What size stat o seal or dowty for 328 oil plug | FerrariChat
Discussion in 'Technical Q&A' started by dhs-9, Apr 24, 2004.
  1. dhs-9
    dhs-9 Formula Junior
    Feb 6, 2004
    292
    I have read that many have used the stat o seal or dowty washers. I would like to know which is better for an oil drain plug washer and which size should be used for the 328 oil drain plug washer. I just changed the oil and used a ferrari copper washer and I am getting a slow leak. I suspect the sealing surface of the pan is not perfectly flush. would this type of waser stop the leak. Thanks for your help
  2. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    For your oil drail plug, I would install a new copper washer.
