What "special" tools are needed for Birdman's belt change on 86 Mondial? | FerrariChat
Discussion in 'Mondial' started by teambft, Dec 30, 2013.
  1. teambft
    teambft Rookie
    Nov 28, 2013
    26
    Brentwood, TN
    What do I need? Bearing tool, stud puller, odd socket sizes? Thanks for advice.
  2. TheMac
    TheMac Formula Junior
    Sep 5, 2009
    452
    Alberta
    Jon Mac
    If I recall correctly, the only really odd socket size was 36mm, for the crank pulley nut. I didn't use a stud puller, I used the double nut technique to pull the studs. That worked fine. I did not use a bearing tool. If you are not degreeing the cams to set the timing, you will need cam locks. I purchased a fancy cam lock tool, only to discover that it did not fit on the 3.2 cam pulleys. I rigged up a different cam lock tool, much like the one birdman has in the tutorial (two wedges of wood with a stud, nuts top & bottom to generate tension and keep the cams in one spot).
