360 - Wheel arch dent | FerrariChat
360 Wheel arch dent
Discussion in '360/430' started by Kitchdog, Apr 7, 2020.
  1. Kitchdog
    Kitchdog Karting
    Jan 10, 2019
    151
    Ryan
    Hi all,
    have an annoying little crease on a rear wheel arch. It’s minor and can only be seen from a specific angle but I always know where to look to see it haha. Have no idea how it got there.
    I had some PDR guys look at it and they suggested glue pulling but said there was a chance it could pull paint.
    Feeling in and around the rear wheel arches it feels as though there are two layers of aluminium there and if I take the tyre off could get in between the layers and beat it out without glue pulling.
    Anyone had any of these annoying dents/creases in a similar area? Any tips?
    cheers!
  2. RedNeck
    RedNeck F1 World Champ
    12,328
    The CSA
    Me
    Have a pic? On a lot of these cars, including mine, the fenders have been rolled to make clearance for tires. Might be what you are seeing.
  3. Kitchdog
    Kitchdog Karting
    Jan 10, 2019
    151
    Ryan
    It’s that horizontal line (the other marks are just dirt, needed a clean here) and that mucky PPF you might see has been replaced too.
  4. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,948
    Melbourne Florida
    KGC
    That's a tough one. If there is a double panel there (I haven't checked my car) then it will be pretty tough to make it go away. I can tell you that I took a small ding out of my door when I got my 360 and that aluminum is hard stuff. It took quite a bit more force to get it gone than any ding I worked on a steel car. FWIW
    BTW, I'm not one of those ding specialist with all the special tools. So maybe keep looking for the right guy. There's a lot of them and I have found that there are only a few that are real pros at the top of their trade. Check with the high end dealers in your area. Ask who they use.
    And I don't blame you, that would bug me to no end too.:)
    Kitchdog likes this.
  5. RedNeck
    12,328
    The CSA
    Me
    Oh wow, yeah, that's probably not from a fender roll, looks like something jumped head first. Not even sure after PDR it would not still show some evidence of being there. It would bug me too, but may just want to consider acceptance.
  6. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,782
    Aluminium is tricky to do because it work hardens easily.
  7. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    No PDR will be able to remove that , I would call that more of a crease . I ran a used car super store for Toyota and those PDR guys work for me in reconditioning my used cars I know what they can and can not do. My AirStream has the same crease to remove it the inter panel has to be remove and roll out the crease with a metal roller. You will not be able to remove the enter panel to work on your 360. Only way IMHO take it to a pro body shop they will have to sand away the paint and use aluminum pull rods to remove the crease or fill body filler witch I would not recommend . I would get a estimate from a body shop and maybe fill a claim with your INS company
    Kitchdog and Skidkid like this.
  8. 02360spider
    02360spider Formula 3
    May 27, 2015
    1,753
    Dartmouth
    Richard oliveira
    I had a bunch remove I had creases and dings they charged me $700 but it came out amazing.
    Sent from my SM-N975U using Tapatalk
  9. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    I had a crease in my 430 door which the man pressed out in half an hour,, u would never know. Mine was easy as went down past the door glass and pressed it out. If they can get behind it , it should come out
    SoftwareDrone and Kitchdog like this.
  10. J360M
    J360M Karting
    Nov 29, 2018
    76
    It’s a crease and looks relatively easy. It will need some careful manipulation from behind the panel and some gentle warming... If in doubt, get professional help.. but make sure if using a dent puller to check it won’t pull the paint (if original paint you should be ok). I’ve pulled dents from original paint on all my Ferrari’s over the years.
