What were original tires on 328? | FerrariChat
Discussion in 'Technical Q&A' started by vinny, Dec 10, 2003.
  1. vinny
    vinny Karting
    Nov 1, 2003
    167
    R.I.
    Vincent Pitocco
    What were original equipment tires on 328 line and roughly how many miles could you get from them?
  2. f355spider
    f355spider F1 World Champ
    18,044
    Two tires were specificied in the owner's documents. Both were Goodyear products
    One was the NCT with a treadwear rating of 140, the other was the Eagle with a treadwear rating of 220.
    There are way too many variables in wear, to say how long they lasted. I would guess that most are replaced do to damage or age, rather than wear, since most folks put so few miles on their cars...
    Why do you ask?
  3. vinny
    vinny Karting
    Nov 1, 2003
    167
    R.I.
    Vincent Pitocco
    Im in the market for a 328, just figured it was a good way to check if mileage coinsides with treadwear.
  4. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    I would sure hope that the tires have been changed by now.
  5. f355spider
    18,044
    Vinny,
    The BEST way to document mileage is with a solid history of receipts from day one; for services, tires, replacement battery, etc. Trying to figure it out, based on tire replacement, pedal pad wear, entails way too many variables to be trusted with any reliability.
    Without complete history, a solid amount of documents for the past 5-7 years would be good. Between that and a thorough PPI should tell you if the the car is sound, and the mileage fits the car.
    No reciepts or documents? Walk...no run! :)
  6. DGS
    DGS Seven Time F1 World Champ
    71,839
    MidTN
    DGS
    Performance tires have a life span of a few years, max. Even if you don't run them, they will get harder with age, until they become fairly useless. In far less than the life of the newest 328, they become too cracked and brittle to use ... or even, likely, hold air.
  7. vinny
    vinny Karting
    Nov 1, 2003
    167
    R.I.
    Vincent Pitocco
    Thanks Guys, Great advice.
    Vinny
  8. Mark 328
    Mark 328 Formula Junior
    Nov 6, 2003
    510
    Orange, Ca
    Mark Foley
    Vinny:
    I saw a low milage 308 with the original tires on.
    It was one of the Magnum PI cars with less then 20K on the odometer; the car was at the recent "Under 3 Liter" show at Woodley Park (Van Nuys) Ca.
    I have also seen low milage cars at Symbolic Motors with the original tires.
    Look at the car carefully, and be sure to do a Car Fax.
    Mark
  9. hk328
    hk328 Rookie
    Nov 14, 2003
    21
    Vinny
    Note other comments, I know of 2 accidents, one in China, one in Hong Kong where cars have been written off, reportedly due to original low mileage tyre failure. Cars involved a Testarossa and a Diablo!
  10. CraigFL
    CraigFL Formula Junior
    Jan 17, 2001
    954
    Panama City, FL
    Craig
    The standard type of tire mounted was put on a decal and stuck under the locking glovebox door.
