Q. Hi new to the ferrari world i have a 1980 308 I am wanting to know if 360 -355 19" wheels will fit tire size 235 35 19 fronts 295 40 19 rear (P Zero) same bolt pattern 5 X 108 do not know offsets i believe mine is low or O Thanks
Hi Dan, Welcome to F Chat. 360 and 355 wheels are 18 inch. There is some variability and debate about what will actually fit under the fenders without moving the top rear shock mount or raising the back a bit. Spacer choice is is critical to getting the wheels to work. If you go to the top left item in the header, "search" and try, "355+wheels+308" and hit search, or do the same with 360, you will find a selection of threads discussing wheels and tires, so give it a try. hope this helps, chris Image Unavailable, Please Login
