355 - What's wrong with this injector waveform ? | Page 4 | FerrariChat
355 What's wrong with this injector waveform ?
Discussion in '348/355' started by yelcab, Sep 4, 2023.
  1. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Yes I connected to all the different color wires not the green black and then to ground with the aligator clips
  2. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Before I was connected to each injectors both wires green black and the others
    The green black was to the probes and the other side was to the clips
  3. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
  4. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    #79 taz355, Sep 13, 2023
    I think I am only reading the ground side of the injector now as my probe is only hooked to one side of the injector 1 and 3 and then ground
    Black and grey
    And red yellow
    And then ground on chassis
    Mitchell said we want to see the wiggles and there are lots of them ha ha
  5. Qavion
    Qavion F1 World Champ
    14,631
    Ian Riddell
    Perhaps too many. I don't know if there is something wrong with your test leads. They should be shielded from interference.
    So something like this...
    The transistor in the ECU acts as a variable resistance (across the collector/emitter). It should be close to infinity when the transistor is not activated. If you have a small resistance in series with a large resitance, most of the voltage will be across the large resistance. This gives the oscilloscope the steady or "baseline" voltage. When the transistor is activated, firing the injectors, the resistance across the transistor drops dramatically. Less voltage will be measured by the oscilloscope.
    To put it mildly, your baseline is all over the place.
    Correct. Unmetered air can be fed into engine via air leaks in the manifold (after the MAF) and also into the exhaust (via exhaust leaks and leaks in the secondary air system). I've been told that even exhaust leaks after the rear O2 sensors can allow unmetered air to get to the O2 sensors. If the O2 sensors see too much air/oxygen, the ECU adds more fuel (unnecessarily so if the leak is not part of the normal combustion process).
  6. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,700
    San Carlos, CA
    Mitchell Le
    Let me suggest this.
    Remove all the probes from all injectors.
    Take one probe, clip its alligator clip to a chassis ground point on the car.
    Take the tip of the probe and touch it to one of the two pins on one injector (via the pig tail). If you see the original pattern of 13.5V and 4.5 ms negative pulses, STOP.
    Do the same with the other 3 probes.
  7. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Remember my test Leeds are set to x10
    Would that matter?
  8. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    #83 taz355, Sep 13, 2023
    So because the injector resistance is larger than the small transistor resistance and very small when the transistor ground I should See a straighter line higher voltage about 14 v most of the time when the transistor is grounded and then a very low voltage spike when the transistor switches the injector on
    Ok it’s late here so will do tomorrow after work
    I do have it hooked to the chassis ground bolt by the positive bolts at the back
  9. yelcab
    Nov 29, 2001
    13,700
    San Carlos, CA
    Mitchell Le
    IF you truly connected the probes to the two pins of the injector this way, and saw the 13,5 volts across the injector pins 98% of the time then we found the problem. It means there was 13.5 V across the fuel injectors almost all the time and the fuel was being dumped into the cylinder continuously.
  10. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Just so you know I left the trace on and scope plugged in so I could manipulate scales etc for these traces if someone needed me too
  11. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    I am quite sure of that as I checked 2 injectors by pulling back the boots and tracing the wires to the probes
  12. Qavion
    14,631
    Ian Riddell
    The resistance of the transistor is not necessarily zero at the time of firing. If the resistance of the transistor was, say, the same as the injector, in theory, the voltage actross the transistor (at the time of firing) should be half of your supply voltage (13.5 volts divided by two).
    The transitor resistance can be varied by putting a different voltage on the base of the transistor (i.e. on the third leg). You could probably compute the resistance of the transistor by seeing how much your voltage drops when the injector is fired (if you knew the resistance of the injector coil). Note that coils are not true resistances, though. That's why you get the spike when the transistor is turned off. Anyway, we are probably getting off track here.
  13. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    So all I need to do is hook 2 of them back up the way I had it and instead of saving the trace to R1 just keep it on the scope as a trace and this would show that they are open most of the time and only closing for a micro second?
    They are working backwards?
  14. Qavion
    14,631
    Ian Riddell
    It's the signal to noise ratio I'm worried about. If your signal is bouncing up and down erratically, we don't know what the injector is doing. There may even be a foreign signal on the line activating the injector.
