Redline on the way....
    Point is, as I tell my aircraft clients.....Oil is the cheapest insurance you could ever buy.....They have taken my advice and are experiencing no coking issues or premature bearing failure...Period
    I had a client recently with I'll leave at this "mid size cabin bizjet" that took his oil changes too far or the previous maintenance simply wasn't performed....
    Today I'm hanging his other engine "150K repair".
    Brings us back to the old "tripping over quarters to pick up dimes"
    P.S. I have some used turbine oil as well, complete with gold and gray glitter floating in it from the above mentioned engine :)
  20. bowbells
    bowbells Formula Junior
    Jan 14, 2008
    353
    Guernsey
    Arthur Dent
    I know of several closed petrol stations, you know back in the day old oil was used to control dust. Maybe if I excavate and strain out the oil, put it in pretty package. How do I figure the viscosity? Could be a money earner, take early retirement (oh, too late for that...)
    B.
  21. Llenroc
    Llenroc F1 Veteran
    5,603
    Colorado
    Vern
    Always good advice, whats going cause more pain to my wallet 100 bucks in Redline a year or 25,000.00 for a rebuilt engine. vern
  22. life@8500
    life@8500 Karting
    233
    Milford,CT
    C Ryan Ramotar
  23. PAP 348
    Dec 10, 2005
    100,249
    Mount Isa, Australia
    Pap
    #48 PAP 348, Feb 2, 2008
  24. Dcup
    Dcup F1 Veteran
    Jan 3, 2005
    8,645
    Between 2 Implants
    Claude Balls
    your a good man, pap
  25. PAP 348
    Dec 10, 2005
    100,249
    Pap
    You're a good man Lamour.........:D:D
