What Oil Are You Using | FerrariChat
Discussion in '308/328' started by Brent328, Apr 10, 2019.
  1. Brent328
    Brent328 Rookie
    Feb 21, 2019
    40
    Brent Neurauter
    Just purchased a 1987 328 GTS and the shop said they changed the oil with Mobil One Synthetic 15W50.
    People have told me this oil is too heavy, whats your guys thoughts?
  2. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,607
    California SF bay area
    Paul
    The question would be who are the people telling you this? Since it is multi-viscosity they are essentially telling you that 15W is too heavy. Are they suggesting 5W?
  3. ragtop1
    ragtop1 F1 Veteran
    5,241
    Ontario
    Larry Warren
    Oh boy. Another oil thread This is what I currently use. However mine is a ‘79 308. Previous threads usually indicate that synthetic oil seeps through seals. The Mobil oil in your car is definitely a heavyweight for synthetic though. There is tons of reading on this topic if you use the search function
  4. syata
    syata Formula Junior
    Feb 23, 2017
    428
  5. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    There should be a plate on the engine bay right rear corner with fluids.
  6. Rifledriver
    37,100
    Oils are not the same as they used to be. Hard as it is to believe there have been technological advancements.
    I use 0-40 or 5-40 in mine and all of my clients cars of that period.
    JohnnyS likes this.
  7. Rifledriver
    37,100
    79 308 has completely different oil needs.
  8. Brent328
    Brent328 Rookie
    Feb 21, 2019
    40
    Brent Neurauter
    Yes the shop I am dealing with said it should be 0W or 5W
  9. Alfer
    Alfer Formula 3
    1,360
    NH/the Netherlands
    Menno
    I use the Original 10W40, see below picture. This is for Euro 328's. Changing oil means changing viscosity that together with additives of full systhetic oils can cause that oil seal rings start sweating. The right viscosity likely also depends on the climate of the part of the world you are. I live in the Netherlands with a mild climate of no hot summers and no too cold winters.
      File size:
      43.5 KB
      188
  10. Portofino
    Portofino Formula Junior
    Sep 17, 2011
    850
    Yorkshire UK / Switzerland/ Antibes France
    Portofino
    5 W 60 , the stuff they put in M series BMW s fully synthetic in a 77 208 engine .
    This is because my techs are M series specialists and do other performance cars .Tech said something about the high rpm s and heat dissipation.
    There isn’t a one size fits all answer , many oils work .
  11. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,810
    Cerritos, CA.
  12. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    Mobil 1 0W40 in my '89 328 since 2008.
  13. pappy.72
    pappy.72 Formula Junior
    Nov 13, 2010
    536
    Elgin, IL
    Dave
  14. moysiuan
    moysiuan F1 Rookie
    4,187
    Canada
    Redline 10W40 for 15 years on my Mondial 3.2. 10w40 per the manual, its a pretty broad viscosity range, should work well unless driving in artic conditions, then 0w40 would do, but might cause leaks. No leaks from my 10w40 synthetic choice.
  15. pappy.72
    Nov 13, 2010
    536
    Elgin, IL
    Dave
    The manual stated 10W-40 because maybe at the time there was no 0W-40. Is that correct?
  16. miketuason
    Feb 24, 2006
    15,810
    Cerritos, CA.
    #17 miketuason, Apr 10, 2019
    Mine stated 10w 50
  17. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,607
    Paul
    It seems that if you assess all of the comments in these threads you’d have to draw the conclusion that it doesn’t matter because they all claim that brand X in XWXX viscosity worked for XX number of years with no problems.You never see a post saying that brand Y leaked like a sieve and destroyed my engine in six months.
    rjlloyd likes this.
  18. nerofer
    nerofer F1 World Champ
    Mar 26, 2011
    12,083
    FRANCE
    I thought that starting another oil thread, or starting another belt change interval thread, was considered as "baiting" and therefore get you banned...:D
    Rgds
    Martin308GTB likes this.
  19. Rifledriver
    37,100
    I know it is really hard to believe but technology has advanced since the mid 80's. Oil today is a very different product.
    miketuason likes this.
  20. Rifledriver
    37,100
    They are good engines and get relatively few miles put on them so most often the ramifications of not using an ideal product can take a very long time to become known.
  21. nerofer
    Mar 26, 2011
    12,083
    FRANCE
    Brian,
    I was wondering (no hidden agenda, just genuinely wondering) if, in matters "oil and Ferrari engines", we do have such examples indeed with enough evidence to say that "this oil has indeed been responsible for this, or that, problem"? (such as bearings, bushings, piston rings, rods etc...) Without naming the brand, of course...but it seems that many top-tier oils from any reputable brand, in the correct viscosity bracket, are indeed doing their job of protecting these engines?
    Rgds
  22. Rifledriver
    37,100
    Well we may have but it would be a small sample. The other problem is I see so many failed engines badly diagnosed and bad information distributed it really muddies the water. The good news is modern name brand oil is really excellent and you can get away with doing a lot of dumb stuff.
    This thread is a great example of the problem. Oil, gasoline and and coolant have all changed dramatically since the cars were built and using what was suggested in 1975 is not what is in your cars best interest in 2019. I spend a lot of time staying on top of the changes in these products and am pretty familiar with the specific needs of these cars and change pretty regularly the products I use to keep my clients cars working and trouble free.
    Gasoline though is a real issue and we can do little about it. Our cars were not designed to run on what we now call gas. That is a situation that will not get better.
  23. JohnnyTS
    JohnnyTS Formula Junior
    Jun 3, 2012
    907
    Pretoria East, RSA
    I also thought this thread will be deleted..
  24. Rifledriver
    37,100
    Another problem we have is the factory change recommendations. They are usually mileage based and do not take into account time. A lot of additive packages have a life span based on the calendar and if it takes you 10 years to put 15,000 miles on your car the gear oil died about 8 years ago, earlier if you live in a humid climate. I live in Austin, far from the most humid place in the US. I have a tester that shows water content in fluids and I can tell you brake fluid and gear oil do not last 2 years here. Imagine being in Miami and doing the same test?
    Antifreeze with the correct additives to protect a wet liner engine until just a couple of years ago was good for 400,000 plus miles.......as long as you did that in 1 year. That additive was dead in less than 2 years.
    None of it matters if you sell the car in a few years. If you plan on keeping them a long time it is a very different story. And when you sell it, just what story is it you want me telling a prospective buyer? I don't care how nice a guy you are, if you didn't take appropriate care of it I'm not lying for you.
