What steering wheel fits? | FerrariChat
Discussion in '348/355' started by Sonnythebull, Feb 16, 2025.
  1. Sonnythebull
    Sonnythebull Karting
    Nov 6, 2024
    78
    Sonny Dabull
    I know there’s a model of Momo or other steering wheel that bolts right in to the 348. I want to change my steering wheel to Alcantara and keep the stock one. What size and model steering wheel in alcantara bolts right in? Thanks!
  2. ChoonHound
    ChoonHound Formula 3
    2,221
    Saint Michaels, MD
    Lucas
    I believe the momo bolt pattern is consistent so I’d imagine any model will? There’s a dude on here who’s an expert. Let me see if I can find his username.
    Sonnythebull likes this.
  3. michaelz
    michaelz Karting
    Jul 7, 2017
    79
    Melbourne Australia
    MOMO has always used 6x70mm bolt pattern.
    Basically you could use anything with 6x70mm regardless of brand.
    IvanRico, 308 GTB and Sonnythebull like this.
  4. Sonnythebull
    Nov 6, 2024
    78
    Sonny Dabull
  5. IvanRico
    IvanRico Karting
    197
    Westchester NY
    Ivan Rico
    Don't forget to get a resistor for faking the presence of the airbag, else you'll get a airbag light that only a dealer or someone with Ferrari diagnostics equipment can reset.
    I got a kit like this which included the wheel, hub, horn button and resistor: https://www.ebay.com/itm/315728686168
    Alternatively you can just get a kit like this - you want a 3.3 ohm resistor. I used the kit for the passenger airbag fakery: https://www.amazon.com/gp/product/B08FHPJ5G8
    308 GTB likes this.
  6. 308 GTB
    308 GTB F1 World Champ
    11,717
    New Jersey
    Barry Wolinsky
    momo, OMP, Sparco...take your pick of 6x70mm bolt pattern Alcantara steering wheels in the diameter and dish you prefer.
    Order from a reputable dealer. Stay away from eBay...
    :D
  7. Sonnythebull
    Nov 6, 2024
    78
    Sonny Dabull
    #7 Sonnythebull, Feb 16, 2025
    348 has no airbags
    Auraraptor, ChoonHound and IvanRico like this.
  8. 308 GTB
    11,717
    New Jersey
    Barry Wolinsky
    Right, Sonny. You might be able to fit your OEM Ferrari horn button in the steering wheel you purchase.
  9. IvanRico
    IvanRico Karting
    197
    Westchester NY
    Ivan Rico
    #9 IvanRico, Feb 16, 2025
    Ha - I missed that you had a 348. Carry on. :)
    308 GTB likes this.
  10. 308 GTB
    11,717
    New Jersey
    Barry Wolinsky
    It's still good advice for F355 owners, Ivan. :)
    Our F355 Challenge cars had their airbags removed so it's no longer a factor in the choice of steering wheels. The F355 Challenge Technical Regulations Manual permits the driver's choice of steering wheels.
    This OMP wheel came in the Challenge kit for my car...
    Peter Sachs preferred using this momo wheel...
    ...which he kindly autographed for me a few years ago...
    He attached his push-to-talk radio switch to the wheel with Velcro. I replaced his momo wheel with this momo Competition wheel...
    I didn't mind drilling a hole in it for my push-to-talk switch.
    Sonny, please forgive my digression here. But I've illustrated a few wheels which you might like.
    Note how the original OEM horn button fit my current wheel. It's non-functional as my wheel has a quick release hub. The silver ring you see behind it is a 1cm spacer.
    IvanRico likes this.
  11. 348SPIDERMAN
    348SPIDERMAN Karting
    May 12, 2022
    53
    Canada
    ANGELO ALBANESE
    Hill engineering has a 25mm wheel spacer that I would recommend , tired of having. your fingernails hitting the dash? this solved my problem, and it looks good.
  12. 308 GTB
    11,717
    New Jersey
    Barry Wolinsky
    Ivan's F355 Challenge should have a mandated quick release hub as my car has...
    ...in which case a 25mm spacer might be a bit to wide.
    I had a custom 1cm spacer machined to put my steering wheel at the optimum distance for me...
  13. IvanRico
    IvanRico Karting
    197
    Westchester NY
    Ivan Rico
    It does have a quick release wheel, at least according to the posts. I haven't yet had a chance to see it in person as I had it sent directly to Pocono Sportscar since 11 years without a documented timing belt change seemed like long enough to me.
    Lots of little and not so little items to sort out. Example: Shame on me for not doing a full PPI but I didn't expect the power steering pump to be missing and replaced with an electric unit that was never fully installed. No wonder in the video the driver was doing the hand shuffle instead of hand over hand with what was basically manual steering.
    308 GTB likes this.
  14. 308 GTB
    11,717
    New Jersey
    Barry Wolinsky
    Ivan,
    Looking at the pictures still available on the auction website, it does indeed have the mandated quick release hub. They were made by several manufacturers in different configurations.
    The steering wheel is typical of the suede momo wheels used when the car competed.
    Your rear clutch housing was drilled as shown in the regulation manual. The clutch cooler would complete the Challenge set-up.
    Your car is in good hands at Pocono Sportscar.
    Barry
  15. ShineKen
    ShineKen F1 World Champ
    19,892
    Southern California
    Nostradamus
    I noticed the suspension actuators were missing as well implying it is probably running a fixed setting setup. I would check the passenger foot compartment to see if a challenge Bilstein damper ECU is still there.
  16. IvanRico
    IvanRico Karting
    197
    Westchester NY
    Ivan Rico
    I'm planning on taking advantage of Barry's experience with his Challenge car and duplicating his Penske setup described here: https://www.ferrarichat.com/forum/posts/149100738/
    Indeed though I will check if the ECU is there and store it along with the dampers for the future and/or next owner. I am more focused on performance on track than originality currently.
    308 GTB likes this.
