Wheel spacers | FerrariChat
Wheel spacers
Discussion in '456/550/575' started by ReyF, Jul 19, 2017.
  1. ReyF
    ReyF Karting
    Jan 10, 2017
    73
    #1 ReyF, Jul 19, 2017
    Hello Gents, as a new owner of a 99 550 I'm looking for a set of quality wheel spacers. Let me know if someone has a set that are no longer in use. A photo of the newly acquired ride.
    p.s. just installed a pair of Capristo mufflers....exactly what a proper V12 should sound like��
    Jaredsalinsky likes this.
  2. DOWORKFCAR
    DOWORKFCAR Formula Junior
    332
    My 550 also has Capristo mufflers! Truly sounds amazing! Love that V12 howl.
  3. henryr
    henryr Two Time F1 World Champ
    22,407
    Atlanta
    Juan Sánchez Villa-L
    #3 henryr, Jul 19, 2017
  4. ross
    ross Three Time F1 World Champ
    Mar 25, 2002
    37,972
    houston/geneva
    Ross
    hill engineering uk
  5. Il Tifoso
    Il Tifoso Formula 3
    Oct 22, 2013
    1,642
    SF Bay Area, CA
    Ruben
    Congrats Rey, beautiful ride! I'm curious, why are you considering spacers? Front, rear, both?
    Cheers!
    Ruben
  6. ReyF
    ReyF Karting
    Jan 10, 2017
    73
    Thank you for the compliment, I'm just considering the rears. Front looks fine to me. I'm aware of the new ones I can get but figured I should first ask if anyone had a pair of pre own ones (25mm) before buying a new pair. Any pitfalls to rear wheel spacers for a car that's a weekender?
  7. henryr
    22,407
    Atlanta
    my vote would be to leave it as is.....
  8. Mr Mezzanotte
    Mr Mezzanotte Formula Junior
    Aug 22, 2006
    646
    Hill engineering (via ricambi for US) sells them.
    I have them on the rear of my 456GT with longer bolts, no issues at all for several years now.
  9. Il Tifoso
    Il Tifoso Formula 3
    Oct 22, 2013
    1,642
    SF Bay Area, CA
    Ruben
    +1, I wouldn't change a thing - modulars look fantastic as is!
    Ruben
  10. fstncln
    fstncln Rookie
    Jul 30, 2015
    41
    Brighton, MI USA
    Frank
    H&Rs are just as good (hub-centric, quality material and process, etc.) and cost less. I've got them on my 575, no problems at all at regular or higher speeds. H&R has the longer bolts too.
  11. tazandjan
    39,163
    Frank- H&R are nowhere near as good as the Type 2 Hill Engineering 25 mm spacers, which is what he needs for the rear of his 550. The HE spacers have hardened inserts for the OEM wheel bolts, while the H&Rs are just threaded into aluminum. I bought a used set of the H&R spacers and they were so badly cross-threaded we just threw them out and bought a real set from Hill Engineering/Ricambi. Steel bolts into aluminum threads that will be removed every time tires are changed are not a good idea.
  12. fstncln
    fstncln Rookie
    Jul 30, 2015
    41
    Brighton, MI USA
    Frank
    Taz - I was referring to the "TRAK+/DR Style" spacers which just require longer bolts. They are not threaded, the bolts still go into the stock hub. They're hub-centric so there's no issue with being off center and vibration, etc. I know, I've had the car up to some pretty high speeds with them and have not had any problems. The spacers which bolt to the stock hubs and then require another set of bolts to hold the wheel to them are heavier that the type I'm referring to and also have more tolerance stackup. Versus a good pass-thru design they just add weight and complexity while reducing the effective clamping force because the 2 sets of bolts are offset. Why have 2 sets of bolts when 1 will do? They might be better suited to thicker spacers (like 25mm). I only went 15mm since I've lowered the car a bit so the single bolt type was the better choice for me. The H&R part numbers I used are 3035671 for the 15mm spacers and 1457011 for the long bolts. H&R is a high quality German brand, IMHO.
  13. tazandjan
    39,163
    Frank- Those longer bolts on inch thick (25 mm) spacers are not a good deal because bending/shear forces are much greater. Plus I have OEM titanium bolts, so very limited options for longer bolts without spending a fortune. No difference in tolerance between a 25 mm spacer held on by longer bolts and one held on by a separate set of bolts, so I do not buy that at all. Both are just flat pieces of aluminum with holes bored in them. IN HE's case, with hardened inserts for the bolts. My titanium bolts make up for any gain in weight.
    For spacers less than 25 mm thick, longer bolts are the only option. Over 25 mm and the bolt on spacers are a better option in my opinion. Will take HE quality over H&R any day.
  14. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    2" wider rear track will make the car understeer even more.
  15. tazandjan
    39,163
    Not really, and not with FHP.
  16. 308 GTB
    308 GTB F1 World Champ
    11,717
    New Jersey
    Barry Wolinsky
    #16 308 GTB, Jul 25, 2017
  17. JohnnyRay
    JohnnyRay F1 Rookie
    3,597
    Central FL/NW WI
    I have a set of 30mm spacers. New and unused. PM if interested...
  18. Andrew D.
    Andrew D. F1 Rookie
    Jul 6, 2008
    3,979
    Goodwood Ontario
    Andrew D.
    Ive had my 456 on the track with 13" wide wheels and the back and 10mm spacers. No rubbing. But make sure your longer bolts engage the threads deeply enough. If they engage by only 3or4 turns a disaster will happen. By the way the track handling is very neutral with the bigger wheels and tires.(SO2s)
