Wheel cleaning help | FerrariChat
Wheel cleaning help
Discussion in 'Technical Q&A' started by CavalloRosso, Aug 18, 2007.
  1. CavalloRosso
    CavalloRosso Formula 3
    Jul 12, 2007
    1,423
    Atlanta, GA/Vail, CO
    SVO
    I have HRE brushed aluminum wheels. I haven't found any good way of cleaning them. Everytime I switch to some different product, the wheel looks dull. I'm worried that I'm ruining them with poor products/technique. Can someone with similar wheels/experience please help.
  2. f355spider
    f355spider F1 World Champ
    18,055
    If they are not clear coated, then you should use the mildest of soap to minimize any reaction with the metal surface. Griot's wheel cleaner is pretty mild: http://www.griotsgarage.com/catalog.jsp?&SKU=11106
    But to bring back the gloss, you may need to use a metal polish first. Like Flitz, MAAS or Wenol...which all seem pretty interchangeable to me.
  3. CavalloRosso
    Jul 12, 2007
    1,423
    SVO
    Thank you for the advice. I've tried Griot's wheel cleaner. I will try a metal polish.
  4. Todd Helme
    Todd Helme Formula Junior
    Apr 2, 2007
    947
    Oviedo Florida
    Todd Helme
    #4 Todd Helme, Aug 18, 2007
    For a quality wheel cleaner, you cannot beat P21s wheel gel. It has incrediable staying power, but is very mild, so it works by clinging to the surface, where you can let it dwell for up to two hours before rinsing away. The down side is that it is very expensive, 25 dollars for a little spray bottle, and up to 100 dollars for a half gallon. However, it is considered the industry standard, and considered top of the line.
    To test if your wheels are clearcoated, take a little metal polish and rub in lightly on a spot. If the towel turns black, then you have uncoated wheels. If it does, your wheels are clearcoated. Clearcoated wheels should be treated like paint, with a mild paint polish used to remove scratches and restore gloss, then a quality sealant (such as Zaino) to protect.
    Here are two sets of Ferrari rims. The first are painted and clear coated. A mild polish was used to restore gloss, and Zaino sealed it in. The second set are custom rims that featured clear coated centers and metal barrels. The spokes where treated as above, the metal was hand polished with Meguiars NXT All Metal Polysh to a high gloss, then Zainoed to protect the metal.
    Once protected with a quality sealant, the rims will be very easy to clean with regular carsoap, and generally just spraying the wheels with water will cause the brake dust to literally flow off!
  5. CavalloRosso
    Jul 12, 2007
    1,423
    SVO
    The metal polish worked beautifully..........thanks for the help.
  6. f355spider
    18,055
    Nice ! What did you use? Most of the metal polishes I mentioned have a protectant in them, so as mentioned by TD, you can just use normal wash mit and soap to clean them. An additional coat of wax wouldn't hurt though.
  7. bwiele
    bwiele Formula Junior
    Mar 21, 2007
    256
    West Harrison, NY
    Brian
    Tropicaldetail: the 3-piece Ferrari wheels that are available as a 360 upgrade...do you know if they are clearcoated or not? I THINK the are not, but I'm not 100% sure. Appreciate any input.
  8. CavalloRosso
    Jul 12, 2007
    1,423
    SVO
    I used the Flitz aluminum polish. It produced a black debris quickly which let me know that the wheels weren't coated. The result was amazing. I'll post some pics when I get a chance. Thanks for the info.
