What's happening with my wheels? | FerrariChat
Discussion in '348/355' started by GrigioGuy, Dec 7, 2017.
  1. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,433
    E ' ' '/ F
    Enzo Gorlomi
    I'm running 355 wheels on my 328. All are fronts, and all were bought used. I've had them on the car about a decade now.
    The other day I glanced inside one of my rear wheels and it looks like the paint is peeling off. These pics are the worst wheel, but I have another that is starting. No brake fluid leak, which was my first thought. The stuff coming off is matte on the outside and shiny on the side toward the wheel.
    Ideas? Bad refinishing? Is it dangerous to continue to use them?
  2. hjp
    hjp Formula Junior
    Feb 23, 2013
    591
    Kansas City, Mo.
    Jerry Peterson
    Appears to be an improper base coat (or likely no base coat) under the finish. Check the threads here regarding Braden's refinishing 355 wheels. They explain how to do it right. The 355 wheels are magnesium and need a special base coat (I believe its made by 3M but can't remembers its name) otherwise the paint will blister or delaminate over time.
  3. itsablurr
    itsablurr Formula 3
    1,016
    Carlisle, MA
    Matt
    #3 itsablurr, Dec 7, 2017
    Wheels chromed at some point?
    DOW 7
  4. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Yes, Dow 7 is a chemical conversion process similar to alodine on aluminum. It's a dipping process, it's not a coating. After Dow 7, within a limited amount of time, primer should be applied. Dow 7 is critical for adhesion and protecting the metal.
    Here is a photo of wheels I had Dow 7 process done on.
    SoCal1 likes this.
  5. FLORIDAsnakeEyes
    FLORIDAsnakeEyes Formula 3
    1,154
    Sarasota, Florida
    OC
    Were they sand blasted first or chem stripped??
  6. watkinsgt
    watkinsgt Karting
    Feb 4, 2008
    215
    Gents, Is Dow 7 necessary prior to powder coating?
  7. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Hi Tom, it's not. But don't powder coat 355 wheels. To high of heat for magnesium.
  8. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    Maybe Ferrari is making the wheel inserts out of the wrong matrerial
    "Dow 7 is a good choice for both new and overhauled parts that have
    dissimilar materials such as inserts, or where conditions will tolerate a
    less robust and less costly alternative to Dow 17 anodizing. It makes
    an excellent paint base and provides the best corrosion protection of
    the available chemical coatings for magnesium. "
  9. vracer
    vracer Formula 3
    Jun 23, 2014
    1,098
    NorCal
    Richard
    Mag wheels are subject to "cancer", i.e. corrosion. They should , (must) be magnafluxed.
