355 - What's wrong with this injector waveform ? | Page 2 | FerrariChat
355 What's wrong with this injector waveform ?
Discussion in '348/355' started by yelcab, Sep 4, 2023.
  1. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,294
    CT
    John Kreskovsky
    And, yes, I know, all the injectors are "good".
    Have you bothered to do a simple impedance check of the injectors? Are they all relatively the same?
  2. m.stojanovic
    m.stojanovic F1 Rookie
    3,315
    Serbia - Niš
    Miroljub Stojanovic
    Very interesting find. The 355 injectors should have 15+ Ohm resistance. This is the info I found:
    Qavion likes this.
  3. Qavion
    Qavion F1 World Champ
    14,634
    Ian Riddell
  4. johnk...
    Jun 11, 2004
    11,294
    CT
    John Kreskovsky
    #29 johnk..., Sep 9, 2023
    This is the way I see it. When the driver is open, Vss appears on the scope. When the driver closes you see ground potential. The absence of the flyback spike indicats that there is no reactive load which would indicate the injector is shorted or there is a very low resistance in parallel with the injector coil.
    One other possibility would be a very high resistance on the supply side (Vss side) limiting current to the injector.
    As Ian pointed out, it would be nice to know if the voltage scales are the same for the good and bad injector because if you aren't seeing a true ground on the driver side then it could indicated the driver has some parasitic resistance when close which would also limit the current to the injector.
    26street and Qavion like this.
  5. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Ok so I frigged up 1 of the pigtails I made so this happened to be the one I used for cylinder 2 and 3
    After fixing the crimped wire and retesting as per diagnostic sheet 11(which was how I found it) all injectors appear too be working
    I will get traces of them tomorrow and post
    So it seems I have not found the problem again since when the injectors were plugged directly and not into the pig tails for testing on the scope they would have been working it seems.
    Need to confirm this obviously tomorrow
    INRange likes this.
  6. 26street
    26street Formula Junior
    Jan 30, 2021
    473
    Westchester New York
    Mark k
    The only time it doesn’t matter which wire is when you are looking at AMPs with either a amp clamp or inline meter
    When checking voltage with a scope you need the red probe on the wire that is being switch on/off and black probe to ground if the signal is a grounding circuit if switch power then reverse the probes but either way still need on the wire that switches
  7. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    So all my tests were with the probes hooked up backwards according to the people in the know.
    I will attach a few scans from today but will reverse the probes and put all clamps to common ground at the back tomorrowThis scan has probes that reference each cylinder
    Here are some of the scans from today and a video but the probes were on power and the alligator clips were to each injector ground
    The scan today show it in the firing order 1 3 4 2
  8. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Here is a short video with the 1 3 4 2 firing order going down from top as above picture
  9. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    I don’t know why the movie did not load correctly
  10. phrogs
    phrogs F1 Veteran
    7,374
    Kzoo Michigan
    I would swap the injectors to different cylinders and see if the problem stays with the same cylinders or moves with the injectors.
  11. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    all the scales for voltage was the same I just did not put it on zero the same
    remember though it was my bad pigtail causing this issue as my previous posts show the same
  12. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
  13. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    The scales were the same but I had a poor connection or actually no connection on a crimp
  14. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    It was a bad connection on a pigtail being used inline with the injector so I could hook the scope up without back probing
    phrogs likes this.
  15. johnk...
    Jun 11, 2004
    11,294
    CT
    John Kreskovsky
    Grant asked me to post this video of his injector pulses. Have a look. All well and good.
    taz355 likes this.
  16. 26street
    Jan 30, 2021
    473
    Mark k
    All the waveforms in this pic look uniform and good still not sure about the voltage ranging of your scope
    I can see you are trigging your trace on channel 1 at 280.0 mv with a forward slope and the update rate is 20ms horizontally across the screen meaning you will only see a trace after the voltage rises about that threshold if you are not on auto range (which you should not be)
    The injectors should open when the intake valve is at or close too full open so what is the degree scale on the screen referencing ???
    What is the problem with the engine is it missing or running rough ???
  17. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,700
    San Carlos, CA
    Mitchell Le
    Grant
    Expand the horizontal scale and measure the width of each injector pulse. Are they the same for all four?
    Then switch one of the channels to Cylinder 5 of the other side. Compare the injector pulse width of Cyl 1 to Cyl 5, What is the difference?
    26street likes this.
  18. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Ok will try that but will be a few days sorry for the delay busy at work again due to ‘winters coming” ha ha
  19. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
  20. Qavion
    14,634
    Ian Riddell
    The increments in your last photo seem to show microseconds. That's ridiculously short for a pulse. What cylinder was that? Your photo in post #37 shows relatively normal scales/pulse widths.
  21. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    #46 taz355, Sep 11, 2023
    I think that’s correct but would the 10x on the probe mean it’s the same as 10 micro seconds?
    It is at idle
    It’s also only 1.5 dots roughly in post 37 and its 22 dots on this scale
    I think you would read it off of the notes but not sure what they mean
    But it says
    R1-width is 112ms not sure what most of that righting at the bottom means
    I did not know how to save it so it was saved as a reference waveform ie R1 with a description of
    Cylinder 4
    Then I zoomed in after so it probably just means that to make it that large 1 pushed the ms button to go from 200ms down to 1 micro second so it would get bigger
    Not even sure if that makes sense but I think that is what I did
    I used it as a zoom basically to see the shape
  22. Qavion
    14,634
    Ian Riddell
    Where is the "10x" shown? It sounds more like a vertical scale, not horizontal. i.e. voltage
    Even at 10microseconds per (horizontal) increment, the pulse width in that photo is only about 45 microseconds. Typical vehicle pulse widths should be around 2500 to 3500 microseconds at idle. Something weird is going on with your measurements.
  23. yelcab
    Nov 29, 2001
    13,700
    San Carlos, CA
    Mitchell Le
    Grant
    10x on the probe only affects the voltage level, the vertical scale. It does not affect the horizotal (the time) scale.
    That negative pulse looks like 4.5 divisions. You would need to know the horizontal setting, such as 10ms per division, and calculate the value of 4.5 divisions to be 45ms per pulse. This scope looks very capable so I bet there is an on-screen way to measure the time between two points on the signal. But, you are the only one there so there is no way for me to figure that feature out from here.
    The negative pulse is how long the injector stays open and therefore how much gas is being given to each injector. I want to see if all injectors on bank 1 is being fed the same fuel. Then I want to compare that to the fuel given to injectors on the other bank. Since your car is having over-fueling issue only on one bank, it is good to know if one bank is being fed more fuel than the other bank by the ECU.
  24. Qavion
    14,634
    Ian Riddell
    It does on one display, but what's happening on the second pic?
    Should that read 1 ms, not 1µs?
  25. 26street
    Jan 30, 2021
    473
    Mark k
    The pic on the right with (1 ms) should mean that each division across the screen is 1 ms so if I’m reading it right your ECM is supplying ground to the injector for 5.1/2 ms which for idle is ok in close loop
    What brand and model is the scope
