What the unexpected cost of running my 355 for 6 years have been | FerrariChat
Discussion in '348/355' started by johnk..., Sep 21, 2018.
  1. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,267
    CT
    John Kreskovsky
    I though I would sit down and add up the unexpected costs of keeping my 355 running since I got it, 6 driving seasons ago. I am not including routine maintenance like annual oil changes which run me about $100 for oil and filter, that I put a new set of tires on it, or some of the little things I've done which were unnecessary to keep it running right. These include things like a new leather strap to hold the tool kit in the trunk, the motor for the recirculation flap, some material I bought to make skid plates, and a few other little things, none of which were required for safety or proper running.
    So here it is:
    That's what it would have been necessary to spend to keep the car running correctly. And I think the 5-8 O2 sensor was unnecessary but I replaced it along with the MAF just to be sure. An annual average of $328, less than the annual cost of gas for the car. I have a major coming up in a year or two or three, but that's a separate issue.
    BrianNYC14 and Yassa like this.
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Good post, John but you are light on this estimate ;)
    And, I agree - my car has cost me more for insurance than to run it.
    BrianNYC14 and taz355 like this.
  3. fdekeu
    fdekeu Formula Junior
    632
    Belzium
    Frank
    So 10yrs between majors?
  4. jjtjr
    jjtjr Formula Junior
    Aug 29, 2016
    762
    Vermont
    john truskowski
    Or 10,000 miles. Whichever comes first;)
    RandyT likes this.
  5. johnk...
    Jun 11, 2004
    11,267
    CT
    John Kreskovsky
    Want to see the receipts? $37 for the filter, a couple of buck for copper washers, and about $60 for the oil and then I but the oil when they had a rebate of $10/5quatrs. So, yes, under $100 for a DIY oil change. And no, I don't change gear oil every 2 years because it's a Ferrari. But if I did it would only push the cost to about $120.
  6. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    #6 Dave rocks, Sep 21, 2018
    Oil is $85ish for 9 quarts ;)
  7. johnk...
    Jun 11, 2004
    11,267
    CT
    John Kreskovsky
    First major was after 7 years at 9808 miles, 2002, Ferrari of Dallas. 2nd major in 2006 at 14389 by Boardwalk Ferrari. That's 4 years. 3d major at 19200 miles in 2103, with hears by Steve Maxwell, another 7 years. I can't see doing it any sooner that 7yrs/15k miles unless something I can't fix breaks. Not to mention I don't track my car, I seldom have it over 5000 rpm, and I'm not paranoid.
  8. johnk...
    Jun 11, 2004
    11,267
    CT
    John Kreskovsky
    Where and what you buy.:)
    I use what was recommended to me, Rotella 5w/40 full synthetic. 10 quarts for$58 less $20 rebate,$38. And if you are willing to go to 0w/40 you can get the Pennzoil Platinum Euro after rebate for $18 for a 5 quart container. Just bought two 5 quart containers in for $56, less $20 rebate in May for by Cayman.. That's what Porsche recommends. Check the viscosity of the 0/40 compared to 5/40 and you will find the only temperature it is lower is at 40*C, and at that temp it is still a lot higher viscosity that at operating temps. Comparing the Pennzoil 0/40 to 5/40 both are recommended by MB, VW, Porsche and Fiat under the same specs. But only 5/40 is recommended by Ferrari and Maserati (because they want the little horse on the bottle?). When you compare the specs of the oil, they are almost identical except of the viscosity at 40*C, 5/40, 80.8cSt, 0/40 72.2 cSt. At 100*C 5/40 is 13.3, 0/40 is 13.0. I see no reason Pennzoil 0w/30 could not be used in a 355.
  9. johnk...
    Jun 11, 2004
    11,267
    CT
    John Kreskovsky
    Obvious typo. Should be 0w/40.
  10. phrogs
    phrogs F1 Veteran
    7,352
    Kzoo Michigan
    Yep, my tags and insurance have cost me the most. I hate Michigan for this reason.
