Buy
what tool for a 360 oil change?
Discussion in 'Technical Q&A' started by paulie_b, May 10, 2004.
  1. paulie_b
    paulie_b F1 Veteran
    Jan 13, 2003
    6,816
    Jupiter, FL
    Paul Bianco
    does anyone know the size tool that is used for the motor oil drain plug on a 360? there are 2 plugs to drain from and both are different sizes. I have done it before but the person I borrowed the tools from is not around anymore.
    thanks in advance.
  3. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    12mm for engine sump. 14mm for oil tank drain.
    Measure what you take out, and fill it back up with a bit less initially. It's so very common for the 360's to be overfilled, causing the inlet system to be filled by the breathers........
    Finalise the level with oil temp at 80 degrees centigrade. Check it within 30 seconds of switching off the engine.
  4. mw575
    mw575 F1 Rookie
    May 30, 2001
    2,924
    Lake Oswego,Or
    Martin J Weiner,M.D.
    Make sure you do not overfill otherwise you will lay quite a smoke screen.
  5. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    I know of a couple that have hydraulic locked and bent conrods......not good
  6. paulie_b
    paulie_b F1 Veteran
    Jan 13, 2003
    6,816
    Jupiter, FL
    Paul Bianco
    thanks for your help. is there a name for the type of tool I need?
  8. Ferrari_tech
    Ferrari_tech Formula 3
    Jul 28, 2003
    1,527
    Malcolm W
    Allen key wrenches
    MW
  9. paulie_b
    paulie_b F1 Veteran
    Jan 13, 2003
    6,816
    Jupiter, FL
    Paul Bianco
    Malcolm, can you confirm that the 2 correct sizes are 12mm and 14mm? Thank you.
  10. Ferrari_tech
    Jul 28, 2003
    1,527
    Malcolm W
    Paul,
    ferrarifixer is right sump 12mm, oil tank 14mm
    MW
  11. paulie_b
    paulie_b F1 Veteran
    Jan 13, 2003
    6,816
    Jupiter, FL
    Paul Bianco
    thanks for everyones help.
