what's going to happen if i..... ? | FerrariChat
Discussion in 'Technical Q&A' started by Jimmy540i, Feb 21, 2006.
  1. Jimmy540i
    Jimmy540i Formula 3
    2,494
    Los Angeles / NYC
    www.Jimmy540i.com
    #1 Jimmy540i, Feb 21, 2006
    Guys i have 2 360s. I'm curious what's going to happen if I put the head unit of my red 360 into the yellow one?
    It is going to work? Or it would tell me i need to input the code? or this will mess up the system?
    Anyone know? I'm really curious but I wouldn't do it before I know the answer cause I don't want to **** things up lol... thanks
  2. EVartanian
    EVartanian Formula 3
    Mar 19, 2002
    1,180
    Sunny SoCal
    Eric
    Jimmy, do you mean you want to replace just the faceplate from the head unit of your yellow car with the faceplate from the red car? If you plan on just swapping the faceplates, I don't think it should be a problem, nor should you need to enter the radio's security code. Only if power is cut from the head unit will you have to enter the code.
    If you plan on swapping the entire head units, you will need the codes once you plug in the power. You'll also need the "key's" to remove/pull out the radio from the car.
    Perhaps see if any others chime in with their thoughts, but I'm pretty certain I'm correct.
  3. Jimmy540i
    Jimmy540i Formula 3
    2,494
    Los Angeles / NYC
    www.Jimmy540i.com
    yes, just the plate :)
  4. Jimmy540i
    Jimmy540i Formula 3
    2,494
    Los Angeles / NYC
    www.Jimmy540i.com
    anyone other pointers? thanks!
