What to look for in a Scud when purchasing? | FerrariChat
Discussion in '360/430' started by FazTaz, Aug 14, 2016.
  1. FazTaz
    FazTaz Karting
    Aug 19, 2004
    107
    Northern NJ
    I am in the market for a Scud. Anything I should be looking out for? All the 08s I've looked at have the carbon package. As far as depreciation any significant benefits regarding an 09 purchase vs an 08 with carbon package?
    Most have under 20k miles with 80+% clutch remaining and have no more than 3 prior owners. Most have the headlight haze and peeling of black paint around the hinges. Are there any major recalls or issues I should be aware of (ie similar to MKI header issues with the 430).
  2. raider1968
    raider1968 F1 Rookie
    Mar 13, 2008
    4,966
    NC Mnts & Asheville
    John E
    Peeling around the hinges is nothing - easily touched up - none issue - i Have a 2008 with no haze on head lights - check for discolor of CF in engine compartment - can be fixed for about $6K - I think 75 % on clutch and brakes might be more realistic
  3. FazTaz
    FazTaz Karting
    Aug 19, 2004
    107
    Northern NJ
    Raider thanks for the tip, why so expensive for discoloration repair? Does it just need to be wet sanded and/or buffed or does a new clear coat need to be applied?
  4. raider1968
    Mar 13, 2008
    4,966
    NC Mnts & Asheville
    John E
    When I got a white haze on the two side panels down low, I sent all the carbon parts to Mc Carbon in CA - (all the parts not just the discolored ones) did not do the work myself - they refinished them all and put thermal barriers on the sides underneath - should have been done at factory - no problems since - so I had to pay for shipping and the work - unfortunately I cannot turn a wrench - but fortunately i have a new son in law who can - my daughter says she married her track support - I believe at the time it was around $5,500
  5. raider1968
    Mar 13, 2008
    4,966
    NC Mnts & Asheville
    John E
    #5 raider1968, Aug 14, 2016
  6. raider1968
    Mar 13, 2008
    4,966
    NC Mnts & Asheville
    John E
  7. dmark1
    dmark1 F1 World Champ
    BANNED Owner
    Feb 26, 2008
    11,439
    Americas Team Headquarters
    Mark
    a good price ;)
  8. Spdrcrj
    Spdrcrj Formula 3
    1,101
    Jim
    Look at the bottom of the rear diffuser for damage to the fins and bottom edges of the outside parts. I've bought two Scuds with the damage. Found the damage prior to the latest purchase and had the repair thrown in for free. Apparently, this is common.
    I think you've hit the rest (cracked headers, hazing headlights, and dis colored carbon engine bay panels).
  9. FazTaz
    FazTaz Karting
    Aug 19, 2004
    107
    Northern NJ
    Thanks guys for all the help. Raider beautiful car. Definitely looks like you have been enjoying it. Still waiting on pics of the engine bay =P
  10. FazTaz
    FazTaz Karting
    Aug 19, 2004
    107
    Northern NJ
    Spdrcrj are the headers prone to cracking similar to the regular 430. From what I understand there are no precats, hence less likelihood of failing.
  11. Spdrcrj
    Spdrcrj Formula 3
    1,101
    Jim
    #11 Spdrcrj, Aug 15, 2016
  12. raider1968
    Mar 13, 2008
    4,966
    NC Mnts & Asheville
    John E
    Looks just like mine so don't need a picture - I have no heard of headers cracking on a Scud - had it happen on my 430 - was replaced under warranty
  13. FazTaz
    FazTaz Karting
    Aug 19, 2004
    107
    Northern NJ
    Work of art. Thanks again guys for all the insightful info.
  14. koop
    koop Formula Junior
    Apr 30, 2011
    811
    Headers are not an issue on the scud. The biggest items are the engine carbon panels and the hazing of the carbon headlights.
    The previous owner of my scud had the carbon panels replaced under warranty and they seem to be holding up just fine now. My car also has an aftermarket exhaust with heat blankets on the headers/cats which helps to keep engine bay heat to a minimum (the source of discoloration on the carbon).
    I had a body shop open up my headlights, clean out the inside and reseal. Almost a year later, they still look like new. Much cheaper than buying a new set which will probably haze again anyway.
    I've owned my scud for almost a year and so far it has been very reliable and extremely enjoyable. Good luck with your search!
  15. riverflyer
    riverflyer F1 Rookie
    Nov 26, 2003
    3,583
    Mendocino, Ca
    Koop,
    Do you know how they cleaned them out? Or could you supply the body shop name?
    thanks, John
  16. koop
    koop Formula Junior
    Apr 30, 2011
    811
    #16 koop, Aug 15, 2016
    Basically they cut open the seal, polished out the inside of the lens and then resealed with some kind of silicone.
    The shop I used said they'd rather not do the job again since there is risk in cracking the lens. But if you're ok with shipping out the lights to someone, these guys are probably better equipped:
    05-09 Ferrari F430 — Headlight Restoration Service
  17. dwe8922
    dwe8922 Formula Junior
    Feb 27, 2004
    403
    FL
    David
    Mine has hazing of the lights, and they were replaced years ago under warranty. Also, the engine bay carbon was refinished ( the sides), but the hazing has started to come back. I've kind of learned to live with it. Those are the only things I've really had.
  18. freshmeat
    freshmeat F1 Veteran
    Aug 30, 2011
    7,284
    hazing headlights is a chronic issue, at least for the carbon version. 08s with non-carbon headlights don't have this hazing issue.
  19. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    Get a ppi from a reputable independent - they will know what to look for!
  20. Shark01
    Shark01 F1 Veteran
    Jun 25, 2005
    6,481
    First thing to do is congratulate yourself for getting far enough along in life to be able to buy such an icon.
    Then have fun looking!
  21. Rcktrod
    Rcktrod F1 Rookie
    Dec 21, 2010
    3,946
    Agree with the PPI.
  22. riverflyer
    Nov 26, 2003
    3,583
    Mendocino, Ca
    thanks for the info Koop, much appreciated
