What oil do you use | Page 2 | FerrariChat
What oil do you use
Discussion in 'Technical Q&A' started by dkny, Mar 6, 2007.
  1. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    Thanks Brian,
    With a new pressure sending unit, new oil, filter and 220 F oil temp, would 50 psi at 3000 rpm be adequate, in your experience. I haven't done this yet and would appreciate your thoughts as to what to look for.
    Does Dr Haas's 10 psi (minimum ?), per 1000 rpm make sense to you??
    thanks,
    chris
  2. Rifledriver
    37,310
    That should be fine. The motors are pretty understressed. The pressure has a habit of dropping fast below 3000 though. I think I would want to see at least 10-15lbs or so hot idle. Thats one of the reasons I like Redline, doesnt fall apart hot like some do.
  3. sc67vette
    sc67vette Karting
    Feb 28, 2007
    92
    Dallas, Tx
    Steve
    Castrol syntec European spec. Made in Germany. Lots of additives, ZN, ect. 5-30, but acts more like 5-40. Look for "made in germany" on the back of the bottle.
  4. chrismorse
    Feb 16, 2004
    2,150
    chris morse
    Thanks Brian,
    I will look at the Redline products viscosity and temp performance compared to the Mobile stuff.
    Thanks Steve,
    I will also consider the Syntec German stuff as well.
    chris
  5. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    Guy's do you know all there is to know about oil? No! Is E Hass the know all to end all? No! Every single thread on oil I learn some thing new and this recent link to Oil Engineering was very revealing and presented "New" information. I and others would like to learn more and appreciate every single contribution. I have been studying oil for years and I am still hungry for more. Oil changes yearly with new advances and it may not be important to some but I choose to be able to identify what oils are the best and for what reason. Feel free to yawn with boredom but I choose to hear and hunger for more.
  6. chrismorse
    Feb 16, 2004
    2,150
    chris morse
    Gary,
    I applaud your enthusiasm, I just don't want to melt the motor - now if you want to talk about brakes...
    best,
    chris
  7. f355spider
    f355spider F1 World Champ
    18,058
    Actually it is Castrol Syntec 0w-30. You can only find it at Autozone. It is very popular with the BMW crowd, as it meets most of the current BMW and Mercedes specs. It is a bit "thick" for a 30 weight (as you mention) and is very close to a 40 weight at operating temp. Learn more about it at www.bobistheoilguy.com
    I have used it for a couple years now in my 2001 540 M-Sport.
  8. wetpet
    wetpet F1 World Champ
    10,210
    I use it because it's royal and purple. My name is Prince.
  9. Greg D
    Greg D Guest
    Jul 29, 2006
    145
    Orangevale, CA
    Greg Dills
    I use Castrol Syntec 5-50 and Vavoline Syn Power 20-50 depending what is in the TR at the time. The F shop had synthetic 0-50 in it according to the last oil change paper work. I also use Mobil One 5-20 in the Navigator and am changing the 63' Vette to full synthetic 30 wt. I am glad you asked, made me check the TR. Found a little oil weeping from the front of the cam cover on the pass. side. Checked the torque on the cover nuts. All were needing snugging up about a 1/4 turn and one was loose where the oil leak was. I guess we missed checking final torque on that one fastener. I hope that is all that is needed since the TR had a complete engine out P.M. and all drive train updates current to early 2005 with 3,400 miles. Now I have 8,900 miles.
  10. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,846
    Cerritos, CA.
    AEHaas sugest to use the Castrol Syntec European 0-30 which he said a much better oil for my car so I'm going to try to swith from Amsoil to Castrol on my next oil change.
  11. f355spider
    18,058
    Ow-50 synthetic? I don't believe such a beast exists.
  12. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    As always, excellent post AEHass. Got caught out by the Mobil 1 0W-40 change in formula and think it may have caused some problems... How are we to ever really know when an oil manufacturer changes their formula to be less robust than their same-packaged previous releases?
    Chris, FYI in the 308 here i tried 5W-30 for winter and it is fine provided ambient was below 60F imo. Over 60F the oil was too thin (for my liking) and the pressure was too low (imo). Just trying to help.
    Am right now is the same situation as you, since Mobil changed their furmula and am searching for something else. The info at http://www.lnengineering.com/oil.html seems interesting, maybe Shell Rotella 5W-40 synth would be good? i'm going to give it a go for latespring to fall use even though a 0W oil is personally preferred.
  13. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    For my BB512i, I use Castrol TWS 10w60, which is a full synthetic oil...I have been well pleased.
  14. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    Yes parkerfe Castrol finally has a "real" synthetic oil, all the others have been hydrocracked dino oils. This 10w60 is purported to be a good one with real syn. basestocks. Hooray! long overdue, the rest of their product line are pretenders.
  15. parkerfe
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    It has been out a long time...at least 7 years as it was specified for my 2000 M5 as well as my current 2006 M5...
  16. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    In the day (1931) oil varied a bit. My Studz has an adjustable oil psi system so you can adjust your psi to what you put in.
    In my race boat the oil gets to 325 degrees. I use Mobil One 50W which has worked nicely.
    In my Dusey and Studz I use Rotella 40W which I also use in MK-IV/166/P 3/4/412P and Lola.
    Maser uses Agip 0-40
    P Turbo Mobil One 0-40
    P 4/5 Shell Helix
    So far all is good.
  17. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    Parkerfe, sometimes the word takes time to get out. Have you been using it that long?
