What's the latest hotness in brake rotors for 355? | FerrariChat
Discussion in '348/355' started by squid, Nov 29, 2022.
  1. squid
    squid Karting
    Oct 5, 2006
    153
    I haven't found a ton of options for brake rotors, but I'm new to the F-car world and maybe I just don't know where to shop.
    My primary concerns are fade resistance, low weight, and I would like them to be quiet if possible.
    From my years in Spec E30 I've become a big fan of Stoptech slotted rotors, they seem to have the best life by far and are very fade resistant. However, they don't seem to be available in that size.
  2. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    In what size are you referring to there? Stoptech's are available for 355's.
    squid likes this.
  3. squid
    squid Karting
    Oct 5, 2006
    153
    Everywhere I've looked there's no Stoptech available...do you have a source to recommend?
    It's a 95 355 GTS. I assume whatever the stock size is, but I wouldn't mind adding some rotor mass for additional cooling if it's available.
  4. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Early cars has Teeves brakes not brembo, may be an issue with the year. Stoptech has kits for the 348 so I suspect the early 355 too, perhaps not obvious.
    Sent from my SM-G990U using FerrariChat.com mobile app
  5. fboutlaw
    fboutlaw Formula Junior
    Dec 3, 2014
    260
    Woodside, CA
    I have stoptech trophys on my F355. They fit under the stock wheels... as long as you use 1/4oz thin weights.
    I'm not sure what the policy here is on non-sponsoring vendors, but if you do a search on a site like vividracing, you'll find what you're looking for. They're not cheap, but huge huge upgrade over the stock system. Getting them installed was easy, getting them to work properly with ABS takes come careful shimming.
    willrace, IvanRico and squid like this.
  6. squid
    squid Karting
    Oct 5, 2006
    153
    I see the complete stoptech kits, I'm just looking for a set of rotors to replace the worn stock ones.
  7. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I know its an Italian car but using Tomato sauce for oil is probably not a good idea. Hope at least Roma tomato's.:p
    Fabulous photo btw.
    308 GTB likes this.
  8. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    63,971
    Southlake, TX
    Rob Lay
    how about the bearing hubs, they must be going for $2,500 each now. that was really the only expensive limiting part racing the 355 Challenge. bumpy courses could go through a set a weekend.
  9. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,631
    Elliott Caras
    It’s a vacuum tank - only the earlier models had it as a tin can it was later updated to a more robust unit.
    IvanRico and 308 GTB like this.
  10. 308 GTB
    308 GTB F1 World Champ
    11,719
    New Jersey
    Barry Wolinsky
    #10 308 GTB, Nov 29, 2022
    Right, Elliott. Here's mine on my 1995 F355 Challenge...
    When it fails, I have a spare..
    :D
    chopsui and OCKlasse like this.
  11. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I know it was humor. On the 348 that's the oil tank position. I hope that Sacramento Tomato product is made in Italy. :)
  12. willrace
    willrace Three Time F1 World Champ
    34,940
    North Tay-has
    Kurt
    #12 willrace, Dec 4, 2022
    I upgraded to larger Girodisc on the Porsche, and have been quite happy with them.
    They come with car-specific spacers to move the calipers to where they need to be.
