355 - What's wrong with this injector waveform ? | Page 5 | FerrariChat
355 What's wrong with this injector waveform ?
Discussion in '348/355' started by yelcab, Sep 4, 2023.
  1. Qavion
    Qavion F1 World Champ
    14,622
    Ian Riddell
    And set the timebase to 1 millisecond so we can get a proper reading of the width of the pulse on Cyl 5 and at least one cylinder on bank 1. This may mean that you won't see the pulses on the other injectors at the same (but we need an accurate reading).
  2. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
    That's the way it should work. But apparently that is not what is happening. There is unburnt fuel in the exhaust, a very "rich" condition, causing the cats to over heat. Under such conditions, if operating correctly, the O2 sensor "should" sense a lack of O2 in the exhaust and narrow the pulse width. But it's not doing that. It pushing the LTFT to 18 which means it's actually trying to correct for too much O2 in the exhaust. I.e. for some reason it thinks it's too lean. Why does it think it's too lean? Assuming the ECU is OK it must be getting a signal from the O2 sensor that there is too much O2 in the exhaust. The reason could be any of several: bad O2 sensor, Exhaust leak (Grant says no to that), bank 1 running on 3 cylinder, failure of the air injection system to shut down in closed loop mode.....
    What could be done is to set LTFT to zero and see if it increases again, but I think an SD1 is required to reset it. I recall LTFT is not reset when power is cut to the ECU. Perhaps someone can confirm that one way or the other.
  3. Qavion
    14,622
    Ian Riddell
    Grant, could you just confirm that you meant +18 LTFT.
    Definitely not on the 5.2. No reset.
    taz355 likes this.
  4. 26street
    26street Formula Junior
    Jan 30, 2021
    473
    Westchester New York
    Mark k
    I believe we are all talking about the same thing but with different approaches
    Ltft doesn’t reset after key off —- and ltft is a strategy to bring STFT to 0 —- the STFT has to rises or fall from what the feed back from O2 sensor is at that time the LTFT will rise or fall if the STFT stays above or below a predetermined value in the ecm so that the STFT is as close to 0 as possible
    Add the 2 together and that your over all trim
    A CAT in simple terms stores oxygen and the fuel mixture will create a high temperature catalyst reaction —- the O2 sensor monitors the fuel mixture to try to keep the system in the right “sweet spot “ not overheating the cat and have a reduction in lower emissions—— the air pump is supply oxygen to cat through exhaust valves to ensure there’s is enough oxygen for the emissions to be reduced and to help lite off the cat as fast as possible
    The temperature sensor on the cat is to warn the drive the cat can not handle the the high temperature that is being created in the car and to allow the system to lower or add more Oxygen to bring the cat back in balance
  5. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    No it is switching fast on front and slower on rear
  6. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    This was all due to a misfire on at least cylinder 4 due to fuel injector not firing so far
  7. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    #107 taz355, Sep 18, 2023
    I can confirm as I have 2 ecu’s and my used ecu had LTFT at about 5 when I plugged it in and it slowly started to climb and car was still not working correct and STFT was at 10
    When original was plugged in it was STFT 5 and LTFT was at 15
    as LTFT went up STFT went down and even when unplugged for months it remembers it.
    That being said I can supposedly 0 it out with my Leonardo.
    Air injection shuts off about 3 min
  8. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    #108 taz355, Sep 18, 2023
    Update. X 1 on Leeds from now on and voltage at 10 volts. DC coupling
    So definitely bank 4 is not firing and when I move the main harness in towards engine it works and when I pull towards seats it cuts off and maybe even more than 1 cylinder.
    Here is the trace from bank 4 when working followed by when not working.
    And now today not working
    this picture is zoomed
    Of the above one
    So would that mean grounding problem
    Or supply voltage problem
    voltages are set at 10 volts
    when it was working those smaller vertical lines are exactly 28ms apart
    Qavion likes this.
  9. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
  10. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,698
    San Carlos, CA
    Mitchell Le
    Grant, you don't have a grounding problem. You have at least one (maybe more than one) broken wire from the 88 pin connector to the injector connectors.
  11. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Would it be the ground wire though or the voltage wire
    Can we tell from the scope
  12. Qavion
    14,622
    Ian Riddell
    Are you pulling on the harness in the cabin? The injector power wire for both the right bank and the left bank is probably only a single wire near the ECU (and doesn't go to the ECU).
