What's the power to weight of a daytona? | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by blackdr, Mar 19, 2013.
  1. blackdr
    blackdr Karting
    May 20, 2008
    92
    I'm just trying to figure out something in my head, now we all know about the obsession with horsepower everyone seems to always boast about.
    you know imports with some insane amount of power via some turbo the size of a jet on a space shuttle on them that makes them undrivabile and I'm looking at well regarded, good handling fast light cars as a base line in reality about what makes a fast car fast without going nuts on HP.
    and yeah I know everyone says go with the torque figures but I think that was more because of how much automotive makers used to lie about how much power their cars put out, GM being a damning example with there 1 HP per CI lie back in the 1950's
    when a 350 put out maybe 220 to 240 and a big block 427 290, atleast in street form, pre 1972 and somewhat even post really.
    So that out of the way I believe the lotus elan from the 60's is something like 1,500 pounds with a 140 HP motor, the Dino 206/246 is 2,300 - 2,400 pounds with a 170 to 200 HP motor apparently and looking up the daytona specs they seem kind of inaccurate
    something like the weight of the dino with 340 HP with a 4.4 liter V12 according to some of the specs I've found and judging by the size of the car it just doesnt seem right, especially given that the specs for a testarossa puts it at 3,300 pounds with 380 HP with a 4.9 liter V12 to reach about the same top speed and 0 - 60 time
    so what is the power to weight ratio of a 365 GTB/4? is the daytona really that light and have that much power?
  2. Daytonafan
    Daytonafan F1 Rookie
    Oct 18, 2003
    2,748
    Surrey, England
    Matthew
    Ferrari quoted 1200kg (2,645lb) dry for the Daytona when launched but that was very optimistic. I would estimate a Euro Daytona to be around 1,500 (3,300 lb) to 1,600kg (3,500 lb).
    As to power, I've never dyno'd mine but everywhere I've read says a properly tuned and serviced Euro Daytona should hit the quoted 352bhp. I can't comment on whether a US Daytona has less power or not (claimed to be the same).
    That should give you enough to work out your power to weight figures.
  3. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,038
    US Spec, late Daytona, wire wheels, spare tire and toolkit, but no fuel: 3,487 lbs.
  4. Dogdish
    Dogdish Formula Junior
    Dec 27, 2005
    367
    Denver
    #4 Dogdish, Mar 19, 2013
    US spec, 1971, half a tank of gas, Chromodoras, aftermarket rear A/C, no spare or tools.....3342
    Bill
  5. straightpipe
    straightpipe Karting
    234
    West Chester, PA
    Tom
    Interesting, I dyno'ed the C4 last summer at 354 HP with P6 cams, 4923cc, straight pipes and stock air filters . The engine was dyno'ed at 385 HP-364 TQ using stock mufflers and air filters in 2005. I think the book weigh is listed as 3800. It's been a ton on fun on the track and road. Especially if I can pass a Daytona which is priced beyond my range. Check out the db level and the guy in the background. There were about 12 of us doing the same. It's much better going down the road.
  6. miurasv
    miurasv F1 World Champ
    Nov 19, 2008
    10,754
    Cardiff, UK
    Steven Robertson
    Do you have a 400 engine with 4823cc in your car?
  7. blackdr
    blackdr Karting
    May 20, 2008
    92
    #7 blackdr, Mar 19, 2013
    Hmm so I was about right, something along the lines of 1 HP per 10 pounds coming out to 3,300 to 3,500 with 350 HP
    and yeah I thought the GTC, the 2+2 version of the daytona (if I'm getting that right) there had a 4.4 as well
    with the quoted weight by ferrari I may have an explanation for that exaggeration, they may have been trying to pull more buyers away from lamborghini with there miura here given the quoted weight here:
    Lamborghini Miura Restoration
    Lamborghini Miura Restoration Information
    Bob's house, 1982. The car was painted black and gold. I was so excited about getting the car that I bought some baby announcement cards and used this photo to send to a few friends. Name: Miura, Date: 12/14/82, Weight: ~2480 lbs! (About the same as my MGB.)
    and that is about on par with the quoted ferrari weight which seemed off to me, plus wasn't the daytona at the time the most expensive ferrari you could buy back then?
    something about 22,000 bucks back in the early 70's which in modern terms comes out to about 220 grand? so they may have lied about it for that reason.
    and yeah I know what you mean about the gas tank, think its two 15 gallon tanks one on either side next to the spare tire, which comes out to about 150 pounds of gas
    plus with the Miura it was really a concept car for the road hence its probably true lightweight on the early P400's of which that one is, while the Daytona was a proper old school GT Car that could actually reach its quoted speeds without having severe front end lift problems like the miura did
    and reportedly in the real life cannonball run at a 140 Brock Yate's blue 365 coupe wasnt even breathing hard while all of the normal american V8's would top out there or about 10 MPH earlier.
  8. straightpipe
    234
    West Chester, PA
    Tom
    #8 straightpipe, Mar 19, 2013
  9. blackdr
    blackdr Karting
    May 20, 2008
    92
    that's the DB level right? kind of surprised he doesnt have hearing protection on.
