Wheel Question | FerrariChat
Wheel Question
Discussion in '612/599' started by George Vosburgh, Jul 29, 2024.
  1. George Vosburgh
    George Vosburgh F1 Rookie
    #1 George Vosburgh, Jul 29, 2024
    Here are the specs for a BBS wheel that came off of a 458. The sizes are correct for 599 but the off sets are different.
    Can someone please tell me if these will work on a 599?
    Front: 44, GTO: 38, Challenge Wheel: 43.5
    Rear: 56, GTO: 63, Challenge Wheel: 63.8
    The front looks like it will work, the rear I'm not so sure about.
    Are these too far off?
    Vorderachse:
    Felgenbreite: 8,75 J
    Felgengröße: 20 Zoll
    Einpresstiefe: 44
    Lochzahl: 5
    Lochkreis: 114,3
    Mittelzentrierung: 67,09 bzw 67,1
    Farbe/Oberfläche: Satin Black
    Felgendesign: Multispoke
    Teilenummer BBS: FI025
    Hinterachse:
    Felgenbreite: 10,75 J
    Einpresstiefe: 56
    Lochzahl: 5
    Lochkreis: 114,3
    Teilenummer BBS: FI026
    gated.599 likes this.
  2. tazandjan
    39,170
    George- Those will work fine. The rears are 1/4" (~6 mm) narrower than OEM but will not make much difference with same size tires if you do not mind. As a bonus, you get 3/4" wider front wheels. May slightly increase understeer, but easily countered with throttle on a 599.
  3. George Vosburgh
    Thank you Taz! What would be the best tire size for this set up on the 599, OEM sizes for Challenge?
  4. tazandjan
    39,170
    George- Affirmative, but you could still go one size larger on the rear if you want MPS4S tires without a problem.
  5. DZ-96
    DZ-96 Formula 3
    1,907
    South Germany
    Daniel
    George, take my calculator
    i took the last wheel "458" with the sizes you wrote.
    I had 22 mm and 25 mm spacers with 255 and 315 tires on my GTB before i mounted the GTO rims
    Daniel
  6. DZ-96
    DZ-96 Formula 3
    1,907
    South Germany
    Daniel
    At the B+C line 8 you see the spacers i had on the car.
    At the B+C line 12 you see the measurement from hub to rim outside.
    If you mount the 458 you can go wit 12mm and 20mm spacers (line 11) to get the same result as with Monolitic and 22/25mm spacers like on the photo