    Even on the bad waveform, the base voltage seems to be the same as on the good waveform (?). As Mitch says, it's more likely to be the individual ECU trigger wire/s.
  13. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Yes I am pulling on the main harness right at the bulkhead rubber
    When I pull it miss fires when I push it back towards engine it runs good
    I am not moving other connectors in the cabin and if I try to they do nothing
    Only the main harness has an effect
    Qavion likes this.
  14. Qavion
    14,622
    Ian Riddell
    So it sounds like there is a broken wire or two inside the harness. Perhaps the harness was stretched too much during an engine out.
    Other than splicing in some temporary wiring, it sounds like an engine out job to repair the wiring.
    Welcome to the club.... I still have a bypass harness for my alternator... until the next major.
  15. johnk...
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
    #115 johnk..., Sep 19, 2023
    If I understand the figures this is what I see. To the left is what you are seeing. The probe is sitting at the supply voltage before the switch closes. Then there is a spike down when the switch closes but it quickly rises back to nearly the supply voltage. This indicates a high resistance in the ground side of the injector, limiting the current flow. Classic response of and RL circuit to a step change in voltage. That resistance must be somewhere after the point where the probe is connected.
    To the right is what the signal should look like.
    I would check the harness to the ECU where the wire is crimped to the connector to see if the wire broke just before or at the crimp. I've had that happen. It's a high stress point.
    Another option is to run a second wire parallel to the wire in the harness from the injector to the ECU and see if that solved the problem
    Here is a schematic ofwhat you appear to have on the left of the correct circuit on the right.
    Here is what I mean by a second wire. If doing this works it eliminated the ECU "switch" as the problem.
    Qavion likes this.
  16. johnk...
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
    Qavion likes this.
  17. Qavion
    14,622
    Ian Riddell
    That's the hard part... running a wire through the firewall over the fuel tank into the cramped area behind the engine, then through the engine "V".
    There is a concern that the old wire is shorted to something, so you may have to temporarily cut both ends of the old wire to take it completely out of the circuit.
    26street likes this.
  18. johnk...
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
    #118 johnk..., Sep 19, 2023
    Yes, but to test it you can just run it from the injector, out the rear deck, in through a window and to the ECU. If that works the problem is confirmed.
    Shorted? To what? The wave form doesn't look like a short anywhere. The initial negating spike when the switch closes followed by a rise to nearly the supply voltage indicates a high resistance in series with the injector (not the injector resistance). The large positive spike when the switch opens is a result of the instantaneous drop in current to zero (open circuit).
    Another reason why 2.7 cars are better. ECU right in the engine compartment. ;)
    Qavion likes this.
  19. Qavion
    14,622
    Ian Riddell
    Ferrari is still making up its mind about this :D
    348 - out of engine compartment
    F355 2.7 - in
    F355 5.2 - out
    456/550 - out
    360 - in
    F430 - out
    F458 - in
  20. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    I think that is correct but I was not smart enough to put that together
    I am not sure John
    All I know is that I did not get the correct trace when I pulled on the harness
    This is without moving the main 88 wire connector
    It is definitely within 6 inches of the bulkhead as you pull and push while isolating the wire from bulkhead to 88 wire plug
    If I move just the 88 wire plug lots it does nothing
    I did not look but do the time frames match up.
    I assume they did and that. Was how you came up with that
  21. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    I don’t blame ferrari for me likely pulling too hard on the harness
    Mostly poor mechanics
  22. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    #122 taz355, Sep 19, 2023
    Based on the scale though would it not be like 5 micro seconds between those
    And on the good wave is it not 4 milli seconds based on scales
    So would that actually be the same??
    I think I read it wrong it does look close
    So did anyone say weather this was power or ground
    My understanding is it would be the switched ground is not switching good so would that mean the grounding wires are not grounding properly.
  23. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    So from your diagram John the ground wire is broken, is that correct or mostly broken
  24. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    If it was shorted would the injector not stay open?
  25. Qavion
    14,622
    Ian Riddell
    I was thinking of it shorting to a power wire on the earth side, but I guess that would create a different base/starting voltage on your scope.
    Does the scope position the baseline on the screen according to voltage or can it be moved around?
    taz355 likes this.