  10. straightpipe
    234
    West Chester, PA
    Tom
    They weren't prepared. You would've thought someone had foam plugs available. Everyone used the old finger but they could also walk outside (except the fellow running the show). Same problem around jets and F1.
  11. blackdr
    blackdr Karting
    May 20, 2008
    92
    ah I guess they werent rock people. as I started carrying around earplugs on me at all times in a little circular pill contaner when I was hanging around with a friends band about a decade ago, and when someone pulled the fire alarm in high school 3 times in 3 days.
  12. JazzyO
    JazzyO F1 World Champ
    Jan 14, 2007
    12,156
    The Netherlands
    Onno
    There is no doubt in my mind that a Daytona is heavier than a Boxer, and that closes in on 1,500kg without a problem (even the 365BB). There is also no doubt that a Daytona is significantly heavier than a 330GTC, and that also goes over the 1,200kg mark. I think a Euro Daytona should be close to 1,600kg with fluids. Whether a Daytona really delivers that 352bhp might also be up for debate, but I don't think it was overstated by a massive margin. The 365BB delivers around 350bhp at the 7,700 redline (which Ferrari lowered in the manual to 7,000, making for the generally accepted number of 344bhp). The 365BB engine was essentially a folded-out Daytona engine. Given the Daytona's redline, I would say that it will produce between 330 and 340bhp. But I have no data to back it up. ;)
    @straightpipe, your car should be a 4390cc, not 4932cc. Just a swap of the two digits, methinks.
    Onno
  13. blackdr
    blackdr Karting
    May 20, 2008
    92
    So the berlineta boxer was actually lighter than the daytona then? Hmm that kinda makes sense as I think that was ment more to be a proper kamakazi machine than just a fast old school grand tourer like the D was.
    And that was always my impression of the daytona, it was a what was thought at the time to be the last great hurah of the Front Engined long distance high speed grand touring cars that you would probably see Dean Martin or Frank Sinatra driving.
    So the Berlineta would have needed to be lighter and faster to be on par with the Miura and the Countach, which makes sense.
  14. Daytonafan
    Oct 18, 2003
    2,748
    Surrey, England
    Matthew
    In Simon Kidson's column in Classic Cars a few months back he wrote about dyno testing the GT cars of that era. Apparently the Daytona is one of the few cars that actually achieved exactly the 352bhp claimed by Ferrari.
    His own Ghibli SS came in around 290bhp IIRC.
  15. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    Maserati claimed 320HP for the 4.9 V-8 in the Khamsin (essentially same as Ghibli SS) and close to 500Nm torque. A Euro Khamsin weighs a little over 1500KG, tested top 273 km/h.
    What was the tested top of a Euro Daytona?
    On most of these cars you run out of revs before you run out of power. Top speed is almost never achieved at max HP RPM, always way over.
    Best,
    Jack.
  16. 375+
    375+ F1 World Champ
    13,658
    European spec Daytona was a legitimate 174 mph. top speed(as claimed by factory), as I recall Road & Track tested an early plexiglass example(Bill Harrah's) and achieved a true 173 mph.
  17. Daytonafan
    Oct 18, 2003
    2,748
    Surrey, England
    Matthew
    In Doug Nye's book on the Daytona, Paul Frere's driving impressions are included. He achieved 175.7mph in a Daytona with 28000km on it. He also said the car had not been prepared for him by Ferrari as the one that had been prepared broke down!
  18. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,038
    That is why I call our Daytona the "Freight Train" because it will haul the mail. In my experiance, you can take the rattiest, most moth eaten Daytona out there and it will do 165 plus easy. Daytonas just pull and pull at the top end. Boxers seem to be all over the place on performance, but Daytonas are amazingly consistent and almost any one in good tune will do over 170 mph.
  19. michael bayer
    michael bayer Formula 3
    Aug 4, 2004
    1,293
    375+: True - but little of Harrah's engine had any resemblance to the subsequent production motors - with far less output M
  20. Ak Jim
    Ak Jim F1 Veteran
    9,621
    North Pole AK
    "@straightpipe, your car should be a 4390cc, not 4932cc. Just a swap of the two digits, methinks."
    I think he has the engine block/crank/rods/pistons from a 412 in it.
  21. 375+
    375+ F1 World Champ
    13,658
    Michael,
    Is there any evidence that the engine in Harrah's car was something special? I was not aware of it. Thanks.
  22. michael bayer
    Aug 4, 2004
    1,293
    There were two Road and Track reviews, a year or more apart one of the Harrah hot rod car the other a "stock" production car I had them in hand when we did the Forza article side by side of the C4 and the Daytona but heavens knows where they are now
  23. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,692
    Sarasota
    David
    Do you know which issue the second test was printed in?
  24. 375+
    375+ F1 World Champ
    13,658
    The road test in R&T that I am referring to is from the October 1970 issue. The test car was Bill Harrah's personal car and it was driven by Dean Batchelor, the article featured the famous photo of the instrument cluster showing an indicated 180 mph. This is not the later Harrah hot rod, to my knowledge this was standard 365 GTB/4.
  25. VIZSLA
    Jan 11, 2008
    41,692
    Sarasota
    David
    That one I remember vividly. The one I'm asking about is the GTC/GTB comparison.
