Wheels and Tires for 308 | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by Devin Stone, Feb 17, 2005.
  1. Sophia
    Sophia Formula Junior
    Aug 17, 2003
    298
    Dash Point/Federal W
    Peter Barbin
    Here are a couple of posts that might add a tid-bit of info. here:
    http://www.ferrarichat.com/forum/showthread.php?t=11452
    http://www.ferrarichat.com/forum/showthread.php?t=25666
    http://www.ferrarichat.com/forum/showthread.php?t=9346
    Good luck with your search, I've seen many sets of the rims like Spasso has on his car, new in the box, on GT4's...the quality is very good and they are a great value. I got lucky and found my stock 16" Cromodora's from a private party. I did fly cross-country to look at them before I bought them; these original magnesium wheels can corrode something awful, particularly at the hub interface.
    I paid $2k for a set of 5, 3/7's and 2/8's. Great deal but I had to refinish them, and I'll never do that again...alot of work for a nice finish. Factor in around $500.00 or more for a professional refinish. PeterB.
  2. GavC
    GavC Formula Junior
    May 9, 2004
    492
    Lincolnshire, Englan
    Gavin Culshaw
    I have just finished refurbing my 16 inch rims. I was wondering if 245/45/16 and 225/50/16 tyres would fit on a 308 gt4 or stay with 225/50 and 205/55. The car is also lowered. I currently have 225/60/14 all round it does catch at front on full lock and also if I hit a bad bump in road. Any thoughts on this guy's.
  3. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,322
    Ventura, California
    Robert Garven
    225's will rub on a gt4 and even bend the inside of the fender if it lowered anything over 205/55 I personally would not use. BTW the QV wheels were available even on the gt4 in Europe as early as 1978, the part numbers are the same as in the 79 gt4 catalog as opn the 84QV's.
  4. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    #29 chrismorse, Feb 19, 2005
  5. jpl
    jpl Formula Junior
    Dec 4, 2003
    370
    Yulee Florida
    JP Lavigne
    I don't mean to hijack the thread but I have a question reqarding some new 16" wheels I just bought.
    I got the 16" 328 pre-abs wheels from Ferrari UK and I am planning to put these on my 308. Do any of you have any idea where I can get the aluminum valve stems, or will the plain plastic ones work.
    Thanks in advance.
    JP
  6. Dr Tommy Cosgrove
    36,592
    Birmingham, AL
    Tommy
    The plain plastic ones should do fine.
  7. Dr Tommy Cosgrove
    36,592
    Birmingham, AL
    Tommy
    By the way, by "pre ABS" do you mean the wheels are concave because the convex ones were never really an indication that the car had ABS.
  8. jpl
    jpl Formula Junior
    Dec 4, 2003
    370
    Yulee Florida
    JP Lavigne
    Yes concave, and I always thought thats why the post ABS cars had the different wheels.
  9. Dr Tommy Cosgrove
    36,592
    Birmingham, AL
    Tommy
    I used to think that too. Evidentially it's not true.
  10. brent Lachelt
    brent Lachelt Formula 3
    Dec 6, 2003
    1,831
    Brownsburg, INDIANA
    Brent R.Lachelt
    #35 brent Lachelt, Feb 21, 2005
    I put these on my 82 308 gtsi when I had it. Compomotive 17x8 fronts and 17x9 rears and Yokohama AVS 100 tires. Wheels from Motorsports Specialties in PA. and tires from the Tire Rack. Total cost about $2600.
  11. f355spider
    f355spider F1 World Champ
    18,055
    I certainly would not recommend driving at freeway speeds on tires exceeding 10 years old...they really lose a lot of their adhesive properties, let alone the ability to even hold air! Seen them on cars, with cracks, and delaminating...scary!
    Of course, if the car is just going to sit in a garage, then that's fine...
  12. geekstreet
    geekstreet Karting
    Feb 7, 2005
    220
    Cam
    brent, those are lovely looking wheels. I might look them up when I need to replace rims. Are there mounting bolts under a centre cover? (It has a centre-lock style)
    The Mondials ran the convex "ABS" rims from the first series (8, QV, 3.2) but only the later 3.2 models have ABS. I believe the convex rim is designed for a revised susp geometry, so I wouldn't just slap them on any car without checking this out.
  13. Dr Tommy Cosgrove
    36,592
    Birmingham, AL
    Tommy
    Those look really good!
  14. Sophia
    Aug 17, 2003
    298
    Peter Barbin
    Plastic, you've got to be kidding, you own a Ferrari, not a Dodge Neon. I would hesitate to cruise at sustained speeds with a "plastic" stem...they can let go. The Fuchs wheels on my old Porsche had a valve stem supports; they "caught" the rubber stems when they flexed at high speeds due to centrifugal force, thus preventing a sudden loss of psi if the stem were to tear under load.
    It would be a shame to have a sudden psi loss due to a valve stem failure.
    PeterB.
  15. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Most tire shops have the chrome steel stems on hand. They are not that much more and look much better.
  16. BigTex
    79,406
    Houston, Texas
    Bubba
    The OEMs are not steel........they are aluminum, I believe.......if you are spending that much money I'd try to track some of those down...
    The intent was not to throw balancing off, IIRC.......
    All of mine have them......
  17. BigTex
    79,406
    Houston, Texas
    Bubba
    Better check on that Spasso...I've seen beauty trims slipped over a rubber assembly and chrome capped.....still a rubber pop in....
    Not the same as the OEM stem at all.......
    Somebody drop over with a camera, I have an unmounted set stacked up.
    The metal ones have a 'retaining seat' inside the wheel, as well as the nut on the outside..no way that thing is leaving!
  18. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    I like the steel better. Stronger and less likely to fail if they take a hit. The difference in weight is negligable when it comes to balancing. Weight will be applied to the wheel regardless of which stem you use.
  19. BigTex
    79,406
    Houston, Texas
    Bubba
    I agree the weight is unimportant.......it is important to use one that allows for the thickness of the rim......I guess that's why the threaded ones came in them.......
  20. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Threaded? What threads?:p
  21. BigTex
    79,406
    Houston, Texas
    Bubba
    That's what I'm trying to tell you...OEM stems BOLT INTO the wheel...solid metal.........mechanical fastening.....not some pop in rubber deal......
    I have 14" Chromos and 14" Campis........
  22. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    #47 Spasso, Feb 22, 2005
    I have 14" also, in a stack in the basement. When you said threaded I thought you meant that the wheel itself was threaded.
    All of my stems are inserted into the wheel and held there with a nut on the opposite side.
  23. BigTex
    79,406
    Houston, Texas
    Bubba
    That's it...thanks...one pic = thousand words...
    One point off, on that cap..........LOL! ;)
  24. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
  25. Sophia
    Aug 17, 2003
    298
    Peter Barbin
    Spasso can get away with the stronger steel valve stems as his wheels are aluminum. I don't think it would be advisable to put the steel valve stems on the factory magnesium wheels, as a "fuzzy science project could result" over time??? With the moisture inside the wheel, a scratch in the chrome stem/wheel paint?...steel and magnesium = bad. Reminds me of a few relationships I've had, all pretty, shiny and solid at first...only to end up in a black crumbling fuzz.
    I've seen some bubbling wheels here in the moist NW, the factory wheels love to bubble if not well primed and painted. Perhaps another reason to go with the nice aluminum repros. rims for cost & durablility...they are about 6-7 lbs. heavier than a stock mag. wheel though. PeterB.
