430 - Wheel spacers/ Brakes | FerrariChat
430 Wheel spacers/ Brakes
Discussion in '360/430' started by Mjzinno, Oct 25, 2022.
  1. Mjzinno
    Mjzinno Karting
    Jul 12, 2021
    56
    M Zinno
    I am going to do brakes this winter and was toying with and Just curious anyone with experience with wheel spacers for F430? Sizes for front and back? Titanium bolts upgrades? Hill engineering seems like highly rated. Any other tips and recs? Also if upgrading to Brembo 6 cylinder from 4 which was standard in 2007 does master cylinder or other stuff besides SS lines need upgrades to? Thx!
  2. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,111
    Josh @jtcarprojects
    Brakes you can convert to the factory ccm 6 piston in the front with IRON rotors for a really good price and they will be factory. If you do the rear you will need tbeebrake caiper since the non ccm rotors are smaller in the rear. And yes I would do brake lines since these cars are almost 20 years old. And that is basic good set up.
  3. tazandjan
    39,166
    There are no factory steel rotors for the CCM calipers. OEM rotors are 330 mm, CCMs are 380 mm in front, 350 mm in rear.
  4. GogglesPisano
    GogglesPisano F1 Rookie
    3,205
    East Bay, California
    Joe
    Just did spacers this past weekend. Left side of car is before, right side is after. I went with 18mm from Formula Dynamics on both front and back. They were the most reasonably priced and included properly sized lug bolts with them. You want to make sure you get hubcentric spacers, btw. I feel like the width is spot on for the back (15mm would have been fine too), but I'd like to get 10mm for the front as the center of the wheels are just barely proud. The tires fit under just fine though.
    Also, don't get fooled into thinking spacers are some magic future technology the way some of these companies sell them. Charging $500 for two spacers that are just turned aluminum is highway robbery. Maybe avoid the eBay special, but no sense in getting Novitec.
    QSA likes this.
  5. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,111
    Josh @jtcarprojects
    Rb brakes and Giro have replacement ones for the ccm
