What should Oil Pressure be for newly built 2 Valve Engine using SAE 30 Mineral Oil? | FerrariChat
Discussion in '308/328' started by ItalianProjects101, Sep 10, 2024.
  1. ItalianProjects101
    ItalianProjects101 Karting
    Feb 5, 2023
    215
    D
    Hi everyone,
    I'm currently running SAE 30 Millers MINERAL Running-In Oil Classic in my Ferrari 308 2-valve and I'm curious about what type of oil pressure I should be expecting. The engine has just been rebuilt, but I want to make sure everything is within the normal range.
    I intend to run this engine on this oil for around 100 miles, than switch to 20W-50.
    Currently I'm seeing around 105-110 PSI at around 2000-3000 RPM based on a mechanical gauge.
    What oil pressure readings should I be seeing at idle, under load, and at higher RPMs with this particular oil?
    Thanks in advance for your help!
  2. Albert-LP
    Albert-LP F1 Veteran Owner Rossa Subscribed
    Sep 1, 2010
    8,166
    around Modena, Italy
    Alberto Mantovani
    Pleae use another oil! use a 5W-40 full synth, or something like that
    Pressure is about 6 bar at 3000 RPM when the engine has fully warmed up
    Ciao
  3. ItalianProjects101
    Feb 5, 2023
    215
    D
    The oil I'm using is specifically there to help bed in the piston rings, you think it is too thick?
  4. bitsobrits
    bitsobrits Formula Junior Rossa Subscribed Silver Subscribed
    Nov 12, 2011
    740
    Omaha, NE area, US
    Steve
    Don't second guess yourself. Pretty much any mineral oil is fine for a short break-in period. What's more important is to vary the load (from low to moderate) during the break-in and not give it max revs or max load.
  5. ItalianProjects101
    Feb 5, 2023
    215
    D
    Definitely intend to run it in correctly, I was just wondering since I saw the oil pressure a tad high, so looks totally ok?
  6. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,729
    The twilight zone
    It looks fine for cold, straight weights are pretty high pressure cold.
  7. bitsobrits
    Nov 12, 2011
    740
    Omaha, NE area, US
    Steve
    If that is fully hot oil pressure (and fully hot numbers are the most meaningful), it's definitely higher than my car which runs a couple needle widths past 85 on the factory gauge at 3000, but then my car is about to roll over 40k miles. When first started from cold, and at a 1200 rpm warm up idle, my gauge is just under the hash mark between 85 and 170psi, so about 125 psi.
    Seems to me your numbers are reasonable for a fresh engine.
  8. Albert-LP
    Sep 1, 2010
    8,166
    Alberto Mantovani
    everything works, with a new engine, but why not a standard oil: at cold start the SAE30 is a disaster, wearing a lot camshafts lobes and crankcase bearings. And use a 5W-40 as next oil: why do you want to use a 20W-50 oil when today there is the twenty times better 5W-50? 5W-40 is the best balance oil for a 308, or some modern oil like that: 308 engine is a modern engine, does not require any old oil to work well.
    Ciao
    tomberlin and smg2 like this.
  9. smg2
    smg2 F1 World Champ Sponsor
    Apr 1, 2004
    16,322
    Dumpster Fire #31
    SMG
    Our go-to break in oil is RotellaT, loaded with all the good minerals and vitamin support a new engine needs.
    After that, I really like the liqu-moly line up, they've got a great oil for classic engines with solid lifters. MoS2 semi-synthetic.
    tomberlin and Ferraripilot like this.
  10. miketuason
    miketuason F1 World Champ Owner Silver Subscribed
    Feb 24, 2006
    15,808
    Cerritos, CA.
    do they still offers Motor Oil with detergent specially for during break-in period?
  11. Ferraripilot
    Ferraripilot F1 World Champ Owner Project Master
    May 10, 2006
    17,846
    Atlanta
    John!
    You may not even need to run it for 100 miles. Piston rings bed-in a lot quicker than you think. 15-20 minutes of low-key driving or highway cruising (if that) and they're set.
  12. johnk...
    johnk... F1 World Champ Owner
    Jun 11, 2004
    11,219
    CT
    John Kreskovsky
    Originally QVs were to run 1200 with the factory oil, then bring it to the dealer for a change.
    Jbrauer likes this.
  13. 308 GTSi
    308 GTSi Rookie
    Jul 12, 2013
    29
    Rochester,Mn
    according to my shop manual, under normal working conditions, oil pressure should between 5.5 and 6.5 bars, the engine running at 6000 rpms and oil temp at 100c. When the engine is still hot and runs at idle, a pressure below 4.5 has to be considered normal.
  14. Freddie328
    Freddie328 Formula Junior
    Jul 29, 2013
    389
    Herts, UK
    Richard
    Wow, those pressures are quite a bit higher than mine. Warm at 3000 rpm, mine runs about half a needle width below the 85 psi mark. Cold on idle at 1000 RPM about a needle width below the 85 psi mark. The latter drops quite a bit when engine oil is warm. I think Ferrari made a mod to reduce oil pressure on later cars by changing the PRV and flexible oil lines. Mines a late 328, so perhaps that why.
  15. Dr Tommy Cosgrove
    Dr Tommy Cosgrove Three Time F1 World Champ Owner Rossa Subscribed
    May 4, 2001
    36,425
    Birmingham, AL
    Tommy
    What exactly is the real world practical difference between a 0W - something and a 5W - something motor oil?
  16. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,729
    The twilight zone
    In a 308? None unless you live in Alaska maybe. For most of us it's the second number you'll care about, depending how hot it is where you drive and how hard you drive. A 30 might be fine or a 50 not enough....specific to use.
    .....but should really apply to break-in
    tomberlin likes this.
  17. ItalianProjects101
    Feb 5, 2023
    215
    D
    Whilst I have you all guys here, I read other threads but wanted to confirm, how long is it normal for the oil pressure light to go off and oil pressure to start climbing when the engine is cold? Mine takes a solid 3-4 seconds by turning engine with only starter motor, no ignition or fuel, engine is currently out.
    I have the UFI oil filter 23 162 02
  18. Freddie328
    Jul 29, 2013
    389
    Herts, UK
    Richard
    Depends on how long you left it since the last start. The oil filter NRV flap will eventually allow the filter to empty out into the sump. Takes a few days for this happen.
    With mine, if engine had been started for the first time in a while, was up to oil pressure then stopped and restarted; Mine could take a similar time to yours on the first start and then give immediate pressure on the second start.
