WHAT OIL FOR TESTAROSSA? | FerrariChat
Discussion in 'Boxers/TR/M' started by JasonMiller, May 19, 2005.
  1. JasonMiller
    JasonMiller F1 Rookie
    3,649
    Co Springs/ Texas
    Jason Miller
    Any suggestions on the best choice for oil for a 1988 Testarossa? I dont know what the previous owner used ... Is synthetic better for this car?
    Thanks,
    J
  2. Smiles
    Smiles F1 World Champ
    Nov 20, 2003
    16,674
    Pittsburgh, PA
    Matt F
    Why don't Ferrari owners use real castor oil anymore? ;)
  3. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    The TR came from the factory with a synthetic oil from Agip...so I would stay with a synthetic oil. I use Mobile 1 15w50 in the summer and castrol Syntec 5w50 in the winter in my BB512i which has an earlier version of the same engine as a TR.
  4. Prova85
    Prova85 Formula 3
    Nov 13, 2003
    1,996
    So. Shore MA.
    Kenny K
    I've used Redline 20w50 and am using Mobil 1 15w50 right now. I'd stick with a synth if I were you.
    Kenny K.
  5. Tifoso1
    Tifoso1 F1 Rookie
    Nov 18, 2003
    2,603
    Pacific NW
    Anthony C.
    I use Mobil 0W-40 year round. The Boxer 12 can be a little harsh at startup, the 0W synthetic should help in protecting the engine, especially in the colder climates. Since you are in Texas, so this may not be as important to you. The factory does recommend 10W-40 as that was the only ones available from Agip (their F1 sponsor) at the time, so you can see that the 0W-40 is well within and better than the recommended spec. Hope this helps.
  6. parkerfe
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    Was Agip 10w40 what Ferrari recommended for a TR? Agip 10w50 is what Ferrari recommended for the BB512i. I have never had a leak in my Boxer although I have always used synthetic oils...nor in any of my other Ferraris for that matter. FYI, synthetic oils DO NOT cause leaks.
  7. Steve Magnusson
    26,846
    The later TR OMs show:
    Agip
    SINT 2000 SAE 10W40
  8. ASG 86TR
    ASG 86TR Formula 3
    Aug 23, 2001
    1,474
    New Jersey
    Adam G
    I use the Agip Sint2000 also. You will run into probs if you run only synthetic. Too many leaks.
  9. Prova85
    Prova85 Formula 3
    Nov 13, 2003
    1,996
    So. Shore MA.
    Kenny K
    Gotta disagree with that statement. My Tr has been BONE DRY since I've had it with nothing but synthetics.
    Kenny K.
  10. Tifoso1
    Tifoso1 F1 Rookie
    Nov 18, 2003
    2,603
    Pacific NW
    Anthony C.
    Not an oil issue, the engine seals are the problem.
  11. vlamgat
    vlamgat Formula Junior
    Jan 9, 2004
    776
    us M1 0-40 year round. Shell/AGIP is NLA at retail and 0-40 is better than 5-40 for my use.
  12. Rene
    Rene Formula 3
    2,229
    London
    René
    Here in Britain, I have been using Shell 5-40W as recommended by the specialist dealer and service centre which looks after my car (although oddly enough, after a service, they leave a can of Agip in the trunk for my use).
    I note that Shell are beginning to offer 0-40W and it seems that some of you like Mobil oil of a similar weight, so I might try it.
    I have the feeling that TR engines benefit in the long run from the better all-round qualities offered by synthetics. Dr Haas is probably the person to ask why.
  13. steveirl
    steveirl Formula 3
    Dec 29, 2003
    1,163
    ireland
    steve
    When I bought my car it was filled with Castrol synthetic 10w60. I have just finished replacing a leaking cam cover gasket and am about to refill with oil but have doubts about using the same again, not sure what to use?
    steve
  14. JasonMiller
    3,649
    Co Springs/ Texas
    Jason Miller
    Thanks for all the input... I didnt know there was a 0-40 weigh oil...
  15. parkerfe
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    ASG 86TR, FYI Agip Sint 2000 is a synthetic oil, albeit a blend!
