What's the verdict on refueling? | Page 4 | FerrariChat
Discussion in 'F1' started by Drive550PFB, Mar 15, 2010.
  1. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,693
    Sarasota
    David
    Lacks the visual impact of a car making a DRS enhanced swoop.
    Have to keep things easily understood by the great unwashed.
  2. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Fine in theory. But in practice they'd pretty much all converge on the same strategy. Checo or Jenny may do one less stop, but beyond that the strategists will run the numbers and one will prove to be the best.
    Refueling isn't coming back any time soon - Remember, just hauling the rigs around the world added a complete 747 to the mix.
    Cheers,
    Ian
  3. VIZSLA
    Jan 11, 2008
    41,693
    Sarasota
    David
    Of course it's not.
    But if we're limiting ourselves to only discussing the possible you'll have to delete at least half of P&R.
  4. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    No doubt! I keep out of there - Scares the hell out of me! [I am a CA "flake" after all these days ;)]
    Cheers,
    Ian
  5. kraftwerk
    kraftwerk Two Time F1 World Champ
    May 12, 2007
    26,826
    England North West
    Steve
    +1 yup.
  6. kraftwerk
    May 12, 2007
    26,826
    England North West
    Steve
    #81 kraftwerk, Oct 31, 2012
  7. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Ouch!.... Almost certainly cost him the WDC. :(
  8. VIZSLA
    Jan 11, 2008
    41,693
    Sarasota
    David
    I do miss the comic relief.
  9. tervuren
    tervuren Formula 3
    Apr 30, 2006
    2,469
    I was glad to see it go, was surprised to see this thread, was going to post my thoughts, then realized I was quoting people from years ago.
    So anyway, I like it better without the refueling. I'd also like to see a tire that can go the race distance, I think it used to be that way in the 60's, refueling wasn't normal, nor was a tire change.
    Taking out refueling, emphasizes more on the driver.
  10. VIZSLA
    Jan 11, 2008
    41,693
    Sarasota
    David
    Go back further and you'll find both were a part of the sport. I suspect that more GPs have involved pit stops for tires and fuel than haven't.
    Anyone know?
  11. DGS
    DGS Seven Time F1 World Champ
    74,015
    MidTN
    DGS
    The problem is the mandated tires.
    The sharp end of the grid all qualify on the option tires, but then has to run the same tires with a full race worth of fuel -- which is a significant weight difference, in cars that light.
    They've done everything to try to *force* passing except the obvious: get rid of the super brakes.
    This is a constructors' series: they shouldn't be using brakes that are useless on production cars. (Ineffective when cold.)
    Go back to iron brakes, and drivers can't brake at 5G every corner.
    When you have to pick when to heat the brakes, you'll see more passing under braking.
    And you might even reduce costs a bit, too.
  12. tervuren
    tervuren Formula 3
    Apr 30, 2006
    2,469
    I know for sure rear tires where a wear issue in the "golden days" of GP racing - pre F1, pre WWII. Drivers could put the tires on edge, perhaps spinning them a little, trying to push harder out of corners, necessitating pit stops, or try to make the distance. I'm not sure on fuel back in those days.
    So post WWII, when did adding fuel during the race become normal? The early cars seem to have pretty substantial fuel tanks. I do not know my GP racing from the early 50's to the early 60's that well, or the 70's.
    I think the two different sets of tires, makes for more passing, but it can be hard to figure out who's doing what from a spectator's stand point. I'm ok with tire changes, and I'm ok with no tire changes.
  13. VIZSLA
    Jan 11, 2008
    41,693
    Sarasota
    David
    I think that refueling wasn't done between 57 and 82.
  14. schumacherf2006
    schumacherf2006 F1 Veteran
    9,100
    Chris
    Want to see it back ASAP
  15. Tifoso1
    Tifoso1 F1 Rookie
    Nov 18, 2003
    2,606
    Pacific NW
    Anthony C.
    I have been following F1 since the 80's and I can not say that I prefer one over another. With that said, there is one rule I hope that they NEVER consider bring back, the one set of tires per race rule. IMO, that was one of the biggest fail ever by FIA.
  16. ELP_JC
    ELP_JC Formula 3
    Dec 13, 2008
    1,264
    Great points.
    Imagine Grosjean or Maldonado with no brakes??? Honestly, it'd be a serious safety issue IMO; accidents would go thru the roof. It's like putting Miata brakes on a 458. Brakes have to at least match the performance of the car IMO. Production cars don't brake at 5Gs... but they don't corner at 5Gs either :D.
    After much debate, not an easy answer folks :).
  17. infinitespecter
    infinitespecter Karting
    Mar 16, 2004
    92
    I'm afraid I have to disagree. If the old Champ Car series is any indication, it won't help. They used steel brakes all the way up to the last year before the new DP-01 chassis was introduced, and during all of the last half decade, Sebastian Bourdais exhibited Schumacher like dominance and passing was still fairly uncommon. This was in a totally spec series with cars that were nowhere near as aero dependent as F1 cars.
  18. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    43,195
    ESP
    Bas
    +1
    It won't be long before they figure out the brakes and we'll be back at square one.
  19. texasmr2
    texasmr2 Two Time F1 World Champ
    22,232
    Houston
    Gregg
    IMAGINE!!!! I believe we have already witnessed that scenario countless times!!
    Sorry I could not pass up da pun.
