What Oil for a 328? | FerrariChat
What Oil for a 328?
Discussion in '308/328' started by scott1967, Oct 9, 2004.
  1. scott1967
    scott1967 Karting
    Jul 12, 2004
    148
    Tampa, FL
    Scott
    I am about to change oil in my 1986 328 GTS for the first time :). I am curious what oil other owners of 328 use. I have researched the archieves and I am more confused now than ever. I have even sent a PM to Ali Haas, the oil expert, to get his input. I called the shop where the previous owner had it serviced and they indicated that they put Shell Helix 5W 40 in the last oil change. I would prefer not to use this again.
    I leave in MN and will be storing the car in the winter. I do not track the car and mainly drive it on weekends.
    I would appreciate others input regarding the type and weight of oil you use or recommend.
    Thanks.
    Scott
  2. Gatorrari
    Gatorrari F1 World Champ
    16,464
    Georgia
    Jim Pernikoff
    I use Mobil1 15W-50 but Napa has a lower-priced oil of the same viscosity so I may switch to that. The car has been fine, but it's only been 6 months.
  3. Bandit
    Bandit Formula Junior
    Dec 21, 2003
    493
    Central MS
    Mike B.
  4. davem
    davem F1 World Champ
    10,716
    Stepford, Connecticut
    dave m
    Mobil 1 synthetic 5-30. Should be ok year round for your parts. Im assuming you wont be driving much come winter time.
  5. Ron328
    Ron328 F1 Rookie
    2,627
    Willamette Valley, Oregon
    Ron
    Castrol GTX 20w/50
  6. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    A 328 came from the factory with Agip SINT2000 10w50 which is a synthetic oil. Since it is impossible to find a 10w50 oil theses days, I recommend Mobile1 15w50, which is what I use in my Boxer as well. I would never use a 0w oil unless the OM recommends it. And, I would not use anythingthinner than a 50. So, that leaves you with 15w50 or 20w50. Since the 15w is closer to the 10w as recommended by Ferrari, that's what I would use.
  7. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,294
    Colorado
    Dave
    89's came with 10-40. I don't know when the change occurred. With modern oils, 50 weight is considered by many to be too heavy except for high heat (like track) conditions.
    Dave
  8. ASFJr
    ASFJr Formula Junior
    Oct 11, 2004
    499
    SF, CA & NYC, NY
    Alfonso Faustino
    Hi. My mechanic uses Kendall (sp?) 20/50 for my 1988 328 GTS. /s/ Alfonso
  9. scott1967
    scott1967 Karting
    Jul 12, 2004
    148
    Tampa, FL
    Scott
    I changed oil today. I ended up using Castrol GTX 20w/50. Used 9 1/2 quarts to bring it to full with filter replacement.
    So far the oil pressure readings are vertical (85) but a little higher than with the 5w-40 Shell Helix.
    It won't be long until it is put away for the winter, so I have all winter to decide what to use for the spring oil change.
    Scott
  10. Gatorrari
    16,464
    Georgia
    Jim Pernikoff
    Frank, I've been putting the Mobil1 in my 328 as well, but NAPA has their own 15w50 which is 30% less expensive. It is made for them by Ashland Oil. I don't see why it wouldn't work as well, do you?
