What tool to measure 360 flywheel thickness? | FerrariChat
Discussion in 'Technical Q&A' started by 24000rpm, Apr 20, 2016.
  1. 24000rpm
    24000rpm F1 Rookie
    the tools I can find have a range of 0-25mm but the outer part of the flywheel will exceed 25mm, which means I can't put the tool into the flywheel for measurement.....
    What specific tools do you use?
  2. BJJ
    BJJ Formula 3
    1,301
    #2 BJJ, Apr 20, 2016
  3. 24000rpm
    24000rpm F1 Rookie
    wow, thank u so much!
  4. ago car nut
    ago car nut F1 Veteran
    5,521
    Madison Ohio
    David A.
    1" to 2" deep throat micrometers. Deep throat metric micrometers.
