Whats the best way to apply | FerrariChat
Discussion in 'Technical Q&A' started by albert328gts, Mar 11, 2012.
  1. albert328gts
    albert328gts Formula 3
    1,667
    California
    Stabilant 22A to connectors, with a q-tip? With a brush? Or with?
  2. Jdubbya
    Jdubbya The $10 Trillion Man
    43,654
    Hell's waiting room
    I usually just put a drop on them. Unless it's a connector where the pins or spades are way inside of a cover or something. Then I would probably use a Q-tip with Stabilant applied judiciously.
  3. Denman_Honda
    Denman_Honda Karting
    Sep 3, 2009
    123
    DFW, TX
    Chris Denman
    Apply directly. I have not had to use it on a connector I wasn't able to drop the stuff directly on.
  4. SeattleM5
    SeattleM5 Formula 3
    1,265
    Kirkland, Washington
    Ettore Palazzo
    Mine came with a micro brush that works well for getting on those parts of the connectors that are hard to reach with the tip of the bottle (inner aspect of relay connectors in particular).
  5. mwr4440
    58,067
    Bavaria, The 'Other' Germany
    Mark W.R.
    Clean well with laquer thinner and use a wife's nail polish applicator.
    Safety Tip: Polish bottle should be empty first.
  6. albert328gts
    1,667
    California
    Thanks all for your help, my last question is once the Stabilant is applied do you let it dry for a few minutes before reconnecting or just reconnect?
  7. maestro8
    maestro8 Formula 3
    2,054
    Nor Cal
    Jason
    I use a little dielectric grease in my connectors before I reconnect. Seals out moisture, protects against corrosion.
  8. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
  9. Ricambi America
    Sponsor Owner
    I'm all ears. This looks very good, from the Milspec ratings to the documents they posted on their site. Have you used it before?
    The Air Force presentation they show is quite interesting regarding gold-on-gold connectors exhibiting significant corrosion.
  10. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    :rolleyes:
  11. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    Very interesting indeed.
  12. mwr4440
    58,067
    Mark W.R.
    Don't get too excited.
    Read MUCH further Gents.
    All is NOT as it appears to be presented.
    Ask yourself, "... significant fretting corrosion as compared to what?"
    Would something else have lasted longer or just been more economical to replace frequently (labor not included). BIG differences.
    Remember solar panels NEVER even return the energy it takes to make them. They are total energy losers with very limited realistic application. Houses are NOT "realistic" in the grand scheme of things.
  13. Ricambi America
    Sponsor Owner
    Agreed... and that's why I'm trying to learn more.
    http://www.hlinstruments.com/RoHS_articles/Reliability%20articles/What%20is%20Fretting%20Corrosion%20-%20Delphi.pdf
  14. mwr4440
    58,067
    Mark W.R.
  15. Ricambi America
    Sponsor Owner
    Mark, are we discussing the same subject?
    I'm just trying to look at the technical data on the product and see how it compares to similar offerings like Stabilant, Dexoit, or simple CRC contact cleaner. The MSDS of each product are interesting to compare side-by-side, as well as each product's utility for various metals in pin-to-pin applications.
  16. Matto
    Matto Formula 3
    Dec 26, 2011
    2,085
    Mooresville, NC USA
    Matthew
  17. mwr4440
    58,067
    Mark W.R.
    Understood. Was just adding another dimension to the discussion that is almost always left out when contractors are discussing the merits of their product and using the military as the backdrop. Can you say "Slick-50?"
    Sorry, Daniel. Please ignore all after "Good Day." :eek:
