Wheel bolt torque setting | FerrariChat
Discussion in '206/246' started by gstraub, Jul 18, 2012.
  1. gstraub
    gstraub Rookie
    Mar 12, 2011
    4
    Can someone tell me the proper wheel bolt torque settings for the 246, standard cast wheels?
  2. HMB-Dino
    HMB-Dino Formula 3
    2,256
    Pebble Beach, CA
    RonG
    Owners guide (under the section Jacking Up The Car) says to tighten the bolts to 9kgm, which equals 65lbft
  3. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,605
    Toronto / SoCal
    Rob C.
    Discussed to death in other sections and the 246 is no different. About 73-75 foot pounds.
  4. HMB-Dino
    HMB-Dino Formula 3
    2,256
    Pebble Beach, CA
    RonG
    That's significantly over what my manual says.
  5. HMB-Dino
    HMB-Dino Formula 3
    2,256
    Pebble Beach, CA
    RonG
    The point is why would you apply more torque than what the owners manual explicitly states?
  6. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,605
    Toronto / SoCal
    Rob C.
    I guess I'm just a rebel that way :)
  7. abstamaria
    abstamaria F1 Rookie
    Feb 11, 2006
    2,668
    Andres
    Not helpful at all.
  8. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,187
    Norfolk - UK
    Tony
    9kgm or 65.09712465 ft lbs or failing access to a torque wrench.....as tight as you can with the wrench spanner..either way is preferrable than hand tight
  9. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,605
    Toronto / SoCal
    Rob C.
    The point is that you are very safe in the 65-75 lb/ft range and will find yourself perfectly within the design parameters of the bolts and wheel rims. Outside of this range and you are likely to end up like this guy:
    [ame]http://www.youtube.com/watch?v=67rX4I8Swfw[/ame]
    bertspeed likes this.
  10. HMB-Dino
    HMB-Dino Formula 3
    2,256
    Pebble Beach, CA
    RonG
    That's funny, although probably not for the owner. But I think that meeting the factory stated value is also ok. Besides, I don't run my Dino thru cones.
  11. abstamaria
    Feb 11, 2006
    2,668
    Andres
    #12 abstamaria, Oct 30, 2014
    I bought neat color-coded Koken (Japanese) wheel nut sockets for the Dino and the other cars I have, and thought I would put labels with the torque setting on each. This is a 19mm socket; the Dino's 22mm socket is yellow. They're great to use.
    Accordingly, I revisited this thread for the torque rate for the Dino. The other threads mentioned above deal with other models and some suggestions don't cite any basis or authority. So I'm going with the manual's 65 lb.ft. Coincidentally, the Stratos manual specifies the same torque setting - 9 kg.m.
    Andres
