355 - Wheel Insert and Other Wheel Questions... | FerrariChat
355 Wheel Insert and Other Wheel Questions...
Discussion in '348/355' started by huzilulu, Jun 13, 2024.
  1. huzilulu
    huzilulu Formula Junior
    Apr 20, 2011
    340
    Houston
    Huzi Husain
    Hey Guys
    I am getting my wheels refinished and new tires along with it... A question on a couple parts on the wheels:
    1) I got 20 new inserts from Ricambi - but it looks like they might need an o ring or something? They seem to have a groove as marked in the picture below - are these pressed into the wheel directly or do I need to use an Oring/Sealant/something else in the groove? My old one seemed to have some kind of black glue on it?
    2) What is No 12/13 on the diagram below? They are not on my wheels - so I am assuming just a dust cover... but any recommendation on where to get these/replacement covers?
    Thank you!
  2. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,217
    CT
    John Kreskovsky
    Don't know about the inserts other than I believe they came in two different diameters.
    12 and 13 are an o-ring and inner cap to seal off the wheel hole from the inside. T%he inner equivalent of 7 and 8. Most are lost after the first tire change.
  3. Ricambi America
    Sponsor Owner
    12 / 13 on the diagram seal the back of the central cavity where the yellow prancing horse emblem is. They keep some/most of the water out of that area.
    The inserts do not use any rubber o-ring. They are simply pressed into place.
    Qavion likes this.
  4. johnk...
    Jun 11, 2004
    11,217
    CT
    John Kreskovsky
    Daniel, On you web site, on the "Wheel" diagram, #47, they are listed as 14 and 15. 15 is called a gasket. Is that not an rubber O ring for sealing?
  5. m.stojanovic
    m.stojanovic F1 Rookie
    3,216
    Serbia - Niš
    Miroljub Stojanovic
    On diagram #47 (355, 2.7), part 14 is called "Gasket".
  6. Ricambi America
    Sponsor Owner
    #14 and #15 are for the rear 'center cap' -- they're not part of the Wheel Inserts which the OP is installing.
  7. Rifledriver
    37,082
    The word gasket is often used when it is a seal or an O ring. Ferrari has often used ESL students for technical translations so accuracy and consistency suffers.
  8. johnk...
    Jun 11, 2004
    11,217
    CT
    John Kreskovsky
    According to Daverocks, "Those are undercuts [grooves] in the inserts. The only purpose is the relieve the cutting tool radius so when inserted into the wheel the radius doesn’t interfere.
    Qavion likes this.
  9. Rifledriver
    37,082
    Makes very good sense.
