What's the best OBD scanner for 599? | FerrariChat
Discussion in '612/599' started by George Vosburgh, Aug 14, 2018.
  1. George Vosburgh
    George Vosburgh F1 Rookie
    Gentlemen, What type of scanner are you all using? Is the Blue Driver the best for a 599?
    Opinions Please!
  2. George Vosburgh
    I'm answering my own question, FOXWELL NT 510, works for 599.
  3. brogenville
    brogenville Formula 3
    2,265
    Robin
    Any generic OBD 2 scanner will work with a 599- it has to by law. It’ll only get you so far though, as many of the Ferrari trouble codes aren’t covered under the generic code list, plus there are loads of functions you can’t access without a more specialised bit of kit. Does the Foxwell get you into any of these proprietary functions?
  4. George Vosburgh
    I'll get back to you on this.
  5. Ospreyjack123
    Ospreyjack123 Rookie
    Aug 4, 2017
    3
    i have a CARLY universal, but it does not fit the port
  6. Skidkid
    Skidkid F1 Veteran
    9,521
    Campbell, CA
    John Zornes
    The port is a mandated standard and has been since 1982 SO you are either using the wrong cable OR you are trying to plug it into the wrong spot. Now, there are at least 3 different buss protocols so an older or very inexpensive scanner may not be able to talk to the port but that is different than doesn't fit.
    I should add: The above is true for US cars.
  7. F3RN4ND0
    F3RN4ND0 Karting
    Nov 16, 2015
    213
    Madrid, Spain
    F3RN
    FYI, I bought a Blue Driver model time ago and it did NOT fit the port.
  8. Skidkid
    Skidkid F1 Veteran
    9,521
    Campbell, CA
    John Zornes
    I don't know what to tell you. The product on their web site is the standard connector that has been in use since 1982. Spain/EU uses the standard OBD connector as well as the US. If I had to guess, you didn't find the right port. On the 599 it is hidden behind a panel so not obvious.
  9. F3RN4ND0
    F3RN4ND0 Karting
    Nov 16, 2015
    213
    Madrid, Spain
    F3RN
    John,
    I'm just trying to help George with his question regarding BlueDriver.
    I bought it a couple of years ago.
    It didnt suit the (Euro specs) port of my 599. Thats all.
    Here the prob I encountered. That centered protruding just makes the whole sensor impossible to connect.
  10. F3RN4ND0
    F3RN4ND0 Karting
    Nov 16, 2015
    213
    Madrid, Spain
    F3RN
  11. Rex71
    Rex71 Formula Junior
    Mar 24, 2007
    359
    Jeddah,Saudi Arabia
    Majd B.
    Same issue here, the Blue Driver scanner didn't fit my '08 599 GTB.
    I believe the large housing of scanner prevent's it from going all the way inside OBD port as the area there is crowded with other electrical things.
  12. Skidkid
    Skidkid F1 Veteran
    9,521
    Campbell, CA
    John Zornes
    Interesting and good point, you are right. I can't see the bar in their website pictures; thank you for the detail. That bar isn't supposed to be there for the OBD connector In most it wouldn't interfere but it isn't in the spec/design so isn't compliant.
  13. spirot
    spirot F1 World Champ
    Dec 12, 2005
    15,115
    Atlanta
    Tom Spiro
    I have an I Ca soft and it fits the port - and I used it to turn an CEL light off that popped on - code was sensor did not match another sensor ... stored the code etc...
