458 - Wheel Alignment | FerrariChat
458 Wheel Alignment
Discussion in '458 Italia/488/F8' started by hgoodwiniii, Sep 23, 2019.
  1. hgoodwiniii
    hgoodwiniii Formula Junior
    280
    Hi all, What's everyone doing for alignments? Dealership? I need to change the rear driver tie rod on my 458. Thanks.
  2. Rdwaggie
    Rdwaggie Karting
    107
    I did the dealership. Also had them do the road balancing on the new tires. Had a hard time finding anyone in Austin to do it that I trusted.
  3. Solid State
    Solid State F1 World Champ
    10,577
    Maximus Decimus Meridius
    My dealer does an awesome job with 4-wheel alignment. That said a really great suspension shop is a wonderful asset.
  4. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    It's a bit of a hit and miss with dealers if you want a more personal setup. Some dealers whom also do a lot of racing will usually do this well. Dealers that just sell cars and do regular service can of course do the standard factory setup, but they are not what you want for chassis tuning.
    If all you need is a part replaced and factory setup, both your dealer and any decent suspesion shop can do it. All they need are the numbers.
    If you're looking for improvements, only use your dealer if the techs are used to work on Challenge cars etc. Otherwise find out what good speed shops other drivers in your area use.
    Solid State and Caeruleus11 like this.
  5. hgoodwiniii
    280
    Yes, I am just replacing a tie rod and need a factory setup in the Houston, Tx area.
  6. RayJohns
    RayJohns F1 Veteran
    7,920
    West Coast
    Ray
    What about measuring the existing space between the adjustment nuts on the tie rod with a caliper, then just installing the new one and replicating it?
    Ray
  7. Caeruleus11
    Caeruleus11 F1 World Champ
    11,606
    In Houston you have Risi- they do a lot of racing and I bet they would do a fabulous job for you.
  8. Solid State
    10,577
    I do that on my DD to get it close then have the shop do the lazer alignment. I check afterwards and usually find all for were adjusted slightly differently from original distance and sometime one quite a bit different.
    RayJohns likes this.
  9. hgoodwiniii
    280
    #9 hgoodwiniii, Sep 25, 2019
    Thanks for the replys.
    I certainly plan to try to measure and adjust the new tie rod in line with the old one
    I may want to just go ahead and have it checked afterwards. It seemed to have a bit of a pull in it when driving, anyways. I'll see how it feels after I put the tie rod in.
    I will give Risi a call;
    Thanks.
    TomC9786 likes this.
  10. hgoodwiniii
    280
    Hi everyone, what's a fair price for a 458 Italia standard alignment? I'm being quoted between $350 and $800 so far.
