whats the oil capacity on 03 360 | FerrariChat
Discussion in '360/430' started by blkdiablo33, Aug 23, 2009.
  1. blkdiablo33
    blkdiablo33 F1 Rookie
    Jul 12, 2004
    4,456
    hi there when performing an oil change how many qts is needed and what grade of oil do you guys use in the summer time.
    thanks
    adam
  2. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    Total is 12 when system is dry.
    It usually takes 10 +/- at oil change.
    5W40 Redline
    Make sure you have an oil filter wrench to torque the filter around 18.5-18.6 ft-lbs.
    You will also need 12 mm and 14 mm hex wrenches and 22 mm oil rings
  3. blkdiablo33
    Jul 12, 2004
    4,456
    to ck oil level does eng have to be at normal operating temp than turn off than ck level?
  4. chrmer3
    chrmer3 Formula 3
    May 19, 2006
    1,719
    USSA
    Chris
    engine at normal operating temp- leave car idling- check with cap resting on top of reservoir (not in screwed down position)
    Use a rag to hold dipstick cap she will be hot.
  5. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    9+ to Redline
    5W40 is the perfect match, but 10W40 is ok too.
  6. 348 Turbo
    348 Turbo Formula 3
    Jul 17, 2002
    1,837
    yup
  7. blkdiablo33
    Jul 12, 2004
    4,456
    thanks for all the reply i used redline syn 5/40 and oem oil filter.
  8. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    This is your mother speaking: did you properly torque that filter?
  9. djastral69
    djastral69 Formula 3
    1,896
    Fl
    David
    Would it be recommended to use Redline 5w-50 oil instead of the recommended 5w-40?
    I live in Florida and it gets pretty hot during the summer months so i would think that the 5w-50 would provide better great protection.
