What's the proper way to install a 308 oil filter? | FerrariChat
Discussion in 'Technical Q&A' started by greg328, May 5, 2005.
  1. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    I just bought several new Baldwin filters, thanks to the recommendation of many on this board. I'll be dumping my old FRAM!
    Now, how to install? Usually, one would fill the filter with oil, lube the filter gasket w/ oil, and install, right? Except these mount upside down?
    What's the proper procedure....?
    TIA,
    Greg
  2. Farmers Agent
    Farmers Agent Karting
    May 24, 2004
    153
    I let my 308 sit over night so the oil drains out of the filter, then loosen the oil filter. Nothing leaks out. It is easier then my other cars to change.
  3. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Do you have to fill it partially/fully w/ oil before install?
    Lube the seal first?
  4. 208 GT4
    208 GT4 Formula 3
    Dec 27, 2003
    1,769
    Brighton (UK)
    Dan
    I've never put any oil in mine before fitting, though I did lube the seal.
  5. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    Yes, Yes. Rag to mop up. I crank engine w/o fuel for a couple of cycles to see something on the guage before I try to start after an oil change.
  6. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    I usually run the engine for 10-15 minutes and then put it on the lift and drain the oil pan. Then I'll take a punch and punch a hole in the bottom of the filter (really the top as you look at it) . Then I go out and get a beer and some paper towels. Come back in 10 minutes and cover the timing hole under the filter and unscrew the filter. Just take the filter and put it in a can and then clean up any excess oil . Just finger wet the new filter seal with oil and screw it on. Fill up the engine with 9 liters (2.34gals) of Castrol 20-50W oil and start it up. Done , now go drive it and enjoy the ride.
  7. DN35
    DN35 Formula Junior
    611
    Illinois
    D. Norton
    First time I did it, the filter didn't seal correctly and my engine bay got a nice oil shower, and my garage floor a nice oil coating. Is there a tip to making sure it's properly seated or tightened? May have been a bad filter. That was in my early days when I didn't know any better. Purolator (sp?) I think. Got a half dozen Baldwins now thanks to Senor Sodacom.
    Thanks.
  8. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    Same here.
  9. ctk
    ctk Karting
    Jul 2, 2001
    238
    Singapore
    Guys,
    Went down to my local Baldwin dealer and asked for the B253 recommended and they offered me the B2 which they claim supersedes the B253. Is this correct? Can I use the B2?
    Can anyone shed light on this???
    Thanks.
  10. Bandit
    Bandit Formula Junior
    Dec 21, 2003
    493
    Central MS
    Mike B.
    B2 is the normal duty filter, listed as a replacement for the motorcraft FL1A. Specs say nothing about having a standpipe.
    B253 is the heavy duty racing filter and has a standpipe.
    B2 is $5, B253 is $12. You get what you pay for in this case. Insist on the B253.
    links here: B253 - http://www.adiesel.com/prodinfo.php?itemid=3156
    B2 - http://www.adiesel.com/prodinfo.php?itemid=2821
  11. ctk
    ctk Karting
    Jul 2, 2001
    238
    Singapore
    Thanks Bandit.
    As you would have it, they don't carry B253s and now want to provide a MANN W940 from Germany.
    CTK
  12. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    My oil is fresh, I just want to change the filter, based on everybody's recommendation....
    So, is the consensus to fill the filter with oil or not?
    Seems like it would spill out when you turn it to install.....
    This will be my first attempt at this, so any advice is welcome!!
    Greg
  13. f355spider
    f355spider F1 World Champ
    18,054
    NOT.
    Just lube the seal, install per instructions on filter.
  14. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,322
    Ventura, California
    Robert Garven
    #14 robertgarven, May 6, 2005
  15. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Dave,
    Thanks, I saw those instructions on the the filter--they were somewhat cryptic to me--still are.... !
    Greg
  16. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    Are Dave, Dan and me the only ones who read the original question? He wants to know about installing a NEW filter, not how to remove the old one! :)
    Anyway, just lube the seal, don't worry about filling it first.
  17. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Yeah, what Mike said.
    Greg,
    If you are just changing the filter to lose the Fram, just let the car sit overnight and all the oil will be out of the Fram. Just unscrew it and screw the new one on. There is no need to fill with oil. There is no way you would be able to put the thing on without getting oil everywhere.
    Contrary to what people say about the standpipe and the anti-drain valve, they don't hold oil that long. After a day, the oil gets out.
    Tips:
    After you unscrew the Fram, clean the surface on the engine where the oil filter seals. Just wipe it with a rag to be sure there is no grit or anything on there. Next, wipe a little oil on the seal of the new filter to lube it. This prevents the rubber gasket on there from binding and leaking. Now just screw it down "hand tight". Meaning, do not use a tool to tighten it. It has a rubber gasket. Make it snug by hand. It will be fine. If you over torque it, it will be a b*tch to get off!
    If the Fram is stuck and you don't have an oil filter wrench large enough (those are big filters) just punch a hole through it (do not drill! No metal filings in the engine!) and use a long screwdriver to loosen.
    Birdman
  18. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Thanks, Mike.
    Funny, sometimes people miss the "gist" of the question,
    but I still appreciate everybody's 2 cents. All info is valuable to me, as I'm a 308 newbie.....
    Birdman,
    Excellent instructions, thank you, as usual..!
    Greg
