360 - What repairs done lately and how much ? | FerrariChat
360 What repairs done lately and how much ?
Discussion in '360/430' started by RANDY6005, Jul 27, 2019.
  1. RANDY6005
    RANDY6005 Formula 3 Silver Subscribed
    Jan 9, 2017
    2,271
    Jacksonville
    RANDY
    Well I had the passenger door cable come lose you could not open the door from inside. Siren battery died and the LED light not go out while driving.. Brake light switch went bad and wound not shift in to gear. So I found door lock rod clip from Auto Zone 2.99 and a brake light switch from Maserati 25.00 and siren alarm module 74.00 from GM they use for Corvettes all three fixes cost 101.99 if this stuff was repaired at a dealer what do you think it would have costed me ?? Here is some pics of the stuff that was repaired hope this helps other 360 owners
    brookliner7, KC360 FL and tifosi101 like this.
  2. RANDY6005
    Jan 9, 2017
    2,271
    Jacksonville
    RANDY
  3. RANDY6005
    Jan 9, 2017
    2,271
    Jacksonville
    RANDY
  4. RedNeck
    RedNeck F1 World Champ Silver Subscribed
    Jul 8, 2016
    12,323
    The CSA
    Me
    4 digits easy. Ferrari service is one of the most successful and profitable scams in history.
  5. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,948
    Melbourne Florida
    KGC
    good on ya, bro. I have a shop with a lathe, milling machine, and a whole lot more. So, yeah, I'm also always saying to myself; "I bet I can fix that and make it even better."
  6. Dbacr
    Dbacr Karting Rossa Subscribed
    Jul 1, 2015
    234
    Ft lauderdale, FL
    Dan
    Apparently the GM siren is NLA. I can’t find it anywhere.
  7. UrbanHero
    UrbanHero Rookie
    Apr 18, 2019
    37
    New York Pothole City
    M
    RANDY6005 likes this.
  8. RANDY6005
    Jan 9, 2017
    2,271
    Jacksonville
    RANDY
    hey Dbacr I looked for a year to a friend of mind found it so I will ask him where he found it
    Dbacr likes this.
  9. Turbotuner20v
    Turbotuner20v Formula Junior
    Mar 18, 2014
    362
    Clutch
    Slave cylinder/throw out bearing
    Clutch position sensor
    Rear main seal
    Oil/water pump
    Variator solenoids
    Valve cover gaskets
    F1 actuator hoses + fluid
    F1 bleeder block
    Fuel pump
    Thermal probe
    Engine mounts
    Front lower ball joints
    Grease CV joints and replace clamps
    Accessory belt
    Annual fluid service (oil, trans, diff, coolant, brake)
    ~$20,0000
    RANDY6005 and UrbanHero like this.
  10. basscase415
    basscase415 Karting
    Jun 10, 2017
    87
    CA
    Last year I spent $1500 in what proved to be pointless labor at a reputable local indie chasing a slow coolant leak. The problem persisted until I did research on here and tried a replacement coolant cap.
    So that's fixed, but after this and a couple of more-minor issues with this indie I'm concerned about "wallet leak". They have glowing reviews here and online, so I'm wondering if I'd really be any better off elsewhere.
  11. shad99
    shad99 Formula Junior
    Dec 12, 2013
    300
    Japatul Valley, CA
    Andy
  12. shad99
    Dec 12, 2013
    300
    Japatul Valley, CA
    Andy
    Small leak on water pump. Probably could have lived with it but doing timing belts and fluid changes, so... $800.00.
    ($525 pump, $275 labor)
  13. vrsurgeon
    vrsurgeon F1 World Champ Silver Subscribed
    Dec 13, 2009
    16,540
    Charleston, SC
    Curt
    Repainted my disareator with black crinkle pain a couple weekends ago. $10 in paint.
  14. Apollo 11
    Apollo 11 Karting
    Feb 11, 2019
    114
    San Francisco, CA
    Randy
    During my first annual service, they found the motor mounts were failing. Replacement cost $950 at my local Indi shop.
    The annual service (brake fluid, oil change, coolant change, F1 oil change) cost $737.
