wheel weights, really? | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by bmw tuning, Jun 20, 2012.
  1. bmw tuning
    bmw tuning Karting
    Apr 27, 2012
    178
    Portland OR
    Donny
    So i was admiring this beauty on the bay and then I got to the pics of the wheels up close. The weights are stuck on the outside lip and with only 195 miles would assume that its still all stock? Does Ferrari really stick the weights on outside like that from factory? If so wow what a terrible thing, those would drive me in nuts! lol Ive heard some wheels need weight put on different sides to make them balance perfect but Ive had enough deepdish alloys over the years to know they can get them balanced from the back side.
  2. Redneck Slim
    Redneck Slim Formula 3
    Mar 10, 2011
    1,651
    Palo Alto,CA,USA
    Walt Kimball
    I've had dozens of balancings done,and not once has a weight needed to be put on the olutside. With proper equipment,it is not necessary. I have never understood why car makers do this with nice alloy wheels,especially painted wheels.
  3. chrisbinsb
    chrisbinsb F1 Rookie
    Oct 20, 2011
    3,675
    Santa Barbara
    Chris B
    My 308 had the weights on the outside when I bought it. Drive from the dealer to a shop and had them re-balanced with weights moved to the inside. No idea why anyone would out them outside an it did leave marks on the paint.
  4. netman
    netman Formula 3
    Jun 17, 2008
    1,905
    OC SoCal
    Had the same issue. Goof Off works well removing the adhesive
  5. Michael B
    Michael B F1 Rookie
    Apr 28, 2004
    3,762
    US of A
    Michael
    Its simple.
    Wheel width is a factor. Yes you can balance a wide wheel with inside placed weights only - but to place weights on the outer portions of the wheel is much more effective & with less weight (I.E. rotating mass - which is why the factory does so).
    Today's balance machines can do a myriad of special things, including (but not limited to) hiding the balancing weights behind each spoke - and yet still getting the wheel to balance. Is that optimal? No. Is placing your weight all on the inside optimal either? No. But those with limited needs for performance or engineered accuracy need not worry, as it will do for them.
    As for me, its a wide wheel. The factory & I will place the weights where they can benefit me the most. Aesthetics will be second.
  6. SrfCity
    SrfCity F1 World Champ
    Not sure what car you're referring to but on say the new 458 the front wheel weights have to go on the outside because the calipers are in the way and would knock them off as the wheel spins.
  7. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    I understand that the proper way to balance mag/alum wheels is to place the weights along the center line of the wheels. All of my wheels have been done this way by 2 different tire shops. After they clean and stick them on the use a racing/duct tape over them. My cars with steel wheels are balanced on the inside lip using the old hammer on lead weights.
  8. Michael B
    Michael B F1 Rookie
    Apr 28, 2004
    3,762
    US of A
    Michael
    Great point.
    Dynamic balance becomes more acute as the wheel/tire assy. becomes wider and rotational speed increases. Moving the weights for cosmetic purposes may not produce dire consequences, and the difference may (or may not) be imperceptible - However, it's still there. Your two tire shops have followed a version of balancing that is accepted by customers but if the wheel has any real width to speak of then calling it proper is a bit of an exaggeration. If it were indeed proper then you would find manufactures following their lead.
    Nevertheless the OP can certainly gleam what information he needs from all of these helpful posts.
  9. JDZNate
    JDZNate Formula Junior
    May 14, 2007
    607
    Portland, OR
    Nate
    I noticed on my wheels (aftermarket Ray's Engineering) the wheels weights are in the inside lip of the wheel as well as inside the barrel.
