What seats will fit in a 348? | FerrariChat
Discussion in '348/355' started by drftfan, Dec 26, 2012.
  1. drftfan
    drftfan Formula Junior
    Jan 12, 2011
    357
    Orange County
    Jamie
    I want to swap the seats out in the 348tb I have. Any ideas as to what will fit?
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,714
    South East
    Jimmie
    Most racing seats can be made to fit but it depends what you are aiming for
    This feels like a question that has been asked and answered before so its probably worth a look
  3. mad dog
    mad dog Formula Junior
    Jan 5, 2006
    875
    suffolk uk
    andrew
    I had a problem with my race seats and size. The basic bolt holes underneath should fit the runners from your standard seats but I found that was then too high for me. I have since fitted race seats in 348 and 355 with side mounts and new reinforced mountings which means I loose the adjustment but get a better fit and stronger mounts for harness and seat.
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,674
    San Carlos, CA
    Mitchell Le
    I asked the same question with very few answers. The problems are several:
    1. The mounting holes for the 348/355 are two vertical in the back, and two horizontal in the front. There is no standard mounting brackets that offer that pattern.
    2. The area where the driver seat (US) fits can only take up to 20 inch width because of the handbrake. That also limits the number of seats that will fit.
    The result is that some level of customization and fabrication will be required. Unless you find a set of racing seat from the 348 Serie Speciale, nothing will drop in.
  5. drftfan
    Jan 12, 2011
    357
    Orange County
    Jamie
    That's what I figured Both seats I was looking at wont fit... Barely. Good thing I didn't buy them.
  6. mad dog
    Jan 5, 2006
    875
    suffolk uk
    andrew
    I think you'll find the mounting holes you mention are on the seat runners not the seats themselves, these are in turn bolted to the underside of the seats in same places as race seats which here usually have underseat and side mount bolt holes. I reckon if under say 5' 10" and dont use helmets any time may get away with it, you just need to be careful with the rake.
    What I was always unhappy about was the small diameter of these runner fitting bolts, especially when you think the rear seat belt mounts are direct into the seat, uk models anyway. So a standard much larger seat belt bolt relying on a much smaller runner bolt for the starin on both belt and seat when in accident. I presume they had to go through crash testing at some point, but just doesnt seem up to job in my mind.