  15. m.stojanovic
    m.stojanovic F1 Rookie
    3,315
    Serbia - Niš
    Miroljub Stojanovic
    The transistor that switches the injector on & off is a so called switching transistor (MOSFET nowadays) and it is basically an electronic switch. For any analysis of the injector circuit, it can be taken that, when "off", the resistance between collector and emitter is infinite (open) and, when "on", it is zero. Just like in the case of a mechanical switch. The control of the transistor is such that it is brought to either "on" state or "off" state with the switching between the two states happening very fast, typically in 20 to 200 picoseconds (1 picosecond = 0.000,000,001 milliseconds), that's fast!
    With regard to the scope, x 10 setting on the probe might be too sensitive. I would try with lower sensitivity.
  16. Qavion
    14,631
    Ian Riddell
    Since there is still a voltage of around 1.7V on the scope when the injector is firing, I guess there must be some kind of additional resistance in the ECU in series with the MOSFET.
  17. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,294
    CT
    John Kreskovsky
    Too many voices.
    Both side or just 1-4?
    Sounds like a bad exhaust leak in the exhaust before the first O2 sensor or a cylinder not firing, or air injection is not shutting off.
  18. yelcab
    Nov 29, 2001
    13,700
    San Carlos, CA
    Mitchell Le
    We are so conditioned to see what we want to see that we don't see what is wrong with this picture.
    Grant's probes are 10x ... so the Maximum value of the yellow curve is 67V, and the Minimum value of the yellow curve is MINUS 17.6V.
    That is drastically wrong. Maybe the way the probes were connected was really wrong.
    Qavion likes this.
  19. johnk...
    Jun 11, 2004
    11,294
    CT
    John Kreskovsky
    Given that the pulses look as expected with the exception of the voltage scale, common sense would say that since this is a 12 volt system the voltage drop when the switch is closed must be on the order of 12 V or a little less. No way you et 17v out of a 12v system. Conclusion, the scope or probes are miscalculated.
    If, as Grant said, the O2 sensors are telling the ECU to richen the mixture, then either there is excessive O2 in the exhaust or the O2 sensors are shot.
    What are LT ans ST fuel trim doing. Grant's comment would indicate that they are increasing with time. Has that been verified?
    taz355 and Qavion like this.
  20. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Yes it’s all been smoke tested and there is nothing for leaks
  21. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Yes before all leaks were fixed now they just stay around 18 hrs and 11 with a STFT on that side of -4 but I don’t let it idle too long due to cat overheating on rhs
  22. johnk...
    Jun 11, 2004
    11,294
    CT
    John Kreskovsky
    Have you looked at the O2 sensor signal on the right? Is it switching? Is it pinned to low voltage?
  23. 26street
    26street Formula Junior
    Jan 30, 2021
    473
    Westchester New York
    Mark k
    If the car is over fueling (aka rich) and the O2 sensor is the fuel mixture not being burned the pulse with will be less (aka on time of the injector) to lean the mixture
    By leaning the mixture (aka give it more air the what the throttle plate can give you should see a change in the O2 sensor
  24. 26street
    Jan 30, 2021
    473
    Mark k
    What the O2 sensor sees because that controls the pulse with
  25. yelcab
    Nov 29, 2001
    13,700
    San Carlos, CA
    Mitchell Le
    I just reread this posting by Grant and it clued me in to what we were seeing.
    Assumption: All four probes were connected the same way to four injector signals, AND each probe ground signal (alligator clip) is totally isolated from all other probes grounds (not the case in the older oscilloscopes), AND all probes were 10x probes, AND the scope was set for AC-coupling. (Definition of AC coupling is not relevant here)
    Then, the signal graphs that were posted made sense. Even the minus 17.5V of the signal just means the scope removes the DC energy, which balances the high skinny positive flyback spikes against the fatter negative pulses.
    I would not have connected the probes that way, but we have what we have.
    If Grant can confirm that the negative pulses of all four Cyl 1/2/3/4 are the same then we can at least agree that the injector wirings are not compromised.
    What remains is to compare these signals to at least one signal of the other bank, Cyl 5 for example.
    INRange likes this.
