What Year will 911 GT2 go sub 2 sec. | FerrariChat
Discussion in 'Porsche' started by msdesignltd, Oct 14, 2010.
  1. msdesignltd
    msdesignltd Two Time F1 World Champ
    20,345
    NYC. / E. Hampton
    Michael
  2. Michael B
    Michael B F1 Rookie
    Apr 28, 2004
    3,762
    US of A
    Michael
    The GT2 with its rear wheel drive will have a heck of a time going sub two... well enough 2.7 (I believe the 2.7 0-60 time is the PDK Turbo-S with all wheel drive... Not the GT2).
  3. UroTrash
    Jan 20, 2004
    40,504
    Purgatory
    Clifford Gunboat
    The year that has the weight to power ratio of a Hayabusa.
  4. tundraphile
    tundraphile F1 Veteran
    May 16, 2007
    5,083
    Missouri
    #4 tundraphile, Oct 15, 2010
    Never.
    Even with AWD and all the power you want it wouldn't happen with DOT tires as the rate of acceleration would be greater than 1g. Difficult to do with anything having treads even if it was 400mm wide.
    A Veyron reportedly does it in 2.46s. Unless super-sticky tires are used and heated mercilessly for a drag run, you won't see street-legal times any faster than that. Even then getting more than 1g acceleration is difficult.
    0-60 in 2 seconds would be 1.24 g.
  5. 308 GTB
    308 GTB F1 World Champ
    11,729
    New Jersey
    Barry Wolinsky
  6. Far Out
    Far Out F1 Veteran
    Feb 18, 2007
    9,768
    Stuttgart, Germany
    Florian
    Apart from the limitations mentioned already: I know you guys hate electric motors in cars, but they would provide, given the same power, for faster acceleration due to the full torque being available from 0rpm.
  7. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,600
    Gates Mills, Ohio
    Jon
    True. Battery weight is probably the limiting factor (?)
  8. Far Out
    Far Out F1 Veteran
    Feb 18, 2007
    9,768
    Stuttgart, Germany
    Florian
    That depends on the battery! See Tesla for electric car performance :)
  9. Doctor7474
    Doctor7474 Formula Junior
    Jun 20, 2010
    367
    Hoover Al,former Atl
    Doctor
    World record drag radial car ran a 4.403 1/8th mile at 179 MPH with 315mm wide tires, and weighed 3250lbs. These tires are street legal with DOT approval ratings. Wouldn't drive with them in the rain though...
    Pretty sure that would definitely be sub 2 second 0-60mph times.
    http://www.youtube.com/watch?v=G5vk7ySeY-w
    I doubt it could ever be accomplished in a Porsche with out a front engine V8 conversion as I don't think you could build a Porsche engine with that kind of power. Plus the rear weight bias, chassis design, and independent suspension are way more of a limiting factor than and tire traction concerns.