  11. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    It nice to see a post where someone does not calculate depreciation, tires, insurance, gas, brakes, service, opportunity cost of needing another car to prevent miles on the ferrari, cost of portion of the house for storage, cost to detail, cost of octane booster, cost to redo the seats etc etc and claiming 15K a year to drive.
    Frankly if you play the depreciation game a bmw will cost WAY more my 348 was 110K new and is worth 70K 30 years later, bmw's 4 series shed 40K off the price in 4 years. Over the life of the car they likely cost less than 100K range rovers you cant give away 20 years later.
    Anyhow nice post. I get annoyed at the I am so amazing it costs me 30K a year to run my ferrari so don't buy one cause you cant afford it type posts. :rolleyes:
  12. johnk...
    Jun 11, 2004
    11,267
    CT
    John Kreskovsky
    To get right down to it I probably could have omitted the cats because I knew when I bought the car one of the original cats was hollow and it might not pass a sniff test. So that could reasonably have been considered part of the purchase price. Also, the ignition module was replaced because I was loosing 1-4 intermittently. Turned out to be a broken wire to the crank sensor so I really didn't need the module.
    I also hate the guys who report excessive costs for majors only to find out that it includes stuff like tires, battery, brake pads, repainting the bumper, refinishing sticky parts, new dash leather etc. Next thing you know you'll see a nut and bolt restoration (see Bradan thread) referred to as a major. :)
  13. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Well, sorting costs are relevant, John. Regardless, these cars cost far less to run than most think.
    Yassa and Robb like this.
  14. fdekeu
    632
    Belzium
    Frank
    My last major was 2005, only 7500kms according to the PO
    Just back from Spa Francorchamps F1 track last Monday
    Those belts are bulletproof
    I'm not paranoid either
    BrianNYC14 likes this.
  15. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,273
    MA
    Belts are bulletproof. Cam drive bearings and tensioner bearings are not!
    I agree with John regarding service intervals. My drive style is similar. 5~7 years for a major. Fluids I do yearly.
  16. Cauf61
    Cauf61 Formula Junior
    Jul 12, 2016
    557
    Belgium
    Patrick
    I replaced my tensioners with Hill Engineering ones last winter. This is for me the critical part.
    A belt last very very long. In VW GOLF GTD diesels (i know they don't rev 7500rpm !) they last 110.000 km's !!
    Yassa and Pangea like this.
  17. fatbillybob
    Aug 10, 2002
    29,151
    socal
    0.04 cents/mile! So everyone should drive a 355 economy Ferrari instead of a Yaris!
    Yassa likes this.
  18. AceMaster
    Feb 6, 2009
    34,778
    Ontario, Canada
    How many miles have you on it?
  19. johnk...
    Jun 11, 2004
    11,267
    CT
    John Kreskovsky
    Assuming that question is directed tome, going on 28k miles.
  20. AceMaster
    Feb 6, 2009
    34,778
    Ontario, Canada
    It was.
    Providing cost over 6 years without disclosing the amount if miles racked up is pointless....ie I can list cost of ownership over 10 years at $0 yet only drive 100 miles (10 miles per year)....that's a crappy hypothetical but I'm sure you get what I mean.
  21. johnk...
    Jun 11, 2004
    11,267
    CT
    John Kreskovsky
    Agreed. But look a little closer. It say right in my little chart, in bold red type, that it is over 6 years and 8000 miles. :)
  22. AceMaster
    Feb 6, 2009
    34,778
    Ontario, Canada
    My bad ;)
  23. AceMaster
    Feb 6, 2009
    34,778
    Ontario, Canada
    If you take away the cats, it cost virtually nothing....but then again if the Queen had balls she'd be the King lol
  24. tbakowsky
    Sep 18, 2002
    20,011
    The Cold North
    Tom
    #24 tbakowsky, Sep 23, 2018
    So you have had the car for 6 years, but have only put 8k miles on it. That is 1300 miles per year. I walk further then that per year. That is less then 2 oil changes of you follow the book by milage not time.
    Let's look at this another way. Your car has cost you almost $2000 between oil changes. That's a lot of money.
  25. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I've had mine the same number of seasons and have done 5500. So what? I have more than 1 car to enjoy. :)
    INTMD8 likes this.
