Wheels air control problem | FerrariChat
Discussion in '360/430' started by chris430, Feb 4, 2013.
  1. chris430
    chris430 Karting
    Oct 30, 2005
    182
    I have a problem with the sensor, appears in red and have no pressure, all wheels are ok, do you know how to fix it?
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,666
    South East
    Jimmie
    Have you tried the recalibration procedure ? The next step is probably the sensors in the tires have died
  3. big_guy
    big_guy F1 Rookie
    Sep 9, 2007
    3,190
    Ontario, Canada
    The batteries in the TPMS sensor are good for approx 5 years. You will know if its the batteries if after recalibrating everything will work perfectly for some time (days or even weeks), then the sensor in the same wheel will fail again.
    BTW, you cant replace just the batteries, you will have to replace the entire sensor.
  4. Noblesse Oblige
    Noblesse Oblige F1 Veteran
    Nov 7, 2011
    6,114
    Three Places
    The TPMS is my '07 failed late last year. I replaced the sensors and all is well. There is a cheaper aftermarket part available from TireRack that appears to be identical to the Ferrari part but I could not get that to work. Had to go the the factory part.
