What trickle charger to get | FerrariChat
Discussion in '458 Italia/488/F8' started by 458-GT3, Jul 4, 2025.
  1. 458-GT3
    458-GT3 Rookie
    9
    Eric Abenoja
    Hi y’all,
    what brand trickle charger are you guys using that are on an anti gravity battery?
    looking for something simple.
    Thanks in advance
  2. up4speed
    up4speed F1 Rookie
    3,692
    Long Island, NY
    Chris
  3. F8F8evoevo
    F8F8evoevo Karting
    May 27, 2025
    77
    My F8 came with a Ctek MXS 5.0 which is fine and basic. I also use Noco 5 and 10 which are great. I bought a magnetic adapter for the Noco to use with the F8. Not sure about the 458, if you need an adapter. Personally I prefer the Noco to the Ctek.
  4. Phelips
    Phelips Karting
    May 30, 2025
    61
    Russel Phelips Brown
    For AntiGravity batteries, go with their Lithium-Compatible charger or a basic Battery Tender Junior (just make sure it has a lithium mode). Simple and reliable.
    Shorn355 likes this.
  5. 458-GT3
    458-GT3 Rookie
    9
    Eric Abenoja
    Thank you. Looking at the lithium ctek one now.
  6. 458-GT3
    458-GT3 Rookie
    9
    Eric Abenoja
    Thanks I found the right one on the Ctek website, ordering now.
    up4speed likes this.
  7. subzero25314
    subzero25314 Karting
    Dec 28, 2024
    56
    Ctek 7200 FTW
  8. Snapshift
    Snapshift Formula Junior
    923
    Centralia IL
    Lyle D. Pahnke
    #8 Snapshift, Jul 5, 2025
  9. 458-GT3
    458-GT3 Rookie
    9
    Eric Abenoja
    Oh darn just ordered the ctek yesterday. I think I’ll return and get this one. Can’t go wrong when it’s the same company making it for their product.
    thanks!!
  10. up4speed
    up4speed F1 Rookie
    3,692
    Long Island, NY
    Chris
    That charger looks cool, but will you be able to use a pigtail adapter on it like the C-tek so you can plug it in to the car like the factory tender?
    If not, I would still get the C-tek. It's a nice convenience to plug it in to the OEM spot on the car. Especially if it's a 488 or newer with the magnetic exterior plug.
    Plus, C-tek is a proven design. Who makes the Antigravity one? I would feel more comfortable with a company that specializes in chargers, and sells a ton of them, and they are the Ferrari OEM provider.
    luvair likes this.
  11. Stethoscope
    Stethoscope Rookie
    18
    @up4speed
    The video shows it including the pig tail adapter.
  12. up4speed
    up4speed F1 Rookie
    3,692
    Long Island, NY
    Chris
    The pigtail adapter will leave a pigtail hanging in your foot well. If you want it to hook up like a factory tender, you will need the C-tek.
    Like this:
    https://www.ebay.com/itm/195154056629?_skw=c-tek+charger+ferrari+adapter&epid=8055514313&itmmeta=01JZGHZVB8TZZDX4DRNZ3BHXTD&hash=item2d701695b5:g:1gsAAOSw5uJixIHD&itmprp=enc:AQAKAAAA4FkggFvd1GGDu0w3yXCmi1eTD/hZ45K4iT8w5GoADE+vxt/x3tFuGly2smQRoN8vByHwTeznfl2xztoIA57sCdIa/MbLP9eR3KOIuotCgEetS2xapnyWIVT4BPUuVFTgl6b941k3tv/iP0UV91HcBwi29zXAyCD54gO2h+ZoGb5IAmyTHslf/3HLxKP1zdptzORsO57iCaAmNPBGtQEKPFtwJl8PfnIXjP00/oEcJ3GiehNoHv+aeCQ6tHOAqkEUxPFWMlF4fDpTCwDohPukEwupYfvSGySK6wkKFtlwtt4H|tkp:Bk9SR_S1_5H8ZQ
    That's just an example, you may find it cheaper, but you can see what I'm trying to describe.
    ***Unless you can maybe find an adapter that has the same jack as the Antigravity connector. (if it uses the same jack as the Battery Tender brand (looks like it may be the same), you may be able to find one to fit.
  13. DiamondDog
    DiamondDog Formula 3
    Aug 29, 2021
    1,462
    Orange County, CA
    There is a seller on F Chat in the market place from San Francisco area that sells adapters and you need to specify for the Anitgravity batter as I believe the polarity is reversed.
