Wheel spacer advice needed | FerrariChat
Discussion in 'Technical Q&A' started by Ricambi America, Aug 12, 2004.
  1. Ricambi America
    Ricambi America F1 World Champ Sponsor Owner
    Dec 7, 2003
    16,448
    Winston Salem, NC
    Can anyone advise the specific advantages/disadvantages for Hill Engineering's two different wheel spacer methods? One type of spacer bolts to the hub, then the wheel bolts into the spacer using OEM original bolts. The second type of spacer just sits against the hub, then a longer bolt goes through the wheel and the spacer, ultimately bolting into the hub.
    Is one better than the other? Why?
    (FYI, I'm considering 15mm front; 30mm rear on a 1990 348ts)
    -Daniel
  2. brm
    brm Karting
    Apr 26, 2002
    183
    Tampa, FL
    Bruce R. Morehead
    If you notice on their web site, you use the longer bolts on the thin spacers and the other method on the thicker spacers. I have them and they work great. The 15mm spacer does not have enough thickness to mount with the short bolts and to conceal them and the thickness needed for the wheel bolt inserts is not there either. In addition to the better looks, the car drives much better.
  3. kenyon
    kenyon F1 Rookie
    Oct 7, 2002
    2,837
    East Yorkshire
    Justin Kenyon
    See hill engineering in sponsor section...
  4. Noelrp
    Noelrp Formula Junior
    Aug 30, 2001
    630
    SSF
    Noel
    There's quite a few discussions about this many moons ago. Here's one.
    http://ferrarichat.com/forum/showthread.php?t=20050&highlight=wheel+spacers
    I have 15mm spacers on the back simply because i want the rear to be close to the factory Speciale spec. with the Challenge wheels. The handling improved noticably.
    I am partial about the front. There's got to be a reason why it wasnt increased from the factory.
    If you want my opinion .. get a set of rear spider wheels and do not forget the longer bolts.
    Good luck
