what to use for brake res to master cyl | FerrariChat
Discussion in 'Technical Q&A' started by Pantdino, Oct 22, 2006.
  1. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    On my 246GT I used fuel hose to replace the approx 6" rubber lines from the brake reservoirs to the master cylinder. Now several years later they are obviously being weakened from within by the brake fluid.
    Does anyone have a source of brake fluid-resistant 1/4" ID rubber hose?
  2. PAP 348
    Dec 10, 2005
    100,228
    Mount Isa, Australia
    Pap
    You sure it lasted you 6 years? I would of have thought the brake fluid would of have softened and rotted that hose within 6 months :confused:
    I would ring around and find a automotive brake repair shop or supplier and buy the correct hose for the job this time, brake circuits are the last thing people should be bodgying up with the wrong parts ;)
  3. Dodici Cilindri
    Dodici Cilindri Formula Junior
    Feb 21, 2006
    548
    Great Plains
    Check with the Volkswagen people. At one time Volkswagen used remote brake fluid resevoirs and there was a special hose just for that application.
  4. Jeff Pintler
    Jeff Pintler Formula Junior
    Jul 20, 2005
    537
    Richland
    Jeff Pintler
    Another source for the hose is Porsche....they have a remote brake resovior in the 911's. It's like a silicone hose and cloth covered but blueish purple. Worked great in my car about two years.
    Jeff Pintler
    89 348tb, 86 TR
  5. Motob
    Motob Formula 3
    Nov 11, 2003
    2,389
    Frederick, Maryland
    Brian Brown
    While the VW/BMW blue hose will work, it doesn't look right in a Ferrari.
    You can get the correct black brake fluid hose from McMaster Carr http://www.mcmaster.com/, just make sure that it is EPDM hose. Do not use fuel hose as this will sweat brake fluid over time.
    Brian
